pete48
Everything posted by pete48
  1. Hello Marisstella, The Planking looks great, Beautiful Job. Very nice looking Hull Best Regards, Pete
  2. Hi Michael, I look forward to it Best Regards, Pete
  3. Your welcome Jay , About the Seats it's a optical illusion due to different curves and shadows ( I could see what you were seeing as well )the seat's are actually flat . heres another shot , look on the port side where the seat meets the bulkhead , and then you can see the shadow effect on the starboard side . pretty cool effect though. Thank you Geoff , I appreciate it Best Regards, Pete
  4. Today, I started by laying out the deck . I then cut the deck out and installed it, After that I faired the deck in with the Hull. Next I cut the frames to match the deck line,( as they would have been to fragile to cut in the begining ) I then started to make templates for the cockpit seats, floor, and rear seat. I am pleased with how she is starting to come together, and starting to look more like the 12 1/2 . Here are the results
  5. Looks great Matti, nice job on the bowsprit mast Best Regards, Pete
  6. After looking at the boat last night, I realized that the fairing was not complete. So I started the day by cutting in the Sheer , then spent about 5 hours completing the fairing of the hull . Now it looks more like Capn' Nate's 12 1/2 . This taught me that I will need to re loft my Profile drawing. here are the results
  7. Nicely done J , it looks sweet the Oars look great , well put together Best Regards, Pete
  8. It looks good Michael, clamping in tight spots can be a real pain Best Regards, Pete
  9. So true Tom, I am constantly learning new things , thats the beauty of this hobby Best Regards, Pete
  10. Nice job on the planking,it looks great, she is starting to take shape, well done Best Regards, Pete
  11. Hi Nigel, The deck looks Awesome ( nice caulking job) beautifully done Best Regards, Pete
  12. Today, The weather was not going to let me Varnish the brightwork on the Buzzards Bay 14ftr.So I thought it would be a good day to work on the 12 1/2, First I made the cradlle, the same way I made one for the Buzzards Bay. Then I did more Fairing on the Hull. ( fairing is just about finished ) Next will be to epoxy the inside of the Hull , with West System .( this way I have the option to Sail Her) here are the results
  13. Hi Nils, Looks Fantastic, beautiful work , nicely done Best Regards, Pete
  14. Hi Bob, Looks like you will have to set up a production line , for all the hoops and pins . Best Regards, Pete
  15. Beautiful work Grant, The deck is incredible Best Regards, Pete
  16. The Planking looks good Tom, 10 yrds of topsoil should keep you busy, you must have decent weather there, its Raining here Best Regards, Pete
  17. Hi Michael, beautiful job on the quarter deck, I am curious as well Best Regards, Pete
  18. Thanks Russ, She is comming together , I am pleased with the color scheme, and how the bright work came out Thanks Bob ( Hexnut ) right on, lets go sailing Best Regards, Pete
  19. Today, I started by fixing the Cockpit Coamings there were a few high spots that needed to be sanded . I then applied another coat of stain on them.( I am glad that I added the 2and coat ) While the Coamings were drying, I turned my attention to the Rudder, and Making the Tiller. I first cut some 3/32" birch ply to match the top of the Rudder, I then cut out the slot for wich the tiller goes in , Then glued the ply to the top on both sides of the Rudder, This then gave me the 1 1/2 " ( Scale) square in wich the Tiller fits. I then cut my 1 1/2" ( Scale) square stock to length. I then shaped it so that it has the ball end , I then soaked it in rubbing alcohol and bent the curve in . Here are the results . I used my sanding block to hold the rudder in position for the pics, Next will be to shape the Rudder Blade below the waterline
  20. Thank you Piet , now I am at a loss for words ( it must be contagious ) she is attractive Best Regards, Pete
