Everything posted by druxey
There is little available on carronades mounted on the 'outboard principle'. Some years ago I researched these mounts from the early 1780's. Contemporary illustrations are reproduced in Caruana's The History of English Sea Ordnance 1523-1875, Volume II, pages 195 et seq. (The actual model's carronades were cast in pewter.)
I believe from previous comments on MSW that this device is a snare and a delusion! One needs to rig shrouds the conventional way - on the model itself.
Some thought on your dilemma: One, is that really lime wood? The appearance is very different to lime I've used in the past, where the grain is almost invisible. Two, your workmanship is fine - that is not the issue. Three, I note that the grain on some of your futtocks does not run at a tangent to the piece (e.g. photo below 'glue in with titebond'). Avoid cross-grain as much as possible. Four, fit temporary cross-spalls across the toptimbers to maintain designed width. This was done on full sized frames.
Tiny Spar on 17th Century English Yacht
druxey replied to catopower's topic in Masting, rigging and sails
Clare: The reason for my identifying the model easily is that, for the past four years, I've been studying Stuart Royal yachts very closely. I've seen examples or photos of every contemporary model still extant, plus many paintings and drawings of these. In fact, there is now a study model of the original 1683 Fubbs (not the 1724 rebuild!) and a SeaWatch book on her will be published in due course (shameless promotion). In addition, a fellow researcher in England and I are working on a book that covers all 25 Stuart Royal yachts in detail. Now, aren't you sorry that you asked! -
Good repair work; something we all do occasionally!
- 62 replies
- Muscongus Bay Lobster Smack
- Model Shipways
Håkan is right; some of the models you see are built by veteran professionals. Take heart; your work so far is excellent.
- 99 replies
- ancre
- La Mahonesa
The short spar at the right is the gaff for the mail sail, foreshortened. On the jib sails, lowered, I can see what appear to be wood block-like attachments for the halliard. These are Dutch yachts, of course, not English ones. -
It is a contemporary model with MODERN rigging: https://www.rmg.co.uk/collections/objects/rmgc-object-66339 No contemporary painting shows these spreaders. -
Curse those ignorant and over-imaginative 'restorers'! It's things like that that really muddy the waters. I feel your frustration in discovering that your 'primary' source is really a secondary and unreliable one. My sympathy, Steven.
- 508 replies
Is the difference in measurement due to the fact that the cant frame drawing is a projection one, i.e. drawn at an angle to the centerline, not at right angles?
- 99 replies
- ancre
- La Mahonesa
Some pins and rails are seen on Vasa's beakhead.
Looks very nice, Mark. For drilling scuppers, I start with a very small bit and drill from both sides. Hopefully the holes align, but if not, this can be corrected as one gradually opens out the hole. Again, work from both outside and inside. That way is less scary, for sure, and avoids any splintering out on an exit hole.
