Posts posted by Kevin
good evening everyone
day 10/90 Stern Frame and after peak
this section has taken me again most of the day, and still not completed, next bits to be added will be the top of the rudder connection
some of the bits for todays work, varnished and trimmed to size
making up the top deck girders for tomorrows work
just in place for the photo
- G.L., Old Collingwood, yvesvidal and 6 others
9
1 hour ago, maaaslo said:
how is this kit build going on? i hope you did not get rid of it, it would be such a waste...
Thank you
it is still as per the last photo, in the future i will do the same as the back end and add a bit from the midships section to it and produce a diorama
meanwhile i am working on the back end and have about 80 days left to produce something out of it
- thibaultron, Canute, mtaylor and 2 others
5
thanls guys, i was considering black, or very dark grey (off black)
- Old Collingwood and mtaylor
2
9 minutes ago, Jim Lad said:
Still charging ahead, Kevin!
John
lol i see the phots i posted they all look soibad then add a bit of glue and they become more presentable
i now am asking myself what colour were the double floor frames, would i get away with red ochre i doubt they will ever be seen, but i dont know what sections are going to be opened up yet
- mtaylor and Old Collingwood
2
thankyou for comments and likes
day 9/90 shaft tunnel
taken me most of the day to get this level done, varnished, cutouts and slots done, deck plates will cover this in the next day or so,
After this is glued into position, the stern will start to be built up
all loose so will straihten them out as they have pva applied
- realworkingsailor, G.L., mtaylor and 5 others
8
to be honest, i never thought about how good but unserviceable aircraft got back home, i need to read up on why this ship was used for it
the PE work looks fantastic
- mtaylor, Canute, thibaultron and 3 others
6
lovely to catch up on the build again, stunning work
- Old Collingwood, Canute and mtaylor
3
4 minutes ago, Jim Lad said:
The accommodation block is coming together really nicely.
A dull reddish brown was probably the fashion colour for decks at the time, although I've also seen a dull green.
John
the red brown sounds good as it will be end of life anyway
- Old Collingwood, mtaylor and Canute
3
day 8/90
managed to make up another deck today, the last one is going to have to wait as it is fitted directly to the deck plates, and i am miles away from that
the corners i am putting a thin strip of paper to tidy them up, with loads of weathering i doubt they will be seen
tonight, i primed one level in grey just to see how it looks, i have infact just ordered some white primer and top coat i have not seen a SD14 superstructure in any other colour than ochre or white
@realworkingsailor what is the best deck colour? would it be green
2 hours ago, Old Collingwood said:
How you guys do this with such delicate stuff is beyond me - amazing but scarry.
OC.
quite easy OC
1 card kit, shape blades, straight edge, decent paper glue and superglue to mend me fingers when the sharp blade a straight edge system dont work
- mtaylor, Canute and Old Collingwood
3
5 hours ago, Roger Pellett said:
Thanks, for reminding me of this Andy. I was part of a student team to design a tanker with a hinge amidships. The idea was to produce a vessel with draft shallow enough to pass through the Suez Canal. The hinge reduced stresses in the shallow hull. We built and towed an 8ft long model of the proposed design.
My job was to design the ship’s machinery and I used a large slow speed Sulzer engine. The American Nordberg engine company offered a prize for designs using a Diesel engine. I designed a heat recovery system that used engine exhaust to generate steam to power the ship’s generating sets.
You are blasting through construction of this model with lightening speed, Kevin and doing a beautiful job. I hope that you build the entire ship.
Roger
i have a lot of the fwd section made up, i may add some of the now useless midships section and complete her as just out of build, (start of her life)
- GrandpaPhil, king derelict, mtaylor and 1 other
4
8 minutes ago, Jim Lad said:
You're progressing well, Kevin, and it's good to see the obligatory 'model maker's cut' on your thumb!
That's a beautiful model of the wreck that you posted, by the way.
John
i stopped the bleeding with a fast setting c/a and it got everywhere, never trust me with a sharp knife
a few more of the diorama (NOT MY PHOTOS)
- Jim Lad, GrandpaPhil, Old Collingwood and 6 others
8
1
day 7/90 - flying by
i was inspired by this model many years ago, and will attempt something like this in my project, this is 1/144 whereas mine is twice the size
looking on the net for cargo ship scrapping i came across this hence one of the reasons for add the extra cargo frames, never mind the foreground only 3 months to build 1/3 of a ship
took a break from the frames today and played with the accommodation block, this brings in the full size of the build, here she is as of tonight
7 minutes ago, realworkingsailor said:
Even diesel boats today still have a small steam boiler. Either a small oil fired unit or an exhaust gas economizer (waste heat recovery), and very often both. Although not used for propulsion, the steam would be used to heat fuel oil (IFO is thick as molasses at room temperature, HFO even thicker), for warming the engine (via heat exchangers) prior to starting, and other auxiliary uses (hot water for the crew). The boiler(s) would require it’s own feed water tank as there are various caustic chemicals needed to prevent corrosion and sediment build up, that you don’t want in general circulation.Andy
thank you Andy
i was trying to remember my Submarine training for feed water/ and distillers and everything my head had to remember, not to mention reactor recovery when sat in the ship control seat
3
48 minutes ago, Roger Pellett said:
Kevin,
It’s coming along nicely.
I believe that the term Shelter Deck was originally chosen to maintain the fiction that the deck was only sheltered from the weather, not watertight.
You mention a feedwater tank so this must have been a Steamship. This is somewhat surprising because by the 1860’s the large slow speed direct drive diesels were favored by many owners and of course Sunderland was home to Doxford, an early proponent of diesel propulsion. Americans were, and still are, one of the few holdouts. They continued to build steamships and when they switched to diesel, it was the medium speed engine with reduction gears and/or CP propeller.
Marine Engineering is Naval Architecture’s less glamorous sibling, particularly in the diesel era as unlike steam plants, the engines are designed by mechanical engineers working for the engine builders. Reading news from my alma mater, I sense that the discipline is coming back into the light of day as shipping lines look for ways to reduce emissions from burning the heavy bunker oils.
Roger
thank you for your reply, im not sure where the feed water comment came from, she is certainly a diesel driven unit built in the 1960, there are still some floating around
i can certainly see a return to wind power
- Canute, Old Collingwood, GrandpaPhil and 1 other
4
day 6/90
well after the addition of the bulkhead, very little seams to have been done today, even though a put a good few hours in
tomorrow i will be working on the shaft tunnel, as that area is getting well a truly battered from the moving around
a bit of paint has made it look a bit better
i now know where the three decks are going to sit
engine room platform
middle one is the tween/shelter deck (1/2 deck)
and top deck
all the tabs between the double floor frames will tidy up when the frames go in, it does make it look very untidy
- G.L., reklein, king derelict and 4 others
7
good morning everyone
sorry about the confusion last night wrt to shelter/tween decks
i have resolved my bulkhead issue, i used part of the midships section, which was beyond repair, and now in the process of joining them together
to do that i cut back the bottom plates to gain access to the double floor frames, it now looks like the 3 part build will be a trwo part one, the front end
as new and this end will be end of life at the breakers
from the midships section i removed about 10 frames up to the forward cargo hold
cut back the bottom plates to gain entry to the frames
- G.L., reklein, realworkingsailor and 7 others
10
Kevin,
Your post that quoted my post reads,
"thank you
as it will be in a cutaway, i will be aware now when it comes to the upper deck and access, it will be helpful then to see what types of goods would be held in this area, as i had presumed that the name shelter, meant that"
Not sure what you were going to say, but the tween deck was just another cargo space (the 'shelter deck' title being merely a bit of legal jiggery pokery by the time these ships were built), but as the tween decks were much smaller spaces than the lower holds, they were useful for stowing smaller or more delicate parcels of cargo or for partial stowage to assist in maintaining a good metacentric height for stability purposes.
John
sorry john, my reply dont make sense, i never realised the two were the same (sheter/tween deck) even though it is in my opening comments, thank you for correcting me
- Canute, Jim Lad, Old Collingwood and 1 other
4
day 5/90
thank you for comments and likes
i have a problem
although available in three kits, it is not going to be easy to build the after section as such, as i have found out today, to keep its shape it needs the bulkhead, which is part of the midships section, which cannot be used as it has bowed from being in my garage for lots of years, also it would take me well past the group build timeline
i am not allowed to purchase a replacement midships section (new years resolution, plus model dockyard has gone bust, and it looks like Marcle have as well, an email to them l keeps bouncing back
so what's my options
worst case is that i cut the midships section up and attempt to attach it to mine, or remove bits of it to try and duplicate, im not a big fan of either,
today number 6 bulkhead has been made up and in place, an enjoyable project with lots of scoring to get the shape
as you can see from the below image the engine room platform and the tween decks fit to the bulkhead but ultimately needs another one to take the weight and keep the shape, i don't think the frames will be enough to support the weight
this is the midships sections been in my garage for well over 5 years
tween decks level being made up away from the hull
day 5/90
i have a problem
USS Thetis Bay 1944 by RGL - FINISHED - Hasegawa - 1/350 - PLASTIC
cannot say i fancy all that masking, but she certainly looks great
sorry, i dodnt have an answer for you, have you asked the wife to bite them for you😀
