HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 66 donations so far out of 49,000 members - Can we at least get100? C'mon guys!) ×
druxey
Everything posted by druxey
  1. There's strength in numbers, Ian! Try them out, say I.
  2. I note that you've started two separate logs. Can you please amalgamate them into one for us? Thank you. So, a major job started! Fine chain is best obtained form a jeweler's supply house. In the U.S. Gesswein is a reliable source. Might I strongly recommend Rob Napier's new book on the subject of conservation/restoration of old models? It will address your questions well, I think. Available at: https://seawatchbooks.com/collections/new-arrivals
  3. My link should then send you to: https://www.eventbrite.co.uk/e/the-prize-papers-a-new-frontier-in-global-and-maritime-history-tickets-482335688027?aff=em&utm_source=emailmarketing&utm_medium=email&utm_campaign=wo_presale__8_dec_2022&utm_content=2022-12-11
  4. Sounds like an Ottawa Ship Model Society is about to form! Welcome aboard, Eugene.
  5. Well, you are deep down the rabbit hole, aren't you. Kranck? I wonder if it takes longer to design the files for 3D cutting than if one were to actually carve the pieces (assuming one has already acquired carving skills).
  6. Bienvenue ici, aurelein! Welcome aboard. You'll find a lot to look at here and advice if you need it.
  7. An online event about a trove of papers captured at sea between the 16th to 19th centuries. See : https://mail.yahoo.com/d/folders/1/messages/130473?.intl=ca&.lang=en-CA&.partner=none&.src=fp and scroll down. It is scheduled for Friday March 10. This should be of interest to many on this site.
  8. An easy mistake to make if you haven't been told or seen the process done.
  9. Well done on a challenging project! You should be very proud of the end result, Ian. Of course, I have to ask what is next?
  10. Certainly the English scored the deadwood for the heels of the frames for exactly the reason you state. It would be the only reasonable solution to the problem.
  11. Sills are probably the trickiest part of framing, except perhaps for cant frames. Gettigng the scores just so and the sill the exact length is a test of patience.
  12. Received Rob Napier's new book yesterday. A terrific read on Rob's career and a record of model cleaning and conservation. In addition it contains a sound philosophy on ship models and considerations to building in longevity to what we do.
  13. The lightness of a model's yards is a factor here. I pin the yards to the masts to overcome this. A small length of hard, blackened brass wire is almost invisible, as the yard is held slightly away from the mast it is raised on.
  14. Ways to reduce breakage: 1) Use bamboo with its long, parallel fibers. Split it first into smaller cross-sections by halving and re-halving the lengths. 2) Use parallel pliers to draw the pieces through the plate. The fibers aren't crushed which happens with regular pliers. 3) Draw steadily and in a straight line. 4) Only use the hard part of the bamboo just under the glassy outer layer.
  15. Apart from the "Honey, I shrunk the ship" shot, superb rendering work, Ron.
  16. You have achieved an excellent result with your 'wood' trim. Well done, Bob!
  17. So, you pay less for postage, but the mail strike hold things up instead. Can't win!
  18. Bienvenue and welcome aboard, Patrick!
  19. The 'alligatored' pebble-grain paint surface looks as if the model was exposed to extreme heat. Is this attic in a hot climate?
  20. Just catching up to you, Steven. Fascinating research and interpretation of those images.
  21. Thank you for educating us, Dick. I wonder wherher the ladder-like iconography represents internal thwarts or even frames?
  22. I use a ruling pen whose tips can be adjusted for width with acrylic paint, suitably diluted to flow nicely. (Each time you load the pen using a brush, test draw on scrap first!)
