Everything posted by druxey
Used Cameron Drill Press Opinions Requested
druxey replied to James G's topic in Modeling tools and Workshop Equipment
I had a second hand Dumore (not Cameron) for some years that I bought on eBay. I had to re-wire the very aged cord and I stripped down and re-sprayed the casing. It worked very well, but I used it so little that I sold it again. -
Yes, some adjustment is needed for this to articulate properly. Does the port side seat back sit as it should? Certainly you are taking care: the use of shims nicely demonstrated!
- 27 replies
- Nonsuch
- Model Shipways
Drifts
druxey replied to tlevine's topic in Building, Framing, Planking and plating a ships hull and deck
But you must be so practiced with chocks by now.... -
Drifts
Bob: I agree that word meaning shifted with time, and I think we are agreed now! Thank you. Bruce: You've smoked me: I'm rotten to the core. -
2nd rate London 1656 – the art of the shipwright
druxey replied to Waldemar's topic in Nautical/Naval History
I don't think 'proof diagonals' were used until well into the 18th century. -
3D Brig 'Rose' in Blender 3.3x
druxey replied to 3DShipWright's topic in CAD and 3D Modelling/Drafting Plans with Software
Um, that partial sheer and profile plan shows no sign of a mini poop deck or access ladders. If there were a deck, then red ink lines would have defined it. Less is more! -
HMS Euryalus 1803 by rlb - 1:48 scale
druxey replied to rlb's topic in - Build logs for subjects built 1801 - 1850
Often hand tools are better unless one is a genius machinist! Most of us have repeatedly failed with bollard and hawse timbers, as well as cant frames. I certainly did in my first fully framed hull! Stay the course and you will succeed.- 122 replies
- Euryalus
- Plank-on-frame
(and 4 more)
Drifts
Bob: I respectfully disagree. 17th and 18th century vessels had these long bolts (not always 'drifted'), typically through deadwoods and other structures that required longer bolts. 'Drift' in the period sense of the word meant a change in level, such as the topside of a ship or diameter of a longer bolt. -
Drifts
Drift in this context would be a longer bolt with different diameter sections, the narrowest near the tip. The changes in diameter would be in small steps.And yes, it would be a friction fit. -
There really is no reason for that micro-deck aft and the access ladders. I hate to see the careful rendering go, but... -
Don't wish to pour cold water on your excellent renderings, but a ship this size would likely not have a figurehead at all (that will save you some work!). Turned spindles at the stern - no. Decorative work on the transom - also unlikely. No extra expense was made on these small ships, particularly at the end of the century in war-time. Of course, if this is a fantasy ship, ignore everything I've written! -
Interesting extrapolation of the half-breadth in the body plan producing a good fit! -
Spell Check
druxey replied to allanyed's topic in Using the MSW forum - **NO MODELING CONTENT IN THIS SUB-FORUM**
wrked? Apparently not! -
Tobias brings up an interesting point. I had a similar conversation just yesterday with a famous ship model miniaturist. He talked about realistic appearance in a model versus size-reduced actual construction. He himself runs a fine blade between the planks and then stains his work. The stain is picked up slightly more in the grooves, so that the seams show up subtly at viewing distance. Ultimately it is the individual model-maker's choice and how different builders develop individual styles.
