Old Collingwood
Posts posted by Old Collingwood
  1. 7 minutes ago, Egilman said:
    Kevin, Yeah I checked out Alclad thoroughly before rejecting it, there are easier ways I found out. I also checked out the various metallic paints and bare metal foil, most of which require an airbrush to apply which I don't have... I was looking for an easy way to apply metal finish that works for a rattle can guy..... Easy is always better IMHO... {chuckle}
    Ken, I know that for sprayed on metal finishes a perfect High Gloss black finish is the key to the sprayed on bare metal finishes. I'm not doing a spray on finish. and the undercoat can be any shade or grade I want it to be... I have to make a few tests first before I go to apply the finish to find the best base coat. But once I do that I will cover it in detail as I apply it to the model....... What I'm going to do is supposed to be so easy that anyone can do a bare metal finish even if they have never done one before....
    The afterburner exhaust on the engine picture above (previous post) is burnt iron over brushed gloss black. I'm going to do it again in steel cause the iron looks nice but it a bit too dark.....
    This is going to be a learning experience and experiment for me, I've always wanted to do a BMF and this is going to be either a great success or an abject failure...  It's is also a different approach, if it works, I will never shy away from a BMF ever again.... and no one else should either...
    Keep at it bro   your doing fine   it will be super.
    OC.
  2. 1 minute ago, gjdale said:
    Glad to see you haven’t given up on this one OC.
    Thank you Grant,
    No  - what I have learned  is to be more careful with rolling the Blu Tack  into smoother smaller  sausage shapes  and longer runs, then to be more precise  how I place them, also I am pressing them down further than I did before  to make sure they have better adhesion  with the plane, hopefully  this way the lines will be smoother.
    OC.
  3. Having a slight change of subject  so back on this  for a bit   - variety is the spice of life  and all that,     so  next job on the Seafire was masking time,   I used my normal  - paper and tamiya tape,   but I also found that blu tack  came in usuful  for masking the exhuasts  and wing  detail section  - next job to spray  the primer.
    OC.
