Welcome tony its a great site with lots of help and convos, LHR - do you like planes also? OC.
Thank you paul, the last time I built a period ship it was one of those Airfix plastic kits HMS Victory or Wasa I think - about 45 years ago straight out of the box. OC.
Thanks paul, I guess there is only so much scratch building you do to a plastic kit - all be it a very very good kit. OC.
To be honest paul just getting them glued down was a real pig - I tried the best I could to get them the right way up, I firstly had to to try to file a small flat spot under each deadeye to aid gluing them down with no other securing what so ever, the way I look at it even if the ropes between the channel / shroud deadeyes are a bit wavy navy - they will be better than the all in one cast plastic shroud/deadeys assemblies - kind of a better move even if a bit less precise than pure wood kits with deadeye chainplates and etc. OC.
Thank you so much lou, those two ports are left un covered port and starboard - reasons unkwown, but they show it like that on the real thing - OC.
Good day all, as always sincere thanks for all the replies and likes, So onwards with the channels - I continued with my process super gluing the deadeyes to the channels, and attaching the chainplate legs then painting and weathering. I have the two completed on both port and starboard, and also the mainmast channel on the one side. Here are the pics -
While on a run - I decided to have a go at the bowsprit and creating and fitting a bobstay and tackle, in the kit there is an assortment of tackle devices in plastic but nicely formed, first off I drilled through the beakhead then secured some thread through it - to this I attached one of the tackle pieces by a simple knot and touch of glue, I did the same to the end of the bowsprit, then I ran a length of thread through the tackles to form a link and glued the end with a small knot. After I touched up with some black/grey just needs weathering. Two more pics - OC.
While letting the first small channel set - I turned my attention to the last row of lid lifting rope/devices, I cut off the ends of the rope then touched up the paintwork on all of them - now they are all fitted/painted. Here is a pic and also a few extra deck pics - OC.
Evening all, thank you for all the feedback and likes. Right then straight in with it - I put two of my wood deadeyes next to the channel linkages and messed around with different joining methods, I decided not to drill through or use a rope/thread - I decided to file the linkages a bit, then I glued the deadeyes to the linkage using strong super glue, after they had set I applied more glue around the base of the deadeyes to strengthen them. I put the assembly aside to set then I applied a couple of coats of paint - then once dry it was glued to the hull - making sure the support struts linked up with the holes in the hull. Here is the result minus weathering - OC.
Thank you kindly mark, yep I thought of that and made sure the cutouts in the hull are free of paint, and also the linkage holes - so it should glue well. OC.
Thank you for putting my mind at rest, I guess all the extra bits of work will make it worth it in the end. OC.
