Everything posted by druxey
I use an electric coffee-cup warmer for heating my Sparex.
- 1,449 replies
Silver soldering multiple joints is a challenge. Your solution of a one-shot deal was quite creative! Well done, Toni. I was taught to use different melting point solders for such situations. For the first joint or joints use 'hard' (highest melting point) solder, then 'medium' for the next and 'soft' (with the lowest M.P.) for the last joints. I believe that there is an even 'softer' grade now available. The other trick is to paint on yellow oxide (powder in water) over the joints you wish to protect; this inhibits the solder from re-melting. My jeweller friend showed me these techniques some years ago. Thank you, Shannon! You've saved my sanity on many occasions.
- 1,449 replies
Pandora by marsalv - FINISHED - 1:52
druxey replied to marsalv's topic in - Build logs for subjects built 1751 - 1800
Very nice work. The correct number of reef points on the sails are particularly impressive! -
Square or round tuck?
druxey replied to lmagna's topic in Building, Framing, Planking and plating a ships hull and deck
Without knowledge of the particular builders of Providence, it would be hard to determine which method was used in that specific case. My personal bet would be a square stern (not tuck), as this was more common on smaller vessels. Your observation on Chuck's Cheerful is a good one. This detail of construction is not usually seen on modern models. It was done this way with rabbets in both directions to prevent plank end-grain from being exposed to water. If not done, moisture followed by rot would quickly wick its way in. One can see this detail of construction on models in the USNA museum collection, as well as being explained in the new book on The Hayling Hoy of 1759-60. -
Also good references to consider: Darcy Lever, The Young Sea Officers' Sheet Anchor (A slightly later time period, though) David Antscherl, The Fully Framed Model, Volume IV C. Nepean Longridge The Anatomy of Nelson's Ships (Again, slightly later)
This looks like it's going to be another fascinating reconstruction! Interesting start, Dick.
- 263 replies
- nave tonda
- round ship
Gondola by AntonyUK
druxey replied to AntonyUK's topic in - Build logs for subjects built 1901 - Present Day
An interesting challenge! Look forward to see how you will deal with this banana shaped hull. -
HMCSS Victoria 1855 by BANYAN - 1:72
druxey replied to BANYAN's topic in - Build logs for subjects built 1851 - 1900
Very nice metalwork, Pat!- 1,004 replies
- gun dispatch vessel
- victoria
Beautiful workmanship as ever. However, I'm confused: isn't the garboard strake the outer plank or plate next to the keel? Or is this term applied differently in metal ships?
- 281 replies
- falls of clyde
- tanker
Methodical or what? Very nicely done, Ed.
- 3,618 replies
- young america
- clipper
"The bit that curves up" is the deadwood. I'm interested to see how this all turns out!
