Everything posted by druxey
Bragozzo by maurino - FINISHED
druxey replied to maurino's topic in - Build logs for subjects built 1901 - Present Day
It's so nice to see seldom modeled subjects. The Adriatic ships are very colorful, as are other many other Mediterranean vessels. -
Very well done indeed, Steve! Congratulations on a complete (I almost wrote 'string') quartet. Now you have the skills for even more advanced models. What's next?
- 27 replies
- Nonsuch
- Model Shipways
Setting up deadeyes to shrouds
druxey replied to Lost and Confused's topic in Masting, rigging and sails
Yes. The cut splice in the swifter is slipped over the masthead. Place the upper deadeye on one side where you want it, remove the swifter and turn the deadeye in. While on the bench, it is easy to position the second deadeye on the other leg of the swifter. -
I appreciate your problem - we've all been through this at one time or another! There are a number of ways to deal with this. Ideally there is a small amount of stretch in the shrouds that will allow for micro-adjustment. However, don't overdo it or either the lanyard will give way or the mast will pull out of line. For the main part of the process I will loop the end of the shroud up (once it is in place over the masthead) until the bottom of the loop is at the level you want the deadeye to be. (A bit of water on a brush applied to the shroud at the bend will help it behave.) I then secure the deadeye in this loop with a spot of glue. Take the shroud off again and complete the lashings around the deadeye on the bench rather than in the air. Then re-install the shroud pair and reeve the laniard. Other folk will doubtless provide you with other remedies. One size doesn't fit all - try them until you find one that works for you. -
Looking very good, Toni. It helps to use your chisel bevel down to control depth of cut when eight-squaring the spar.
- 80 replies
- rigging/masts
- NRG
I've used many different methods over the years. I began with black tissue, graduated to Allan's paint/PVA mix, and now use dark brown acrylic paint (burnt umber) along the outer (show) edges of joints on one side before gluing up. I find black a little too visually contrasty, but that's a personal preference. For minor seams such as planking, soft pencil along the show edge does the trick for me. Try different methods until you settle on the one(s) that you like.
Miniature Russian carving tools
druxey replied to druxey's topic in Modeling tools and Workshop Equipment
Patrick: Unfortunately, due to the current international situation, you will be unable to get these. -
Wrinkled paper suggests that you were using a water-based varnish. Paper does not like moisture. For the length of a build, rubber cement is a good alternative 'glue'. Eventually it will turn paper brown and peel, but that usually takes more than ten years! Enjoy the process of buldign up a model like the real thing.
- 92 replies
