Everything posted by druxey
Welcome aboard Jm. Sure, certain skills in cabinetry transfer well to wooden ship models, but some skills will need miniaturizing!
There are not many kit makers that spend just that little bit extra to supply better line. If you are taking care to build a really nice model, then go the extra mile and buy quality line. It really makes a difference, as you've discovered!
- 111 replies
- Nonsuch 30
- Model Shipways
Yes there are a number of variations seen on plans of mast partners. Some are experimental, such as on Vulture:
- 889 replies
Amazing as the photos are, I bet it's even more impressive in actuality.
- 542 replies
- Sphinx
- Vanguard Models
(and 3 more)
The cove looks much nicer, Ben, but I have the same reservations as Greg about that lettering....
- 889 replies
Your image of Bouteille du vaisseau le Soleil Royal is weird! My suspicion is that the image was rotated 15 degrees, as you point out; but whoever did that then turned the title in PhotoShop or similar to make it horizontal again. Otherwise it makes no sense at all. In any case, what purpose was there in rotating the image to begin with? "I guess the back end has to line up with the edge of the page!"
- 2,696 replies
- heller
- soleil royal
(and 9 more)
Delightful! What a lovely gift for Bean, aka Eve. Would you consider not using CA on your line, Keith? Acrylic matte medium is kinder if at any time in the future any line needs overhauling or adjusting again (See Rob Napier's new book!)
EURYALUS 1803 by Peter6172 - 1:48
druxey replied to Peter6172's topic in - Build logs for subjects built 1801 - 1850
A great start, Peter! I would caution you against the use of ferrous material in the model; at some point it will corrode. Instead, use brass or copper, chemically colored or blackened. When building what will be a very fine project, consider longevity as well! Also, iron was not used below the waterline. -
Looking good, Ben. I see that you 'nailed' texturing the ground to those coves! You might want to make the central motifs cross 'over ' and 'under' for a bit more depth.
- 889 replies
I can't advise you on the curved transparent panels. They need to be of some flexible plastic and using plastic is something I've very little experience of. Hopefully someone else here can advise you. And yes, Mark Twain was a great writer. And then, there's the notorious 'Court of Elizabeth' essay!
- 111 replies
- Nonsuch 30
- Model Shipways
Rather than fabric, consider using SilkSpan for the bimini. Stretch it like watercolor paper and use dilute acrylic paint, before cutting and fitting it. The boat looks great so far! As an aside, I see Mark Twain on the wall. You must be a fan!
- 111 replies
- Nonsuch 30
- Model Shipways
Superb work as always, Valeriy. I hope you can safely complete the model and that things will improve. My best wishes for you and yours.
A lovely and touching story, Keith. And yes, we get our granddaughter and family here this coming weekend. With 'blended' families it gets more complicated!
