Everything posted by scrubbyj427
Thanks Rusty and Diver for the comments. Diver, to answer your question, yes I am building in an engine room. Winchelsea will be my 4th boat built... on a boat and she comes in second For overall nautical miles under her keel! I started Adding the panels to the stbd side tonight, making sure they are as close to the port as possible. A little trick I used to insure that the panels are square and lined up perfectly to the ports, I used a flat piece of wood that sits parallel to the gunport frame, glued it to the deck and wedged it in the frame, from there I can keep test fitting the panel until it fits perfectly between the two ports. When It comes time to glue it in place I can just put it up against the port with the wooden block and set the elevation and it will fit just as it’s supposed to without worrying about it moving side to side. I also used this on all the spirketting between the gunports as well. Hope Someone finds this is helpful. JJ
Wow! I wasn’t so sure of those resin cannons at first but that looks very convincing. Will these and the carriages all be available in the Winnie section of the store?
- 1,784 replies
- winchelsea
- Syren Ship Model Company
Have you ever had issues with any rust appearing with steel wire?
- 1,784 replies
- winchelsea
Thanks Fred, I've been getting little bits of time here and there to get work done. Sounds like you’re running wild on yours! Last week I got cabin panels in along with the last double strakes, a single nice coat of red and it came out well. I had to do some minor wood filling to make some lines disappear before paint. The captains cabin panels went in pretty well with very minor adjustments. Ive got the starboard spirketting almost complete, I spent some time tonight making sure my deck clamps were lined up as close as possible before I glued them on. I measured from multiple points as well as confirming with the eye test, using laser etched lines on the subdeck as a reference. This visual reference will be the final judge once the deck beams are in place. I’ll get them sanded tomorrow and start the panels before finishing the last few strakes.
What a stunning achievement! Amazing work! JJ
- 1,035 replies
- royal katherine
- ship of the line
Thanks Chuck, Ron and Matt for the comments and all the likes. Matt, I find that If there is sandpaper, glue and sticks laying around I make sanding tools on the fly, I end up having hundreds of these little things laying around. I guess it’s easier to make them rather than keep track of them. But it’s very easy to tailor them to nooks and crannies that conventional tools can’t reach.
I’ve just decided that sanding the outer hull is much more enjoyable than the inner. With that being said I’ve completed 80% of the port side with a rough sanding. The planks went down as Chuck prescribed, the only deviation I made aside from the month long lighting project was to glue the plank under the gunports down first to establish the correct run for the other three rows, the lowest 7/32 plank went in last which was a little bit harder to accomplish, the second layer will go down much easier. I Also got to poke around with the laser panels to see how much work I have ahead of me and it wasn’t too bad. Onto the stbd side this week hopefully. JJ
Looking good Kevin. I built Dorade about 10 years ago and what a fantastic kit it is. Dorade is one of my favorite yachts. She still races to this day and is still quite a competitive boat for her class. I’ve seen her several times and even raced against her in a classics regatta. Enjoy the build. JJ
That looks awesome! What motivation!
- 607 replies
- winchelsea
kit review 1:48 HMS Granado ‘Cross Section’
scrubbyj427 replied to James H's topic in REVIEWS: Model kits
I think I need one of these... should be able to work it in next to my Winnie. -
Small update: So I have finally finished my side project of adding all the wiring and lights I want to use, which took way longer than anticipated! Provisions have been made for the stern lantern down the road. You can see a small connecter that I ran through the keel up underneath the sub deck, the female plug sits flush with the bottom of the keel and the male plug which sticks out now will eventually be hidden within the blocks that the model will sit on so there will be no signs of any wiring or electrical work when she’s complete. I Also got the sub decks glued down, I took Mikes advice and used CA To place these. It took quite some time to get these where I wanted them and I still made a few mistakes which I can live with and correct in the decking process. I milled a bunch of lumber last night and plan to start the spirketing this weekend. Feels good to be back on track again. JJ
