Everything posted by druxey
Your model is turning out very nicely indeed. Very neat work, Mike.
- 452 replies
- cheerful
- Syren Ship Model Company
Standard, indeed. Maybe omitted not to scare off less experienced builders? They are fiddly things.
Frégate d'18 par Sané , la Cornélie
druxey replied to JohnE's topic in CAD and 3D Modelling/Drafting Plans with Software
I thought the saying was "Measure twice, cut once; then blame the tape measure." -
Sorry: you are correct, Siggi: the photo of that model that I was looking at does not show that feature. There is a low breast rail! Entschuldigung!
The contemporary NMM (RMG) model of Thunderer/Hercules, SLR 0310, has one central ladder to the poop deck, and no breast railing.
Condolences. John. How frustrating. -
Steel wool can cause problems with finish as well. Either use bronze wool or run a magnet over everything after using steel. You'll be surprised at how many particles will be picked up!
Please stay in good health now. Nice to know that you are back, Robert.
- 241 replies
- royal caroline
- yacht
I imagine only one access ladder was needed until there was armament mounted on the poop deck.
Thanks for the response, Pete. I assume that the alcohol you use has some water content?
- 258 replies
- buzzards bay
- herreshoff
The method you need is to taper the square stick first. Then cut the octagonal and round sections to an octagon by the 7-10-7 proportion across each flat. Finally round off the octagon where the stick is to be round and voila! A perfect mast or spar. One book that illustrated this process is in The Fully Framed Model, Volume IV.
Lovely looking work, Pete. Can you explain the advantage of using alcohol over water for soaking the frames please?
- 258 replies
- buzzards bay
- herreshoff
Echo by Maury S - FINISHED - Cross-Section
druxey replied to Maury S's topic in - Build logs for subjects built 1751 - 1800
That volute looks pretty good to me, Maury! It 'flows' from the straight to the curved section, and you've done that very nicely.- 324 replies
Ah, the Curse of Cumulative Error! Glad you overcame it, Toni.
- 1,449 replies
Lovely. However, the ensign staff and flag were struck when under sail: that mizzen sail and boom swinging across would wipe it out! Under sail the ensign would fly from the gaff peak instead.
Yes, those serpentine curves - plus the transverse curve - are very tricky to do, but you've nailed it, Siggi!
Most Boleys are 8mm but a few older ones are 6mm, Matle.
