Everything posted by druxey
HMS Euryalus 1803 by rlb - 1:48 scale
druxey replied to rlb's topic in - Build logs for subjects built 1801 - 1850
Ah, the learning curve. Some of use needed several attempts before we 'got it'. The up side is that you'll get it right first time on subsequent models.- 122 replies
- Euryalus
- Plank-on-frame
(and 4 more)
Most, if not all of us, don't fully realize what we are getting ourselves into until long after committing to a project. This applies to renovations as well as models.
- 740 replies
- Tudor
- restoration
(and 4 more)
Also see: https://seawatchbooks.com/products/swan-iv-sail-making-supplement-from-the-revised-and-expanded-edition-by-david-antscherl For sailmaking using Silkspan.
Yes, one comment: the plate should also include the maker's name! You are too modest.
- 43 replies
- Lowell Grand Banks Dory
- Model Shipways
Siggi: I thought you had labelled the draught Essex of 1741 (Post #875). What ship is that of then?
re the Essex draught: the floor battens retaining bricks are shown in plan view as the double lines. Aft of the stove is a heavy curved bulkhead with two doors. The stove area itself does not appear to be enclosed. No doorway is indicated along the lines of battens.
A small butane torch creates sufficient heat to anneal brass rod or tube. Be sure to do it on heat proof surface! When peening over, multiple very gentle taps work far better than banging down hard once or twice. This is especially true if the wood is soft, like basswood. Again back up with a very hard surface that will spread the other end of the piece being peened.
- 38 replies
- Norwegian Sailing Pram
- Model Shipways
Looks great, Ron. And you don't look so bad either!
- 542 replies
- Sphinx
- Vanguard Models
(and 3 more)
Yes, those knees are much less likely to fracture. The copper bolts look very pleasing, if tedious to do.
Henry: Without seeing exactly what you are doing, it is hard to diagnose what your issue is. (It could be one - or more - of a number of problems.) Might I suggest you find a jeweler to teach you the techniques that you need?
Nice neat job and presentation, Bryan. Well done!
- 28 replies
- Model Shipways
Just catching up. I winced looking at the photos of the Great Entanglement and could not click 'like' on those images. Well done on recovering from that disaster, Vladimir. Carving is such a different skill set from other ship model activities and low relief scrollwork to scale is particularly painstaking. Your results so far look great.
EURYALUS 1803 by Peter6172 - 1:48
druxey replied to Peter6172's topic in - Build logs for subjects built 1801 - 1850
Glad your hawse timber issue has been resolved. -
Gentle heat forming might be worth experimenting with, rather than wetting the sail.
- 740 replies
- Tudor
- restoration
(and 4 more)
Good to be aboard. Greetings from Alberta, Canada.
druxey replied to Al Litchfield's topic in New member Introductions
Welcome aboard, Al. Looks like a worthwhile model to restore/conserve. -
Great looking fries, Ron! Neat work so far.- 122 replies
- Euryalus
- Plank-on-frame
(and 4 more)
Design by Modelling
druxey replied to Hellmut1956's topic in CAD and 3D Modelling/Drafting Plans with Software
Good to see you back, Hellmut. Virtual flying will certainly exercise your cerebral cortex! Thanks for letting us know how you are doing. -
I agree that, for most things, CA is an abomination. As Allan pointed out, if a part has been properly pre-shaped, no serious clamping will be necessary; just finger pressure. A vet friend of mine does use surgical grade CA - for minor accidents in his workshop.
