justsayrow
Members-
Everything posted by justsayrow
Drawing with quota, exist?
justsayrow replied to Jhenrique's topic in CAD and 3D Modelling/Drafting Plans with Software
Jhenrique, I don't think you will find what you are seeking. I am a professional Naval Architect and shipbuilder. The last vessel I built had a drawing package of approximately 15,000 documents ranging from 1 to several hundred sheets or pages each. Simply too much data to present as a single drawing. Classic vessels were typical built by craftsmen working off physical models and rules of thumb. Then came lofting & molding of templates off tables of offsets. Now numeric models feed directly into automated cutters that nest as many parts as possible from a single plate. Often, layout instructions are burned directly onto the pieces. R/ Jerry -
The vessel in question has four signal flags flying. May be her call sign. Can't read them on my small screen though. Any one on a full monitor make them out? Might get info from google then.
Rookie needs help!
justsayrow replied to twebb's topic in CAD and 3D Modelling/Drafting Plans with Software
Ted, check out http://www.hnsa.org/resources/manuals-documents/booklets-of-general-plans-online/ They have one set of lines: for BB-45 COLORADO. A lot of other plans that you might reverse engineering into lines plans once you're dialed in. r/ Jerry -
Ben, great log. I will keep tabs on this one. I'm a Michigan NA&ME grad so the Fitz is near and dear to me. Andy's (reference Jan's post above) screen name is realworkingsailor, though as of last I knew he crossed the brow and is working in the office. A fellow alum of yours, Pete Jaquith, has several build log on here. His work is simply fantastic. Highly recommend doing a search for his work - he brings his real world shipbuilding experience to bear in miniature. Very cool stuff. R/ Jerry
- 40 replies
- edmund fitzgerald
- iron shipwrights
Jeweler's Tap and Die
justsayrow replied to Landlocked123's topic in Modeling tools and Workshop Equipment
http://en.m.wikipedia.org/wiki/List_of_drill_and_tap_sizes When cutting the threads, go slow. 1/4 turn in, 1/8 turn out. Go slow. Use cutting fluid. Not sure if I mentioned it, but GO SLOW! You will break taps. -
Tim, your build really illustrates how breaking a model up into finely executed sub assemblies which are then brought together makes for a great piece. Love following this build!
- 144 replies
- basilone
- BlueJacket Shipcrafters
Cutting Board question
justsayrow replied to hornet's topic in Modeling tools and Workshop Equipment
If you do head to Hobby Lobby, they have a standing coupon for 40% one item on their website and mobile app. $30 becomes $18. -
Scroll saw operation
justsayrow replied to bigcreekdad's topic in Modeling tools and Workshop Equipment
BCD, What's the teeth per inch on yr blades? -
Is there a better #11 blade handle
justsayrow replied to roach101761's topic in Modeling tools and Workshop Equipment
Jay, Not sure where you got that particular one but I picked up one that looks just like it at Harbor Freight yesterday. It's in a "deluxe hobby knife kit" with three other holders and about 25 types of blades. It's on sale at mine for $14 USD. Don't think the blades will last long, good aftermarket blades are readily available. I particularly like the little rubber nubbin on the side that keeps it from rolling off the bench into ones foot! Jerry -
Please YES! to a log! This is a kit I've been interested in building. Maybe use instant set CA to accelerate the build and hold manually?
Grant, Far and away my favorite kit to build! You are tackling my big regret from my build: the gauges. Good luck! Jerry
- 339 replies
- dumas
- Chris-Craft
(and 3 more)
Dafi is causing my Heller Victory to remain on the shelf for the time being... I hope he know the consternation he causes!!! :im Not Worthy:
- 1,319 replies
- caldercraft
- Victory
IJN Fuso (Halinski) Card Model Review by Captain Slog
justsayrow replied to Captain Slog's topic in Card and Paper Models
Bill, you beat me to it - I was going to mention Doris' work! -
Rigging Tension-how do you do it?
justsayrow replied to capnharv2's topic in Masting, rigging and sails
Harvey, "by feel" is easy to type and hard to describe. One thing to keep in mind, would be interested to hear other's experiences, is keep in mind the temp and humidity when you're doing the rigging. In Houston, we get some wide swings in temp and humidity through the year and I can see spars move. If you make it tight when its hot and moist (Houston summers bless us with "air you can wear" it's so humid), come winter when it's dry and cool, the lines will really sing and pull things out of alignment. waxing the line before rigging helps a lot from humidity standpoint, still moves a bit with temperature changes. best teacher is experiment.... take some scrap, buy a dowel and fiddle with tying knots to gauge how tight you can make things. r/ Jerry -
Andy, think about not gluing the mast in - the rigging should hold it securely in place and lets you avoid having to hit it on the first shot.
- 188 replies
- constitution
- mamoli
