mtaylor
Moderators
Everything posted by mtaylor
  1. I'm puzzled, Dennis. Why can't you call this bird "Old Glory"? The link you posted is only about 1-2 flags. Many folks call the flag "Old Glory". Maybe some research will give some idea of what your plane was actually named.
  2. Glenn, thanks for leading us mere mortals You're doing a great job.
  3. Try running this search as it shows build logs and questions about this model. Some related to rigging. https://modelshipworld.com/search/?q=occre corsair&quick=1 Also, give some thought to doing a build log of your own. A short intro to bring it up to date and then carry on. It's a great way to get help and also meet other builders.
  4. Well, the bar serves a dual purpose. That's my excuse and I'm sticking with it. Thanks Gregory. I think I have it sorted. Right now waiting for glue to dry before checking.
  5. Hi John, Two place that might be better on asking about your Gondola.... https://modelshipworld.com/forum/13-discussions-for-ships-plans-and-project-research-general-research-on-specific-vessels-and-ship-types/ for general non-CAD discussion and then here if about CAD: https://modelshipworld.com/forum/34-cad-and-3d-modellingdrafting-plans-with-software/
  6. I really see no need for large power tools on this model as I'm pretty much building it "out of the box". If rigging, maybe a lathe for the masts but those can also be done by hand but I'm thinking only stub masts on this one.
  7. Kevin, no worries. Always seats... did I mention the balcony? Not the first time I've done that Bob, and probably not the last. But it's part of what I need to do for me. I feel like how to build a model is coming back to me. Well, I did step 72, the one I missed...<sigh> and did it and also faired the top of the bulkheads. Re-glued one down as the glue/water mix I was using didn't hold. A true comedy of errors but no real harm done.
  8. Welcome to MSW, Mark. Looks to be an interesting build. BTW, I would suggest you open a topic in the New Member Introductions to let folks know you're here and what you're planning.
  9. Perhaps you "personalize" the faces, OC. Give some a mustache or a beard? If they Irish in the ranks, maybe some red hair...? I'll go quietly off now......
  10. Thanks Glenn. I just realized that somehow I missed 72. Thus, stern part of the deck wasn't seating. I'll go stand in the dummy corner for a bit.
  11. I will. I looked at Glenn's log and he didn't mention it. Edit.. I found that one and the solution was to check, double check and check again. Headed to the shop.
  12. As for the build a bit of head scratching. My deck patterns (44 and 45) seem too wide and are not flush along the centerline. A bit of overlap maybe <1mm. I'll do some more test fitting and if need be, a bit if fettling with the notches where they connect with the frames. Note, the lower deck for the hold was a perfect fit.
  13. Dave, welcome to my circus.... I'm feeling like the head clown today. If questions are related to this build, feel free to ask here. Otherwise, PM is fine and also there are all the subforums too.
  14. Thanks OC. It is getting stronger but I still wouldn't want to drop it.
  15. Bitao, makes a good point, shonezmija. Don't compare to others but look at them as goals. It's a process to get there. And start "small" scratchbuilding. Maybe a kit with as many of the parts as you can made from scratch. There's no rush and no pressure. For all but a few, this is a hobby.
  16. Very well done and quite a beautiful slope. Congratulations.
  17. Thanks for the likes and comments. Small update but moving along.. I made and added the coamings and gratings over their respective openings. Also added gundeck support beams and the beams themselves. So far, so good, and I"m a happy camper. Really starting to like a ship. Tomorrow I'll work on the stern and with a bit of luck and no distractions maybe get the gun deck foundation in place. Quite a bit of work between those bits and getting the gundeck veneer installed.
  18. If it's actually boxwood it's a good price. Not sure who Woosteel is or where they're located (no info on Amazon).
  19. Almost too perfect. I saw the photos before reading the text and thought they were the real thing.
  20. You might post your location as location is factor with shipping, customs, etc.
  21. Welcome to MSW. Do tell us a little about yourself as there might be members in your area. Also, post some photos so we understand the problem.
  22. I didn't do much in shaping the bow and stern but I think for me mentally (yes I"m obviously mental) it'll be better to shape at the time I sand prior to planking. I did get the bow, stern, deck, and the gun port frames mounted. Probably would have had more done but had to buy groceries and deal with apartment issues.
  23. Since this appears to be a kit and not a scratch build, I moved it. If it's just the Sterling plans, let me know and I'll move it back.
