Gender
Hartford, CT USA
daHeld73 reacted to a post in a topic:
HMS Bellerophon 1786 by AON – scale 1:64 – 74-gun 3rd Rate Man of War - Arrogant-Class
hexnut reacted to a post in a topic:
HMS Black Joke by highlanderburial - 1/50 Scale - by Todd Wardwell
Ferrus Manus reacted to a post in a topic:
Spanish Galleon 1607 by kirill4 - FINISHED - Lee - 1:100 - PLASTIC
USS Maine by ERSRich - FINISHED - BlueJacket Shipcrafters - 3/32
9 Pound Naval Cannon 1786 by AON - FINISHED - 1:12 scale
popeye the sailor reacted to a post in a topic:
VARYAG by RGL -FINISHED - Artwox - 1/350 - Plastic, resin and photoetch - Protected Cruiser
EricWilliamMarshall reacted to a post in a topic:
HMS Warspite by Old Collingwood - FINISHED - Academy - 1/350 scale - PLASTIC
Matthew 1497 by Ilhan Gokcay - FINISHED - Scale 1/50
Muscongus Bay Lobster Smack by SkiBee - FINISHED - Model Shipways - 1:24 Scale
USS Tennessee 1869 by Keith Black - scale 1:120 - Wood Hull Screw Frigate - ex Madawaska 1865
I always love your hyper-detail updates. I am making the same face as all those deadeyes! 😮
Joseph Conrad and the Otago, Allen Villiers and the Joseph Conrad?
Very nice work. vaddoc! Are you using Rhino? First of all, I understand the pushback from the "ship's curves and paper" fans, but at the same time, I think part of the frustration some experience is that CAD offers a LOT more precision, and old boats simply were not that precise. Go down to the drydock on a nice, salt-spray-blowing November day in Bristol, crawl around a large hull taking measurements, dodging teams of workers doing sheathing and caulk, go back to the office and calculate the offsets by candlelight--Or during the initial build, lay out the stations with splines, ducks and chalk on the lofting floor, then have wrights rough the sections out of wood with a pit saw and broadaxe.... It's enough to give a quality assurance/risk mitigation director nightmares... I think the historian in all of us can't help but have enormous respect for primary sources, or high-profile scholars working at an earlier time (Chapelle, Longridge, et al.), but the reality is that by CAD standards, the original plans often weren't all that accurate. One of the biggest problems in lofting a hull in 3D is getting the stations and WL's to line up and meet while being fair in both directions. I have yet to trace a vintage plan where that happens, because the original was never fully-resolved until wood started coming together. There is a bit of an 80/20 rule--what is good enough to start construction without wasting too much material? When doing it in CAD, every tiny surface imperfection is abundantly highlighted; where on the model, it's an issue that may be solved in 30 seconds with some 120 grit. vaddoc, the truly good news is that now that you've put the work in to make a faired hull, once you make it solid you can boolean ribs and even planking out of it, setting up shiplap profiles at a station and extruding single-rail surfaces using the planking curves projected onto the hull. You can also offset the polysurfs to accommodate whatever you choose for wood thicknesses... Great-looking hull!
They had rubber pads on the tracks... Graf Z looks amazing!
- 345 replies
- graf zeppelin
- trumpeter
Ala-Kart by CDW - FINISHED - AMT - 1:25 Scale - PLASTIC
hexnut replied to CDW's topic in Non-ship/categorised builds
I tape a cut length of plastic straw to the nozzle to decant into the airbrush... -
Tamiya also makes a pearl clear (TS-65) that is pretty nice--helps even out coverage... https://www.amazon.com/Tamiya-85065-TS-65-Pearl-Clear/dp/B0006SG21C -
Great work! I've also had good luck with Vallejo paints, both w/ brush and airbrush. They go on thin enough to keep detail and permit layered glazes, but also cover well enough so that too many coats aren't needed... https://acrylicosvallejo.com/en/producto/hobby/sets/war-games-en/french-infantry-napoleonic-wars-en/
- 2,699 replies
- heller
- soleil royal
(and 9 more)
Epoxy for structural patches, but good ol' Bondo automotive filler works great for cosmetic fill/surface coating, with Nitrostan/Red Lead as a final skim coat. Additionally, cabinet scrapers and box cutter blades work well over PLA for knocking down the FDM print lines...
- 133 replies
- alert class
- tugboat
Brilliant work, as always! Reminding me a bit of some of Charles Sheeler's great artwork... 🙂
- 238 replies
- leviathan
- troop ship
