Everything posted by druxey
Yes, beeswax will eventually cause problems, as it is not pH neutral like conservators' wax. However, it's your call. I imagine you should be OK when you've applied the wax.
Door hinges
druxey replied to src's topic in Discussion for a Ship's Deck Furniture, Guns, boats and other Fittings
If it did open inward, runner 63 is correct. However, weather deck doors open outward: think of a heavy sea breaking over the deck. The water pressure would blow an inward opening door open. In the 18th century 'T' style hinges were most often used. -
Any natural fibre will absorb and give off moisture. Shellac is not water-proof: remember the white ring if you accidentally put a water glass on a French polished table top? You'll either need to live with what happens or slow the moisture migration by using conservators' wax or some other means.
Barrels
druxey replied to ross's topic in Discussion for a Ship's Deck Furniture, Guns, boats and other Fittings
The only barrel that might be on deck would be a water barrel: a butt. That's where gossip occurred (think the office water-cooler!); hence the origin of the expression 'scuttle-butt'. -
SS Vinal Haven by TBlack - FINISHED
druxey replied to TBlack's topic in - Build logs for subjects built 1851 - 1900
You wrote: I'm disappointed that, with the roof on, you can't really see the interior detail, sigh! But, you know it's there! And so do we.- 326 replies
- vinal haven
- steam ship
Echo by jml1083 - cross-section
druxey replied to jml1083's topic in - Build logs for subjects built 1751 - 1800
Thanks for the update, Jim. We will be patient..... -
Well done: those sleepers are tricky beasts to tame!
- 1,449 replies
Sounds like quite the struggle to achieve the result you wanted, Dan! But you've succeeded brilliantly in the end. I'm surprised that those essentially soft-soldered joints held. Food for thought....
The other method will also yield consistent slots, Toni. The only difference is that about 50% of the slotted material vanishes in sawdust!
- 1,449 replies
Now that's something I hadn't thought of: I always cut the slots first in the stock, then part off the individual pieces. Your pre-cutting the strips, then gluing them is a great idea.
- 1,449 replies
19th century U S Ship-of-the-Line Rigging Plans
druxey replied to Frank Cook's topic in Masting, rigging and sails
Looks like you are making good progress bringing order out of chaos. Possible sources for you might be the U.S. Naval Academy Museum or the Smithsonian. A good book on the subject would be James Lees 'Masting and Rigging of English Ships of War 1625-1860'. American rigging practice would be very similar. -
Congratulations! All you have to do is remove the 'bomb' shelter' over the wheel and pop her on the pedestals. She is a terrific model, Ed. Thanks for sharing her build with us here.
Sweet! You have got the sheer curve beautifully, as well as the various round-ups on the stern. No easy task.
Oh, yes: those railing supporters are, in the case of the outer ones, the tops of the outer counter timbers. If the inner ones align accurately with the pillars between the lights (hard to tell on your small image) then they, too are the upper ends of the inner counter timbers. If they do not line up, then they are standards on the quarter deck.
Looks like your drawing is not typical. The tafferel (aft) is lower than usual, so that there is a bulwark forward of it to make up the height for safety. This being the case, the tafferel is the width of the blue line, as it butts up against the bulwark. The latter has its own rail, the width of which you can measure directly from the plan.
