Right then folks "Take a seat and enjoy the show" here is the Dio - We start off with my dad chatting with his superior about a sticking Flap At the same time "Number Two" is making his way to the plane after giving the bases dog some attention, The jeep is from were the Two mossie pilots is still on the pan with the dog waving its tail. A spit is brought over as my dad had a quick look over her before working on the mossie. And at the same time one of my dads work friends walk carrying a gas can for the jeep. And here is the general over head scene - And I finish with the dio put on display in my unit with friends. Thank You all for all the convos - help and likes it has been a fun build made even better by some suprises. OC.
Just a bit of tools logic - do you know what makes a great ca applicator - a piece of fuse wire, you drop a small pool of ca into a tub/vessel then just dab the end of the fuse wire into it just enough to pick up a small amount then apply this where you want, just repeate as needed, its what I do for all things that need controled application. OC.
Evening all, A bit more work on this today, first I fitted (tried to fit about Fifty times) the outer wing fence - they are wafer thin pe pieces almost to tiny to pick up, but I managed in the end by placing them and not breathing till I could put a bit of ca glue along both edges, after doing that and exhailing I turned my attention to the stabilizers, these have plates that glue to the edge and these are then glued in place on the airframe. OC.
Evening all, I got a bit more work done on this today - firstly after studying my pics and looking at my Shar I thought there was a bad molding fault with it, near the left hand wing root there is a curved hole - I am not aware of this on the real aircraft, but after checking the instructions I found a curved part that pops into that hole, I think it might have been the auxiliary refueling probe that some harrier could/would use. This was soon rectified and I moved on to an area that was bugging me - on the top near the rear cockpit area that patch I had fitted (I didn't like it) so I sanded if off and worked the area till it was smooth. Next was to work on the flaps and ailerons, these are seperate items seperated by the venting tube, the outer ailerons I glued in the trimed position, but the flaps I partialy drooped. OC.
