pete48
Everything posted by pete48
  1. Looks good J , Nice workmanship Best Regards, Pete
  2. Thanks Omega, I am thinking that she will sail beautifuly , I would like to do one R.C, I will have to bump up the scale to at least 1" = 1' - 0 " Thanks Jay ,She's getting closer , I am going to start making cleats and blocks , I can't wait to see her sail Best Regards, Pete
  3. Hi Nils, She is looking great , Beautiful work Best Regard, Pete
  4. Thank you Geoff , She passed with flying colors Hi Omege, She is a bit to small for radio gear , so I will let her free sail Thank you Michael, I am thinking a light weight rip-stop nylon ( white) Best Regards, Pete
  5. Today, I finally got the Hull Painted,( it took 2 days & sanding her back to wood twice) I went with a semi-gloss white . (3 coats ) I also detailed the seats and cockpit floor.I then Stained and applied 3 coats of varnish. Here are the results
  6. Thank you Geoff, She is starting to get her shape back Thank you David, I appreciate your kind words Best Regards, Pete
  7. Today , While paint was drying on the 12 1/2, I decided to do some tank testing . I used small fishing weights ( the round ones ) filled the bilge where the lead for the Keel is . Then I put her in the water tank ( kitchen sink ) The water line is right on the money, This boat has been a pleasure to build . Here are the results
  8. Today, I was able to get the boat back in primer ( 3 coats ) before the rain came . I also sprayed the cockpit a flat white. she is back to where she was before the incident. ( whew ) here are the results
  9. Michael, the green one is attractive , I can look at them all day Hi Dave, The Herreshoff boats are quite amazing , I would like to have one as well. I grew up Sailing, it is a great pastime. I highly recomend you try it Best Regards, Pete
  10. Hi Nils, I agree this size boat is perfect for day Sailing, and she can be singlehanded wich is a big bonus ( my Wife does not always want to go Sailing ) I would Sail everyday if I could, ( and to me this would be the boat to have ) I have been fortunate to Sail a few of the these, and you cant beat a full keel for directionality ( they track very well ) and no weather helm . One of the most beautifull boats I have ever seen, or have had the privilege to Sail Best Regards, Pete
  11. Hi Michael, the gun Carriages look great , I would make all 6 and choose the best 3 . Beautifully done nice work Best Regards, Pete
  12. Hi Nils, To the best of my knowledege , None of the Herreshoff boats built thru Herreshoff Mfg.Co or Cape Cod Shipbuilding , have been built in a Clinker . However a Company called Brooks Boats Designs, came up with a version of the 12 1/2, that boat is done clinker-built. here are a few photos Best Regards, Pete
  13. Thank You , Geoff, It was a great learning experience, I was not sure at first if she could be repaired Thank You Jay, It was heart wrenching , fortunatly, the repairs to the hull will be covered with paint. The trickey part was where the Cockpit coamings meet the Transom , in the second photo you can see the line in the coaming ( port stern ) I think thats the only thing that is going to be noticable. Thank You David B., It was rather unfortunate , However I was able to upgrade the transom ,with the birch ply Thank You Piet, Stuff does happen from time to time that is out of your hands . I think how you handle it determines the outcome . Thank You Dave , I appreciate it . I think she came back together rather nicely, I am going to re-primer the hull today Thank You Michael, it ended up working out pretty good . I think the Birch on the transom is a great upgrade In this Photo, you can see the repair where the hull meets the Transom Best Regards, Pete
  14. Hi Nils, Beautiful work, excellent craftsmanship. Best Regards, Pete
  15. Yesterday morning was Brutal, the 12 1/2 fell from a high spot breaking the Transom off. And causing damage to the Starboard side Bow area in front of frame 3 to frame 2 . so the repair work began , by cutting back the remaining part of the Transom square, so that a new piece could be sandwiched in between 2 pieces of Birch Ply. ( to give it more strength ) I then glued some scrap pieces of planking material , to fill in the hull . Next, I re faired the hull . I then re-shaped the Cockpit coamings ( they were to tall ) I then Stained the Transom and Cockpit Coamings. I then Applied 3 coats of varnish. Here are the results
  16. Nice Work Popeye, the 3 Hulls look Fantastic Best Regards, Pete
  17. Nice work Nils, Nice to see how you got the blocks ready , Best Regards, Pete
  18. And here is the rest of the pic's , I had alot to choose from. the seat's are held in position by wood wedges
  19. Today , I was able to get alot of work done on the 12 1/2. Starting with re shaping the Transom so that it rolls over the top , I then cut out all the seat braces and cut the frames down to more resemble Ribs. I then made the cockpit Coamings soaked them in alcohol , installed them, sanded them, and finaly stained them ( I stained the Transom at the same time ) . I also made the Cockpit Floor and Aft seat ( wich I had previously made templates for) I was very pleased with the results . Next will be to varnish the Transom and Coamings . Here are the results
  20. Beautiful work Marisstella, I had forgotten about this build . you sure stay busy, Looks fantastic Best Regards, Pete
