Everything posted by mtaylor
"Splice the mainbrace, me hearties!"
mtaylor replied to Renown1980's topic in New member Introductions
Welcome to MSB, Stuart. -
Hello Ruud, welcome to MSW. For planking, have a look at the tutorials here: https://modelshipworld.com/forum/98-planking-downloads-and-tutorials-and-videos/ I suggest looking/reading/watching all of them and then pick one to use. Also, do start a log as it's one the best ways to get help.
There's the old saying that "It's a poor craftsman who blames his tools." A lot of truth in that.
Welcome to MSW. I can't add to what the others have said but only say.... they gave excellent advice. When you start the Ballahoo, do a log and above all, enjoy the process from start to finish.
HH60-J Jayhawk by Jack12477 - FINISHED - 1:72 - PLASTIC
mtaylor replied to Jack12477's topic in Completed non-ship models
Beautifully don, Jack. Looking forward to the next one. -
Hi Michael, welcome to MSW. Do give some thought to opening a build log as it's a great way to meet other builders and get help when you need it.
Hello from the little town of Woodland Washington
mtaylor replied to Roberts Orca's topic in New member Introductions
Welcome to MSW, Robert. As others have said, do start a build log. It's the best way to meet other builders and also to get help when you need it. -
You might give some consideration to drilling some air holes in the wood. I have dremel like tools and there are chucks that go down to almost nothing for a hole size. Mine are old so I have no idea if they're still available. Inside the hull is tough and the smaller the model, the harder it is to sand. I don't know of a perfect solution to that.
- 968 replies
- hahn
- oliver cromwell
Have you looked at the other build logs for Bounty by the same kit maker? That's actually a very good starting place to find out what others have done.
Nice work on the those two water casks, Keith. They almost remind me of a beer cooler for some reason. Must be the holidays... LOL. I hope your have a great Holiday period.
Great to see you back and at the bench, Hakan. Old habits are hard to break, like keeping the work area spotless.
Hi Druxey, I'm using Swiss Pear wood. As for the bending method... due to thickness I've found basically that the planks must soak for several hours. I then use Chuck's method of clamping the piece to some scrap plywood and hitting it with a heat gun, moving it constantly to dry the wood for about 10 minutes or so. Then let it cool. I've found it takes the better part of the day to sit as anything less then about 5 hours leaves center still damp. On that note, the upper wale (and the thickest) is on and the glue is drying. For the hull below the wales, the planks are thinned out some and tapered eventually to the final thickness I think I posted a copy of the cross-section that shows this. So unless there's outside distractions, planking should pick up speed. I found that in order to get the top wale in position (it's the key to the rest of the hull planking) I needed to identify accurately the wale location. I did this by printing out the Hull Plan and cutting it up. There's a line that not's mentioned in the text but it's the top of the wale so I cut the plans, taped it to the side using the gunports as a reference and marked up the hull. I then put the wale planks in place. Three long planks per side. The most troublesome part was getting the bow plank fitted. It needs to be bent in two directions and also as a small twist. Here's some photos of the process. Note that I've not done any cleanup work. I still need to blend in the joins on the planks and some shaping. At some point I'll pull back further and get the whole hull in a pic. Things still look pretty ugly but then, like my Dad used to say about Corned Beef.... you really don't want to see it being made...
It's great to see you back, Mike. I love that mini-drill. My only question is how hot does it get inside the wood housing? I hate to hear that the motor got too hot and burned up.
- 968 replies
- hahn
- oliver cromwell
Welcome to MSW, Arthur. Lovely boat sitting there, and certainly something to be proud of. When you're ready to start your new ship, do start a build log in the kit as it's a great way to get help and meet people.
Thanks gentlemen. I'm slowly making progress. Once the first line of wales is done I'll post pics. I think I got it right this time, but it did cost me some hair that I pulled out. It's taking more then I expected to bend and shape a piece of wood that roughly 1/4" wide and 1/8th inch thick. But I'm patient. Bruce, I think this is only POB monograph ANCRE did but I know it was one of the first. Always room for one more.
