Javlin
NRG Member-
Everything posted by Javlin
Not my build Sir but the builder is highlighted within the text linking to another site and yes he is very good. Kevin
You are rock'in and roll'in on this one Dave and it looks Really Nice Sir!! Most Excellent Work! Kevin
- 133 replies
- cutty sark
- mantua
(and 3 more)
Lou my actual workstation for model building has always been called the office it's on the other side of that wood pile stands a cabinet built into a wall the room measures 6'WX16"L a couple of pics. And Lou Thanks for the explanation could remember the story itself of the "Flying Dutchman" but that makes plenty of sense. Kevin
Yea Jack I have seen them that you could buy for $25 and up and said "just keep it simple" so there it is.I do not handling planes as they are being painted and really when I get to the clearing stage.Jack I think I have about 1hr+ in the project was working on the other side of the shop doing another project I was asked for assistance on......my wood pile ...............and BS wood in the shed.
Denis you were right hardly changed the color maybe a shade probably should of painted white first then the red live and learn.I have gotten the tailcolors on with a boo-boo forgot to put the tail numbers on first all's not lost I will just cut out the numbers that would show should work.The decals are thick so Walthers was used this stuff works but it scares the bejibbees out of me some crinkles stay it seemed though when I applied regular solvaset to the plane placed decal applied Walthers it smoothed out better.I still have to apply the bottom tailplanes stripes will follow that track and see if the results are more to my liking. Kevin
The base gloss black worked the best it has ever done for me over the last few years sprayed wonderful .The silver I am so-so started with semi-matte silver too flat? went to airframe silver though not polished to bright so back to semi-matte look's OK?I think once I get the panels done and get the red yellow and OD glare panel all well be good.I did get the exhaust panel with MM Magnesium.I opted out of the grey panels and all one color silver saw another build just quite enough delineation for my likes.
i have not been idle just slowed down between work and household stuff.I am just about ready to start the gloss black for the base to the Alclad Silver I think I may try some of the panels in a gray flat and spray the same silver and see what kind of contrast I get.The wings were tight ended up maybe removing about .010"off of the bottom of the copit assembly to get a better fit other than that it was a good fit with a couple of dabs of SG as filler nothing major.the instructions show the different wing assembly unlike other.
It took a little while for me to build up these belts to much work and it took about 2 1/2-3 hrs for me to build these four belts but the pit is about to be encase in the fuselage.I want to add that Rabu of https://www.radubstore.com/ was very instrumental in working with Revell in the design of the kit and my hat is off to him this kit just falls together he also designed the belts I used and other AM products.I have already built the duct-work behind the pit and installed pretty much SOP.The wing I will show more of it's totally different from ant other P-51 I've built.
Will do tomorrow night called it quits for today factory or aftermarket?I would suggest to anyone who might think about building this one when it comes to the Ip decal punch them and lay I was this close to doing that!! If it looks like crap tomorrow might have to pull out and ole Waldrons IP kit I also found my Rabu WWII seatbelts.I orginally got those belts for the HK 1/32 glassnose B-25. kevin
