Posts posted by Old Collingwood
Always a course of forward and backs with out model making, she is coming on lovely despite your little hick up.
OC.
Time to build some display cabinets Carl.
OC.
- mtaylor, cog, popeye the sailor and 2 others
- 5
Thats an Airforce.
OC.
After a day in the yard charging me Vit D cells I then de masked the fuselage - not too bad, demarcation line had a bit of a ridge so I attacked it with smooth wet and dry soon sorted, then I noticed a bit of camo that needed correcting - so back on went the masking using tape a bag and blu tac and a quick re spray over a tiny area, I then put it away to dry.
I then turned my attention to the props and spinners - the spinners was a bit awkward getting a smooth sprayed finish as I kept getting some over spray, so plan number Two hand paint with Nato Black - so this was done, I put them aside and tipped the props yellow after masking.
OC.
1 hour ago, VTHokiEE said:
Looking really nice!
Thank you kindly.
OC.
1 hour ago, Landlubber Mike said:
Nice work!
Thanks Mike.
OC.
- popeye the sailor, mtaylor, Canute and 1 other
- 4
Excellent work Mark, bet your so pleased getting the First planking done (hows your hands from the sanding - I remember getiing quite saw fingers with mine) I love the idea of you doing your own rear panel so many kit ones are lacking.
OC.
Just as Edward said your gun ports came out spot on, also I love the shaping of the hull and the smooth work on her, nothing wrong with that in any shape or form, really coming on my friend.
OC.
- Edwardkenway and VTHokiEE
- 2
2 minutes ago, cog said:
Probably a coat of clear lacquer ... solves most paint issues
Dont do my trick though😭
OC.
So, more work on her this eve, I put a few coats on the props - I decided to use Flat Nato Black as its actually like a dark flat Grey, I put a few coats on followed by a few watery coats to smooth out the finish, this was put aside then I put some blu tac inside the spinners attached a stick and went outside and sprayed then the same Black as the fuselage.
They were then put inside the goody goody box to dry.
OC.
- Egilman, lmagna, Edwardkenway and 3 others
- 6
Wonder what the answer is to stop the tape pulling the paint? it crossed my mind also.
OC.
- mtaylor, Canute, popeye the sailor and 1 other
- 4
5 hours ago, Canute said:
OC, hope the unveiling turns out well.
I had a peep "not telling you" lol, seriously needed a bit more spray on the one side - this was done then put back in the box, might leave it in there for a bout a year - everyone patient enough
OC.
5 hours ago, Javlin said:
Props look good OC looking forward to the union of the fuse and wings Kevin
Thanks mate.
OC.
- Canute, Edwardkenway, mtaylor and 1 other
- 4
Excellent work.
OC.
23 minutes ago, Landlubber Mike said:
Good stuff OC - glad you stayed with it, it's looking fantastic. Good luck with the mask removal. Sending good vibes your way.
Thank you Mike, thats very kind of you.
OC.
Another kit I have my eyes on doing when funds allow and after I have sorted out a few important financial things that are waying heavy on my mind, is to do another kit that falls quite close to this one as they were both FAA service and both based at the same Naval base were my late father worked - the unique one of a kind F4U-1A/-D Corsair,
My farther used to chat to me about "the bent wing bird" and how they were like nothing else he had worked on, and how they had initial teething troubles with them that needed quite a bit of sorting out before they could go onto the British carriers.
This type - (Off the Net)
Will keep you posted.
OC.
That lump loooks excellent, always loved full fairing machines myself, one bike I have nevr seen a model kit of is Suzuki RF660R.
OC.
- Canute, popeye the sailor, mtaylor and 2 others
- 5
Good to see some of your bits are arriving mate.
OC.
- Edwardkenway, CDW, Canute and 4 others
- 7
Mosquito B Mk IV - FINISHED - Revell - My next non-ship project
in Non-ship/categorised builds
Thank you Denis.
OC.
