HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 69 donations so far out of 49,000 members - Can we at least get 100? C'mon guys!) ×
themadchemist
Everything posted by themadchemist
  1. ....amazed as always.... the figures give a nice idea of her scale.... as does your finger.
  2. Excellent camera work. how do you get those at gun deck level shots? Amazing as always. Thanks for sharing.
  3. those small gratings can be a real test of ones patience. Nice job, they look great. As much fun as planking is, fitting them out is nearly as much fun.
  4. The last time I had to use boiling water was with bending the ebony wales on the longboat, of course I didn't have to worry about glue softening. It always amazes me what you can get wood to do with water and heat. Looking good Jesse.
  5. I don't know if the #10 blades come in differing sizes as I have a in house supplier , Its nice having a wife working in the OR.... but the one I used was a small blade. I found the rounded tip made a bit wider pseudo-rabbet that was wider then using an #11 blade. I 2nd planked with 0.5mm cherry and basically scraped and fitted the size of the pseudo-rabbet with a scrap piece of planking. Having the blunt side riding the keel, helps keeps it straight and doesn't mare the keel. The ones she brings from the OR have a widen back for bracing the blade, which makes a nice frictionless edge, I don't know if the store bought one are that way. I've always loved the stern hulls where the planking wraps up into the counter. Its such an attractive feature on a hull. BTW have you considered whether to treenail the hull or not?
  6. She's looking good Brian. Typically the plank is narrower at points where it goes through a maximum in curvature. That wrap under the transom is a tricky area, what you've done looks good, it will be interesting to see as it progresses around to the stern post. The use of stealers may be a good way to fill in that area. You could incorporate a half stealer and full stealer, just for the practice of it. I like the way you use the tape line as a pseudo-batten, that's a great idea. However you plank her, side to side symmetry for me is one of the more important aspects, especially at the stem and stern line. Of course the Stern will be broken up somewhat with the rudder, which doesn't standout as much as the stem line, but honestly I don't see that as an issue, as your doing a beautiful job.. I think she will look awesome natural. ...and on the pseudo-rabbet. Use a #10 blade. The one that is flat on the back (unsharpened) and has a curved front edge. Putting the flat edge up against the keel, angle the curved edge into the hull and scrap in your rabbet. I did this on the DSotM and the plank to keel rabbet line turned out nice and tight and gives the impression of the plank fitting into the keel rabbet, which is what I think your wanting. You can do this at the stem also if needed. That walnut is really going to POP with finish. Have you considered what you may use, many use the wipe on polys but I am still am stuck on the old school tung oiling.
  7. Thank you for the hand drawn illustration Nils. I figured it was accomplished with beveling of some kind. If it was just sanded flush one would tend to sand through the overlaying plank and show the space (gap) beneath. Especially on such thin stock. The geralds, to my understanding are to get the planks to overlay and interlock with the opposing gerald or rabbet of the underlying and overlying planks. Building such a small feature at that scale would be near impossible but your technique simulates it very nicely. The plank narrowing adds much further detail. I've watched the videos of the clinker build dinghy by Traditional Maritime Skills on youtube many times and it is a project that I very much would like to attempt, maybe even at a much larger scale, even possibly to 1:8. It may be best to start with a smaller scale for practice though. After finishing my first longboat, I still wish to continue with another, as I find them a very relaxing project and not near as easy as one might expect it to be, which is part of my intrigue. One of my recent studies has been the building of a clinker vessel and I always appreciate those that build them and show details which help me in understanding the best way to simulate the smaller details in such small scale. Thank you for your expertise, it is appreciated.
  8. Relooking at your work, (I love relooking at good work and thinking my way through your process) I'm now beginning to question how you achieved that correct look. Did you bevel or “brow” the Lands (lap) and were gerald's cut adjacent to stem or was this achieved with beveling alone or just sanding them back even? Your plank widths, wide mid-ship and narrowing at the stem and transom, with narrowing happening at maximum curvature points makes your little walnut shell quite real looking, to the form in which I understand them to be build. I wondered if one could make a razor blade scrapper to scrap in the geralds and was just wondering how you achieved your excellent realistic results. I also just realized that the stem and keel were not fit until after removal from the jig. Was fitting the keel/stem more difficult post planking or did it aid in creating the rabbet line
  9. Nils, you have done a beautiful job simulating the geralds at the stem. The flow from clinker to the smooth lay of the geralds as the clinker transitions into the stem and transom is nearly as difficult a part to simulate at that size as the correct overlapping of the clinkered part of the plank. At least I would assume so.... Beautiful work, and fast also. Your work only makes me want to tackle a clinker build vessel all the more.
  10. I'm not knocking the kit supplied anything, Alistair. I'm just saying it is nice to upgrade If one wishes. One could say that filing the flashing seams on the white metal castings and adding photo-etched insignia and flint locks could be just as big an upgrade as new guns. Or one could simply paint the guns as they are, the originals probably has cast flashing and a much rougher finish then we simulate. Al I was saying is that its nice for a builder to have options and MSW teaches many differing ways to upgrade a kit, from modification to kit pieces, to completely replacing them. The white metal castings of figureheads, quarter badges and stern pieces are another place where modifying or replacing a piece can make HUGE differences and whether modifying the kit pieces, or by buying a new piece, or making a piece completely from scratch, it is just a way for a builder to exhibit their personality. I personally enjoy seeing scratch built pieces, but as with anything, that requires skills, which we slowly accumulate over time and each build becomes better as we learn how best to modify the kit to our liking. That's a part of building I personally enjoy. On a painted ship, one might question changing woods, but differing woods are easier to work with and give a better fit....or like in the case of the Holly decking, it just plain looks more striking then the kit decking. It is really not about what one uses, so much as how one uses what they have. One who spends the most on extra parts doesn't have the superior model, but the builder that creates a more enjoyable and satisfying build for themselves has, as FUN is the measure of this hobby...and only the builder themselves can judge that in the end.
  11. I agree, I wouldn't touch the original....and I'm thinking down the road after several other builds... then revisiting the first for a side by side. My DSotM wandered far from a pilot and at some point I'd like to rebuild a historic pilot, possibly even POF. You also have that Hannah to consider....
  12. What? No pictures in the AVS to show how they fit? Painting teaches patience, slowly.... The nice thing with the AVS is that it gives a small primer on rigging guns. With only 8, it gives you practice without rigging huge numbers. I've yet to tackle that task and see it as a huge challenge. The San Francisco at 1:90 has me worried, and it is the odd 2 wheeled carriages supposedly. The upgrades look great, it's always nice to go beyond the kit and make your build personalized. Chucks ropes and blocks... well all I can say is I can't imagine using AL rope or blocks after seeing and using Syren, Were the MS cannon cast? You should show a side by side for comparison, that sometimes really justifies the upgrade. There are some great up grades that MSW builders are producing that help take this hobby several notches towards a better place. Upgrading woods, lines, blocks, carriages, cannon and all other manner of bits and pieces (photo-etch) plus tools, make the original kit price pale in comparison, but I see it as investing in me. People don't blink twice at spending $75 or more every month for TV and they see that as a hobby, I'd rather invest it in a real hobby where I use my creative ability in an established historic hobby. Stamp and music collecting satisfied my taxonomy and artistic side , but ship building satisfies my tactile and academic sides. Both historic studies and the study of applied physics of how the rig/ hull create a working vessel. Plus its art in 3D. Building and other physically active hobbies, I find so much more involving personally, don't get me wrong I like movies and some TV programing, but can not stand the commercial media invasion. I think this hobby draws people with that type of personality. The ability to spend hours on a task only you and a select few will ever notice, just because it brings you pleasure. It's also nice that each person can chose the limit of how far to go with a build. As the Carmen was an "out of box" build has the thought crossed you mind of ever revisiting her again? The good old "why we build?" ...because its FUN
  13. To me it doesn't look strange, with just the stay sails she kind of reminds me of the Xebec rigged with her Lateen Sails, if one doesn't focus on the tall Masts. ... But then I love fore and aft rigs and Lateen setups. To me I couldn't tell you if they are wrong, but I can say they look GOOD. Your Pegasus just keeps expanding and becoming more detailed. With the more distant pictures, one almost forgets that she's cut away for internal viewing. The layers of detail, that draws one in and as you get closer more detail appears, with the added cut away makes your Pegasus SO unique. It is the work of a real Master.
  14. I used a sealing iron on the thin stuff and it shaped so well that the glue was about all the clamping needed. I would narrow it, then glue it into the stem rabbet I'd scrapped in between the stem/keel and the hull, This help simulate that interface. I'd glue about a 1/4" to a 1/2" down. Once it was dry, I'd wet it with a brush and shape it with the sealing iron, so that it lay against the adjacent plank. The heat really done a number on that thin stuff and you can make it lay so tight that you have to pry it off to apply the glue.
  15. Congrats on the promotion. don't you just hate all that studying She's coming along really well. I like that steel rule/rubber band rap job to get the pull-down force on the stem end while shaping. Having those lower decks comes in handy. I couldn't have done that on the older kit. Nice innovation. I wish more people showed the shaping and clamping process, as for me it was always a fun and interesting challenge to figure out just how to restrain the plank while drying... and the method changes as you work around the curvature of the hull. I used some pretty crazy methods. The pins are a good idea, I couldn't bring myself to put holes in the planking, but as she's 2nd planked and now knowing how well dilute glue and sawdust filled those holes, it would have made life a lot easier Its nice to have some build time, kind of like a desert at the end of the day... that is if you don't get lost in it and look at the clock and it is way later then you expected. I feel many focus too much on the pace of a build and not enough on the FUN aspect. Forcing your self to build in order to make a deadline turns building from play time to work time. Never let it stop being FUN. Hopefully once your settled into the new position, your life will get back to normalcy.... if such a thing exists in todays world.
  16. Nice drawing Nils, It is good to get everything worked out before starting. and The sails look every bit as good on, as off the model. One can get lost in the details of those last pictures. She's one beautiful Lady with so much detail.
  17. Thanks Phil. I agree, no 2 Swift builds should be alike, even if just going for the box picture. As with all of life's events, it is all about the experience and each person has to have their own experience, fulfilling what ever their needs are for doing such a task in the first place. I've always enjoyed people watching and as a teacher I found the social interaction of the students an interesting study. I find the same interest with MSW. Each build log has a personality of its own, based on the builder and their wants and needs. Having worked intimately with the older swift kit, I find it interesting to see how others approach the task. I haven't seen a build yet, that hasn't taught me something. No matter whether a veteran builder or a first time builder does the task. The Swift is a beautifully lined boat with a nice sheer line and she's always fun to watch built. I've travelled far off the beaten path with my build of her, but yet the task has given me a real respect for the task the Pilots performed in a nautical world and also their step towards the development of the schooners.
  18. Hello Phil and welcome to the Swift club. She's a great kit to cut your teeth on but I recommend tossing the AL instructions and using MSW as a guide. There are many Swift to learn from. Definitely put balsa in the bow and stern. Nice red illustration. For the stern you will find a 5/8" dowel with sandpaper glued around it will help sand and shape the stern block. Also on the loosening glue, good old H2O is usually the best. If its deep, rubbing alcohol (isopropyl) will help a bit more with penetration. I typically use water with luck. I just clicked the follow button as I can't miss a Swift build. The kit has SO MANY issues, but the bones are there for making a nice little pilot. It's always good to see another builders interpretation on this classic, new or old version. Your right on the fact that the Swift kit simulates the keel/rabbet interface and once you fair the keel bulkhead to a "V" across the second bulkhead it should make a nice transition. The balsa between the 1st and 2nd bulkheads along the keel is so that the bow end of the garboard is best ended between those 2 bulkheads and it will need a solid glue surface. Moving the garboard plank much farther forward and the bow becomes crowded and forces either a dropped plank or over-narrowing at the stem of the planking. Creating a tight keel/stem to hull line is one of the more daunting tasks of this build with the way its simulated. You will also find AL simulates lots of things and leaves many details out, but it is up to the builder, how far they want to take the build by adding to the kit. Looks like your off to a good start and doing some good research. Traditional Maritime skills is a great research tool and don't miss Marcus Lewis's clinker built boat videos on Youtube. They are amazing.
  19. I agree, the older W W Norton published 1st ed's are much nicer as the fold-outs are glued in the text and actually fold-out. That way the drawing isn't lost into the crease of the book. I ordered a old version of "The History of the American Sailing Navy" and received a 1st Ed of "The History of American Sailing Ships" by accident, similar titles. I already had "The History of American Sailing Ships" in a newer printing and when comparing the 2 much preferred the older text, mainly due to the fold-outs. The dealer also sent out the correct book and let me keep the older edition, which was nice. I've noticed on Amazon that by checking all sources, one can usually find the older ISBN versions cheaper also, plus they come with that old book smell for free. Of the Chapelle books "The American Fishing Schooners 1825-1935" has been my favorite. The drawings are priceless in the second 1/2 of the book. Similar to Petersson's texts but many more close up details on individual rigging pieces. Edit for example here is the schooner book for about $40 US http://www.amazon.com/American-Fishing-Schooners-1825-1935/dp/039303755X/ref=sr_1_1?ie=UTF8&qid=1416686574&sr=8-1&keywords=The+American+Fishing+Schooners+1825-1935 but here are used 1973 versions for about $14 http://www.amazon.com/gp/offer-listing/B0027GJR2M/ref=tmm_other_meta_binding_used_olp_sr?ie=UTF8&condition=used&sr=8-3&qid=1416686574
  20. Thank Cap'n'Bob Looks like I need to pull Chapelle off the shelf. His American Fishing Schooners has some great diagrams, it think its my favorite of his. I appreciate the time in taking pic's.... I may have questions though. Having never sailed it's a lot to wrap your mind around and understanding it mechanically is as important to me as building it. Thanks you very much Sir, you are and gentlemen and a great mentor.
  21. Beautiful Work Cap'n, as always. How much trouble would some close-ups pic's of the rigging be, you know me, why not borrow from a master, if allowed. especially the rigging of the top sails. BTW the Bounty's launch had a sail. I'm sure many did.
  22. Actually shouldn't the Jingle Bells have audio coming from it? Ask the Admiral about that one, because I'm sure know you can do it. Someone hand Popeye another can of spinach, the confidence enhancing hybrid strain.
  23. DanV's Boo-Boo thread is a must read. I agree in the scuppers, they look great. Also on the gun heights, remember wood thickness will play a part. If I'm remembering correctly you upgraded to holly, which will raise the cannons if its thick. Seems I read something in Alistair's logs on this, as I've been enjoying his build logs. Oh and BTW, you mention Hobby Lobby, if I haven't already mentioned it, there is a phone app that gets you 40% off the most expensive item and it renews daily. Hobby Lobby is a great source for materials.
  24. and some beautiful paintings also. Nice link Maturin. Thanks. edit: Just looking through the site, WOW what a wealth of information, definitely worth a bookmark, there goes a bunch more hours of homework time...
  25. If you haven't already Michael Motts Bristol cutter in 1:8 scale is a marvel of detail. http://modelshipworld.com/index.php/topic/74-bristol-pilot-cutter-by-michael-mott-18-scale-pof/?hl=mott A must read. The Bristol Pilots have a really different hull shape then the American pilots. Michael was also a professional model maker previously and has some amazing techniques and skills. His 1:2 Yawl Marie is also a great build log.
