Bedford
Everything posted by Bedford
  1. That's what a sail boat should look like, lines, lines and more lines! Love it
  2. Getting all those lines tidy in one little boat is going to be an interesting challenge for you but I know you'll pull it off beautifully
  3. Great work as usual It's always hard to get the right amount of light exactly where you want it even though fluoros are the best way to light a workshop because their length helps eliminate shadows cast by you and other things. Sometimes an adjustable, relocatable lamp is the only way.
  4. Keith, the drill bit had a good run, a long and useful life. Remember it well
  5. Another master class. I was gong to suggest rolling up a sheet of variously coloured paper then cutting it
  6. Funnily enough I also discovered fishing leader wire and used it for the shrouds and stay on the "Miss Caroline" model. I used a cigarette lighter to burn the plastic coating off and this had the bonus of aging the cables somewhat, blackened a bit here, dulled a bit there. You can change the appearance by simply running the blackened cable through your fingers which gives the brighter surface and darker recesses. I'm very happy with it and it comes in a really good range of sizes.
  7. Yeah Keith, I reckon if you had the time to gather all your little manufacturing techniques together in one thread without all the other stuff it would be an invaluable practicum.
  8. Mark that looks like a very nice little row boat, very enjoyable I'd imagine and the neck flexibility, while you still have it, does semi negate the mirror but my neck got too stiff years ago. Keith, very eloquent analogy of rowing and life. At the moment it definitely feels like we've only got one oar and it's called corona! Thanks for your compliments on my little boat and I'm happy it gave you good memories, that is after all the reason we build these things.
  9. Hi Mark Yeah I've wanted to get some rowing in but I've got a bit of work to do on the transom first so about a week before I can. The mirror is right about eye level so is easy to look at and gives really good coverage. What are you rowing? If you want any details on the mirror etc get in touch, I think you've got my number.
  10. I've been using a rowing mirror supported on a "Tablet stand" with a flex neck and clamp base. Effective but wobbly and ugly. Now with all this time on my hands I've made a much nicer replacement using the same mirror and tablet cradle and retaining the ball joint from the original. I was able to cut the ball joint from the flex shaft, centre drill it and turn a 5mm diameter nut to go into a pre-existing lateral hole in the ball. I cross drilled and tapped the nut to 3mm then turned a screw and washer to attach it all to the new spruce post which sits in the inwhale spaces so I can move it to wherever I want it.
  11. You're all wrong, as my dear departed mum used to say "It's a wigwam for a gooses bridle"
  12. OK now I'll come clean, I sent Keith a PM after my previous post saying I didn't really know what it was I was just stirring the pot to promote the mystery of it. Although I did have an idea because I know how Keith did the cradle for Altair, it's his style.
  13. Some really nice work there mate If you're waiting for a heat gun to use on the heatshrink there are other ways to shrink it. A hair dryer works well as does a cigarette lighter, just keep a bit of distance between the lighter and the job. It doesn't take a lot of heat but you want to spread it around the tube so it shrinks evenly
  14. It's obvious what he's doing, I'm surprised you can't see it. I won't spoil his fun though!
  15. Absolutely beautiful my friend, don't rush into town on our account.
  16. Mark, the windlass on Waratah has gypsies for the anchor chain and similar brakes though the axis is on the horizontal, the brake is manually adjusted as the anchor is lowered so yes someone has to stand there and effect a controlled descent of the anchor
  17. Now I know how to make what we call a gypsy for the anchor chain, thanks!
  18. John, the SHF shipyard is closed for the duration, no cruises either because it is run by volunteers and most are in the senior age group most at risk
  19. I'd follow a loco thread Michael As for covid, the Sydney Heritage Fleet shipyard has been closed down and all cruises cancelled because most of the volunteers are of an age deemed susceptible
  20. Keith, further to Druxeys comment, there is an old wood turning trick whereby you glue the quadrants together with paper in between then after turning it a sharp knife can be used to separate the pieces. Clearly you loose half the thickness of the paper from each face but that would not be noticeable in most cases.
  21. Love the oars Geert, I wouldn't have minded if you copied the leathering, that's what the site is about. Learning from each other, getting ideas from each other etc. Having said that, I do like the darkened rope on your oars.
  22. Yeah Keith, I'm replacing the broken drills with 10 packs. The HSS ones Eberhard mentioned would be great but I haven't found any and these are cheap. As for work holding I still have patience to learn in that area, I'll always try the quick easy way first but I can generally tell when I need to go the long route before I start something.
  23. Yeah Eberhard I considered making something better to hold the pins but I only needed 6 and have about 500 to work with. I'll have to keep my eyes open for better HSS drills but these are cheap and plentiful
  24. I got a set of micro drills last week and they've been very handy despite the steep learning curve using such fine drills in a machine, I broke the 0.3mm while getting the 0.4mm out! I cross drilled three of the 0.8mm pins with the 0.4mm bit before it snapped on the way out after drilling the hole, I think a bit of swarf came up with the drill and jammed it. I had to drill the remaining three holes with the 0.5mm bit which required very accurate centering leaving only 0.15mm either side of the hole. I couldn't hold the pins in a collet because I haven't got one small enough so I just clamped them in the machine vice and then used the 1mm bit to start the hole to prevent the smaller drill running off the side of the pin and breaking. The wire I used to put through the pin is 0.3mm diameter The pins were cut just past the holes
