MrBlueJacket
Everything posted by MrBlueJacket
  1. Nothing looks better than even battens. We are now putting them in the Bowdoin, Pauline, and Charles Notman. And the Wyoming when it is finished.
  2. by all means do a build log of your Swampscott dory. When you finish, I will give you a 10% discount on the next kit you buy from us.
  3. Yes, that would be interesting - Justin is a good friend of mine. However, my purpose is to make a display model for our gallery. It will have a water base, but not a real diorama.
  4. I should show you what I'm replacing. Damage you can see, and things like the caprail is half unglued, etc.
  5. First item is to fill some tiny holes in the hull casting. Most of what you see will be sanded off.
  6. Our Wendameen display model is really getting, shall I say, tattered. It was never cased and 20+ years of being exposed really shows. So I'm going to build another one to replace it. I didn't bother with the whole kit, nor did I take any rigging, wire, or eyebolts because I have plenty. Here's the rest of the kit contents. First, the plans Next comes the hull, laser-cut caprail, and the fittings. FInally, the wood package
  7. Hi Josh, The hinges are cast pieces. They look like this and you will need to bend them into hinge shape. Nic
  8. Bend the traveller to shape and trial fit into the holes. Then dip the ends into CA and insert.
  9. BlueJacket has the lobsters. They are Britannia castings, 1/2" scale. i painted them in Army Helo Drab, then dry-brushed flat red. Followed by gloss clear.
  10. Very credible job, Nathan. A little putty and you'll have a fine hull. I can recommend these fillers: Auto glazing putty Bondo Wall spackle plaster if Paris I would stay away from carpenter's fillers, they dry too hard to sane evenly with the softer basswood. Nic PS - nice to see you last week.
  11. Actually, there is a 4th option - re-cut the handles. But being so delicate, I didn't want to risk it. So my option #3 is to put the end of the oars somewhere where it is not easy to see that the handles are missing, like under a thwart.
  12. Did I say they are delicate? While sanding them, two handles broke off. This leads me to several choices: 1- get more lasered oars (advantage of working here) 2- only show 2 oars on the boat 3-get creative and find a way to hide the error I'm deciding on #3. I think it will work.
  13. Next comes the oars. They are lasered in 1/16" basswood, and are very delicate. Raw piece and sanded piece.
  14. Now for the thole pins. I'm making them from .020 brass rod. First, I cut them long and install them through the caprail. Next step is to trim them to length. I'm using a 1/16" x 1/8" scrap of wood as the guide. And here's the trimmed thole pins.
