Gahm
Everything posted by Gahm
  1. As usual you take a good kit and use your superb craftsmanship and love for historical research to get a master piece out of it. Very impressive! Thomas
  2. Looks very good, Robin! I love your color choice! Thomas
  3. That is a nice looking pump! And in my opinion it looks even more impressive with the handles mounted 😉. Thomas
  4. Your stern arrangement with all the details in place looks very nice! And you make very good picture as well 🙂! Thomas
  5. Just awesome! Are you building a model or the real thing? Thomas
  6. Great progress! Your deck is getting crowded 🙂. The binnacle turned out very nice! Thomas
  7. Will, Carl and Per, thank you for your kind comments! Will, I turned the belaying pins from tooth picks on a little Proxxon lathe. To be able to repeat the pattern reliably, I just used a little drawing with the measures/dimensions of my target pin, which I had always in front of me and which I could use for comparison (see image). That actually worked pretty well 🙂 Thomas
  8. The steering wheel clearly is a highlight of your deck furniture. It looks great! Well done! Thomas
  9. Thank you Robin and Justin for your great comments! And thanks for all the Likes! Building these little boats is a lot of fun. And as far as I know Syren had three of them. So there is still a lot to do 🙂 Thomas
  10. I started with the Syren longboat construction. Using Chuck’s plans provided in the Syren kit I subtracted from the frame profiles the amount caused by frame thickness (1/32’’) and planking (<1/32’’) and built a jig out of bass wood (imgs 1-2). I milled a longitudinal groove in the center of the jig for the keelson. The keelson consisted out of boxwood (width 1/16’’) with 1/32’’-wide notches cut into it at regular intervals of 5/32’’ (img 3). A thin layer of plastic foil was inserted between the keelson and the jig to insure that the longboat would not accidentally be glued to the jig during the building process. Using the mill I ‘transferred’ the keelson notches to port and starboard side of the jig to drill holes (diameter ~1/16’’) and cut slots perpendicular to the jig. Both were placed as close to the jig as possible (img 4). With these preparations finished boxwood strips of 1/32’’x1/32’’ were soaked in hot water, inserted one after the other in the holes close to the jig, bent through the corresponding keelson notches and moved through the slots on the other side to the jig. Each boxwood frame was glued into place at those three points (img 5). As a next step the keel assembly was built consisting of stem, keel, deadwood, sternpost, and transom (img 5). A rabbet was cut on both sides of the stem to facilitate planking later on. The last three rear frames were assembled out of small profile pieces and boxwood strips to accommodate the shape of the frames. Img 6 shows the front and the rear part of the finished framing. Finally to stabilize the whole construction two planks were glued to the frames on both sides (img 7). After cutting the frames above the points where they were glued to the jig the whole longboat frame assembly could be removed from the jig. This was primarily done to ensure that it would come off in one piece and that the whole construction worked 😉. The result is shown in images 8 – 10. To facilitate planking the longboat frame will be screwed to the jig again later on. Thomas Image 1 Image 2 Image 3 Image 4 Image 5 Image 6 Image 7 Image 8 Image 9 Image 10
  11. I can see why you ordered this kit . . . I would love to build that one myself! 👍 Thomas
  12. Your combination of companionway and capstan looks fantastic! Going with pear wood was a very good decision! Thomas
  13. Your binnacle turned out really nice! Another great detail added to a beautiful model. Thomas
  14. The binnacle is a very nice little project, and it is one of the more prominent deck details. Yours is coming along beautifully! Thomas
