Everything posted by vaddoc
Indeed Druxey. I read they were purposely forcing the growing trees to become crooked so they had a supply of such timbers. Now, I am slowly finishing the drawings by arranging the temporary frames but I really would like this boat to look good and I need to decide what wood to use. I would like to ask your help in choosing wood but maybe best to create a new thread, your contribution would be greatly appreciated. Vaddoc
Thanks GL Indeed, I was unsuccessful in getting the shapes of the planks with CAD. It will be much easier on the actual model with battens and paper shapes. It is possible though that the planks will have a very odd shape and significant curvature. Of course 50 or 60 cm wide pieces of timber are not really realistic, this is why I think the planks for these boats may have been scarfed which reduces the width of the blanks to half. Back in the 18th and 19th century they were building similar boats but up to 40 ft long, these had to have scarfed planks. Vaddoc
Wonderful drawings! I like the a4 box trick. In the past I struggled lining up both faces of the frame, this seems to have worked fine I ll be following from the back rows GL Vaddoc
- 168 replies
Dear all Life is so busy that I do not have any time to work on the Deben. This is likely to be the case for the next months and probably even years. Regrettably I am also struggling to keep up with the numerous logs I have been following. Still, I have been stealing some moments mostly at night, in between the girls' bath time and sleep time to work on the yawl. The results were mostly disappointing but I got to understand planking and boat building in general much better. I really wanted to get the planking done on CAD but this proved immensely difficult. I spent many evenings but I could not get it to work. It certainly will be much easier in the actual model with a few battens! I am posting some screenshots of the multiple attempts I did, trying many different ways. Some photos look great but really are not. I think the garboard is pretty close but all other planks are likely to end up with very strange shapes. This boat has a very round bow and I think this adds complexity to the planking process. It is probable that this boat absolutely would need scarfing to get the plank shape. For some reason I have a childish optimism that I will be able to get the lapstrake done. I intend to do it properly with all the bevels and nails. I ll be considerably older by then though! In any case, I concentrated in finishing the hull and frames. I really do not know how these boats were built. I suspect that they used solid wooden frames and not steam bend ribs but a superficial look in my library did not yield any results. I visited several online logs of actual boats being built and got some ideas on how to arrange the hull. It will have to be a modern version of the boat with its 19th century lines but it will have to do! I also ordered some more books but in the mean time I finished the hull with the intention of using steam bend ribs. I arranged the ribs at 2 cm intervals. Each rib will be 4 mm x 2 mm. Any of the paired ribs can becoming a 4 mm thick frame for the building and all the bevels are already defined. Note the new sheer due to the gunwale I will install, which will be 2 mm thick. There will be two cant frames at the bow and one aft. Next photo shows all of the boat's timbers Stem and false stem. These boats probably had a massive solid stem but I do not have the timber or the tools to handle such big pieces of wood. I think the stem will be solid wood and the false stem will have a laminated core and solid wood sides. The sternpost and knee will need to be pretty massive timbers and will need to be somehow built up. I have the shape and bevels of the transom but of course this will be an area I will struggle a lot. Oh well... It is necessary to have a false keel. The planking amidships will be very wide and will run almost horizontal. There will be grooves to accommodate the transom knee and stem. The keel will of course be very massive. It will be 56 cm long, 11 mm high and 8 mm thick and of course will also need to be built up. This will be actually larger than the keel of the Deben which I thought was pretty huge. A final photo of the deconstructed hull I think the boat is actually done and I cannot see any massive problems. It should be feasible to transfer to wood but in 1:10 will be a really big boy. Best wishes for the new year, health and happiness for all! Vaddoc
I have huge respect for table saws after I experienced a few kick backs from my very very underpowered proxon saw that sent pieces flying into orbit. Our faces are less than a meter away from a sharp blade spinning at thousand of RPMs! $50 is admittedly not very much but especially for this piece of machinery, I would go quality. Still, the proxon was equally cheap, equally weak but right out of the box. Thick plastic proper goggles are an absolute must using these things.
Welcome Bhupi! This is a big boy for sure but looks very nicely done. Mighty project for a first scratch build!
I have a tin pot where all sharp things go upside down. Also a small cardboard box for drilling and cutting related stuff, one for general stuff, one for sanding related stuff, one for rope making and so on...An organised chaos but tidying up is quick and when looking for something I know where to broadly look. Of course from time to time I do lose things that resurface later on.
You are having too much fun GL! Lovely boat, I like the colour combination a lot. Looking forward for the rest of the journey Vaddoc
Very nice work on the rabbet, I guess your chisels are razor sharp! Very crisp edges, I always struggle and end up with wider margins and irregular surfaces.
- 168 replies
Good news! No need for concern, the plank shape and run is fine! The computer can unroll a curved surface to give the straight surface it originated from, very useful when it comes to planks. The shapes I got were odd, and despite what the software was saying, eyeballing the hull they did not make sense. The problem was that really, CAD is very unforgiving. The hull is curved and fair but the planks are flat. I divided the hull to planks widths and asked it to unroll but this sections were curved and hollowed along their width, following the contour of the hull and not flat. This led to funny inaccurate shapes! I created a random sheer plank but made it flat this time. The result was much closer to what I expected. The plank blank now needs to be 39 cm wide which is much more feasible. Another interesting snapshot is the following, comparing my frames and sheer to the plans as given. The sheer is spot on as well as the aft frames. Note frame No 1 is identical and frame 2 and (to a lesser degree) frame 3 quite a bit different due to the errors and difficulties we discussed above. So all is good, the only minor loose end left is actually building the boat.😁 Putting all sort of disclaimers on accuracy of lofting etc, if any of you have an interest to build this boat let me know, I am happy to share these plans. Regards Vaddoc
Now I played a bit with the planking and odd shape planks come out. So odd that I now have two questions: 1. Can all boat shapes be planked? 2. For these period long boats (7 m long!), is it always one piece plank or is it common practice to scarf planks? There are other boats 35 ft long which is 11 m, so these cannot be one piece plank. The reason is that the initial tries show planks very curved at the transom end, which would need 50 cm wide blanks to come from and would have the grain running almost vertically at the aft end. This seems to happen because the hull at mid sheer runs vertically down wards before turning towards the midline and there is a pronounced curve of the sheer at each end. Looking at the NMM drawing this is indeed how the boat is drawn. More headscratching needed!
Druxey, indeed! GL, it is really not that difficult. Get any CAD, draw a dot, then another one, then connect these with a line. You 're off to a good start! The rest is improving on this! Keith, I actually do have access to a massive CNC mill but it feels a bit like cheating! I would sure like a bench top milling machine though! Bob, you are very correct, CAD (Rhino, well spotted) is very unforgiving and indeed this degree of accuracy is not necessary. I am aware that when actually cutting the wood the tolerances will be just horrible in CAD terms, nothing that sand paper or filler cannot fix. This however is a small boat so it was feasible to get all lines to work together. These guys of old, cutting wood without power tools and following some drawings where even one copy was not identical to the other...but I read that it was not unusual for ships to be a bit asymmetrical! In the end of the day, the ship has to be built! The picture you paint I think was their reality. Now I was indeed tempted to draw the planks, which would be a lot of work being a lapstrake. It is unnecessary though as I ll do the planking the old fashioned way but I will divide the hull just to get a nice run of the planks. I ll post this images later on I actually have in a couple of weeks another few days of computer time, I might be tempted to loft another boat or even something a bit larger. I ll have a look through the NMM plans. Regards Vaddoc
Well, two new things to announce. First that the hull is finished. Secondly, I discovered another mistake! This one was in front of my eyes since the beginning. Simply, the body plan lines are indeed to the inside of the skin, but all other lines are to the outside! This is dead obvious looking at the drawing. What a mess! I have drafted all lines to the inside of the skin. Still, with a plank thickness of 2 cm (so that in 1:10 would be 2 mm), the error is not significant but could explain why I had such difficulties to get the hull to work. Still, lofting the profile view to the inside of the skin instead of the outside, creates some unique new problems that I had to overcome. I will try to explain these with some images. As I have defined the inner skin, I can easily get the shape of the frames at any position. What is left is the rabbet line at the keel, the stem and sternpost. To get this line, the outer skin is needed. This was very easy to get by asking the computer to offset the inner skin by 20 mm which is the plank thickness. Now, the rabbet line (the line the outer skin meets the keel) should be horizontal at the keel. The reason is that this line is given straight and the lofting is done on this basis. But I lofted considering that the bearding line (the line the inner skin meets the keel) was straight. So the skin pivots against the bearding line and the rabbet came out curved in two planes. The next snapshots show the problem. This is the face view of the two skins, the keel area is magnified in the second snapshot Nothing I can do for the bend downwards. To level things off however, the keel surface needs to come out and meet the outer skin. So I trimmed all lines to the same level. No idea how this will work when planking but the difference is about a mm or so. I think it will be fine. In profile view, the rabbet takes a small dive but it should not be visible. The black line is horizontal and the red line is the rabbet After this there is not a lot really to do. I projected the part of the transom that meets the planking just to see the bevels and the shape of the sternpost. There should not be a need to fair the frames at all as all the bevels will be known and cut in advance. Joining the two halves with a keel 80 mm wide gives us the final boat shape with the inner and outer skins I now need to decide whether I will use steam bent ribs or solid frames. The position of the temporary molds for the lapstrake planking will be such that the same screw holes would be used for the molds and the permanent frames. I would like to leave the planks unpainted so no rogue holes allowed. This might change though. What is needed now is to finalise the shape of the stem and the transom and to figure out the positions and shapes of the frames and subsequently the positions and shapes of the molds. I ll do this when I am ready to start building this boat. A couple of cant frames will be needed as well I ve learned a lot from this exercise and I dare say I now understand boats better. The error in lofting did not change the shape of the boat significantly as it was limited only in the rabbet and also due to the small thickness of the planking. This is good as I do not think I could start over for a fourth time! Thank you all for your likes Vaddoc
Converting a Backyard Shed into a Model Workshop
vaddoc replied to Hank's topic in Modeling tools and Workshop Equipment
Depending on the type of work you ll be undertaking maybe also budget for fire extinguishers and a fire blanket ( to be placed near the exit) Some form of dust extraction/management -
Indeed a great opportunity Hank! No doubt you ll end up with a fine shipyard. You might need to revisit your lighting. I converted my single garage to a shipyard, it has brick unpainted walls and no ceiling. 5m x 3m approx. I installed what I thought was massive lighting. 4 double fittings, 5 feet each fluorescent, overall 8x52W concentrated only at the first half of the space. Not enough. I installed an extra 4 double fittings, 6ft each this time. Brighter but for the detailed work I do I could use even more. If I could paint the walls white there would be no problem. Also, it is important for light to come from all directions so there will be no shadows Vaddoc -
Dear friends After endless pains and buckets of digital ink, lofting is done (-ish)! A few pictures: I had to add 2 waterlines and one more diagonal and eventually, lofting to the waterlines was the most efficient way and only took two cycles. Now, I honestly think that there might a bit of a problem with the lines in the original drawing. Of course it is a thousand times more probable that my lofting skills are inadequate rather than the long dead builder making a mistake but I absolutely could not make the thing work in regards to frames 1 and 2. It was coming out very wrong so in the end I had to keep close to either. I chose to keep close to No 1 frame which, being the closest to the bow, should had a stronger influence in the shape of the hull. As a result, all the other foreward frames had to change a bit. Still, I am not too far off the original frame shapes. Now, this is the INNER surface of the hull. It seems this was common practice at the time which is unusual today as almost all plans give the lines to the outside skin. I now need to project new frames to the surface. The computer smooths things out by creating the surface so the new frames that will be produced will be very fair. Then I ll need to create the thickness of the planking and create the outer skin. I will also need to decide the thickness of the keel, adjust the Transom, create the bearding line etc. Tons of work! I also would like to publicly declare my huge respect to all of you that can pull something like this off without a computer! So all good so far unless I discover a catastrophic mistake. A final screenshot and to be continued!
Hope I am not too late! Great project, I ll be following. What is the massive gun in the background? Vaddoc
- 168 replies
Welcome Pannonicus! I have recently been wondering how laminated paper/cardboard might work so I would be very interested to see your work. Looking forward to your log. Regards vaddoc
Welcome Retroship! Have fun building your ship and do start a log! Vaddoc
My dear Druxey, you are very right. It is just that I cannot draw at all! I ve tried and failed miserably. Actually, my mother was a professional drawer/draftswoman for power networks long before the computer era. I have some of her ink drawings which are simply amazing as well as some of her equipment. That gene did not make it through!
