Everything posted by mtaylor
Welcome to MSW. By all means open log. It's the best way to get help and also meet other builders.
Sorry to hear about the family getting sick. Take care of yourself while caring for them. As for the blackening.... You can use Birchwood Casey Brass Black. Works very well.
- 261 replies
- Victory Models
- Pegasus
(and 3 more)
Beautiful work, Glen. That model and surroundings inside look fantastic.
- 174 replies
- Waa Kaulua
- bottle
Ferrari 312t by kpnuts - Revell - 1/12 - PLASTIC
mtaylor replied to kpnuts's topic in Completed non-ship models
Your last 4 pictures are "HEIC' and didn't post. Can you re-post them as JPG's? -
Lovely model and very well done. As for the rope problem, paint them with a bit of 50-50 white glue and water. A small pointy stick (metal or plastic not wood) will hold the shape until the glue/water mixture dries.
- 61 replies
- ancre
- Santa Caterina
Ah.... yes, the French did line the insides of their stoves and ovens with brick. It was held in place with iron straps. They also often covered the outside (but not always) with wood. The iron iron straps did that. I'll have to dig through. IF anyone has a copy of Frolich's The Art of Ship Modeling, have a look at pages 122-123. Not all their galleys (stoves) were like this. For example my Licorne had an oven and a different type of stove (galley) If I can get my scanner to fire up (it's been a bit fussy lately) I'll scan the stove from the Belle Poule.
Retrofit ship columns
mtaylor replied to snedley22's topic in Building, Framing, Planking and plating a ships hull and deck
There are ways to work around this. Some just us an electric drill and using sanding sticks "free carve" the pieces. Others jig up the drill using plywood and make a lathe. While it's not easy to figure out how to make up a drill stand to use it as a mill, it seems to work. Many moons ago I used a drill to turn cannon as didn't have a lathe. It worked but it was a pain to do and use. -
Welcome to MSW, James. The others have given some great advice. If you havent' done so, read the tu;torials here: https://modelshipworld.com/forum/98-planking-downloads-and-tutorials-and-videos/ As a side note, I find using sanding sticks such as those found in beau;ty supply shops for nails to work a treat for fairing.
You might want to do some testing using FireFox if it will run on a phone. The Edge browser uses Google code for it's behind the scenes software and it may start having the same issues. Hopefully, Google/Samsong will sort out their issues. Iit's possible, I think, that Samsung is the problem with their driver so hopefully, they can fix it.
Now that I think of it, we have had some couples building models even just one is doing some odds and ends.
