Posts posted by Old Collingwood
- Canute, popeye the sailor, Nirvana and 9 others
- 12
Looking very tidy Mike.
OC.
- lmagna, mtaylor, popeye the sailor and 3 others
- 6
This has so inspired me with my Waterloo dio I hope to start around christmas time, superb building skills.
OC.
Evening all, a bit more progress today - I am managing one figure per day, project today was an other ERK, this chap is carrying a Jerry can, I had to do a little bit of fettling as the kit way was just to glue the can onto the bottom of the hand - but I thought that looked silly, so I cut the middle bar out of the handle but just left a bit of it showing, then I pushed the hand lower in between the handle and glued it there, this way it looks like he is actually carrying it.
OC.
- popeye the sailor, Egilman, Canute and 5 others
- 8
41 minutes ago, lmagna said:
I think you may be thinking of the American dive bomber the SBD Dauntlas.
I ment this Lou - The Junkers Ju-87 or Stuka (from Sturzkampfflugzeug, “dive bomber”) I put in the initials my self.
OC.
- Canute, popeye the sailor and mtaylor
- 3
Wasn't it mainly refered to as S.D.B Stuka Dive Bomber.
OC.
- Canute, popeye the sailor, Egilman and 1 other
- 4
Thank you EG for further clearing that up, it wont be an issue as there is enough going on to keep the Dio busy, so one table will not be missed.
OC.
5 minutes ago, lmagna said:
They probably didn't even have a hanger! A few days here and a few days there and retreat again. Remember France didn't last long after the "Phony War".
I see, so the bench is probably not for Mossie use or use on a normal base with full facilities?
OC.
- Edwardkenway, mtaylor, Canute and 1 other
- 4
Just now, lmagna said:
I could certainly be wrong OC, but the picture looks like an almost primitive forward operational field, possibly in N. Africa or someplace. Almost certainly not in the UK. Under those circumstances working outside on the flight line would probably be much more common. The tent in the background is probably "home" and is the most advanced structure in a hundred miles!
Thanks Lou, with the bench being uncertain it could always be left out of the Dio, it does seem puzzling to me why this stage would not have been done in preperation for flight (probably many many boxes of them) in the hanger.
OC.
- Jack12477, Canute, Edwardkenway and 2 others
- 5
I have found this pic on the net showing one of the ammo tables - lookes like ammo belts were made uisng the device on the bench before putting into magazines/box.
Perhaps the device connects a row of loose bullets onto a feed system?
Not relavent to Mossie but could have been for a Mossie Fighter/bomber or Spit on the field at the time (hence why its put in the back of the jeeps trailor - been picked up or dropping off near a Spit)
OC.
- Canute, Edwardkenway, Jack12477 and 2 others
- 5
Good start Denis.
OC.
- Canute, mtaylor, popeye the sailor and 2 others
- 5
- marktiedens, Canute, Egilman and 6 others
- 9
11 hours ago, Egilman said:
They had two different crank devices for dealing with machine gun ammo, one made up the belts, (which is what that one looks like) and one to load the belts in the magazines that were not removable from the aircraft...
They would have several of those at the airfield my friend, but it wouldn't be in a trailer on the back of a jeep....
EG
Thank you for explaining that, I was confused about the bench, so I thought best to just pop it in the trailor - like its just being taken back to the hanger.
OC.
- Egilman, mtaylor, Edwardkenway and 2 others
- 5
22 minutes ago, Kevin said:
lovely work, its going to be a very fitting tribute
Thank you kindly Kevin, I appreciate that.
OC.
- popeye the sailor, Kevin, mtaylor and 5 others
- 8
3 minutes ago, mtaylor said:
It's the fiddly bits that make us pull our hair out or what remains of our hair.
Wouldn't that loading table have been in the armory or at least a hanger? I would think that on flight line, there would be lots of dust and/or rain.
I'm not sure Mark, I have seen photos where they are re-arming out on the field, I assumed it was something to do with that.
OC.
I foregot to mention, I have also been battling with a fiddly little thing in the shape of an extinguisher frame to support Two bottles, these need to be built up using the two sides first and held in place by a cross pole, would it stay in place and glue - not a chance, it kept falling away, anyway after about Ten Million tries I eventualy got it to stick enough to attach the top handle and bottom section.
I then left it well alone to set.
OC.
16 hours ago, cog said:
Don't indulge on the diet products (like diet sodas), neither your body nor your nervous system do respond to well to a lot of artificial sweetners. It actually is quite a list.
How is the last part of cleaning moving along?
Yep and Aspartame is actually not very good for you.
OC.
- popeye the sailor, lmagna, Canute and 2 others
- 5
6 minutes ago, popeye the sailor said:
you've made some great progress OC.......jeep and equipment look super figures are coming along really nice as well!
Thank you kindly Denis, with the work bench - I assume that is what the vice/ammo feed device was for?
OC.
Evening all, a small amount of poregress - I have built the ammu bench, its designed I assume to put the ammunition onto belts ready to be fed into the wings in Spits and under the belly in Mossie fighter/bombers, so I have decided to pack it in the trailor as it been kept there while the crew have been dropped off.
OC.
- mtaylor, popeye the sailor, lmagna and 7 others
- 10
Black Pearl by Old Collingwood - FINISHED - 1/72 Scale
Thank You kindly for the nice words Jack,
I contacted Revell and they sent me out a new figurehead of the lady, but if you get this kit of the Pearl from Revell it has the Lady figurehead in it - https://www.revell.de/en/products/modelmaking/ships/sailings-ships/black-pearl.html
OC.
