Nirvana
Everything posted by Nirvana
  1. Bob, That looks amazing. Having the longboat centered on the base would have created several problems further down the road when casing. This will look awesome once the longboat has a home!
  2. Maury, that looks so good. And yes, patience is needed too.
  3. Aydin, Did you look for Valejo paint 70.966? Which is supposed to be the turquoise color. Otherwise those seats looks so nice.
  4. Jaxboat, 40lb is equal to 2.86 stones. Good job. Now I need to the same..... lol And with the box containing the Victory I can do weight lifting!
  5. Chris, that's beautiful work you have done to create HMS Victory. Any indication of the weight? Prince is looking great too.
  6. Julie, thank you for the explanation. Never seen it before but now makes sense.
  7. Julie, Even though the finishing planking is running "against" the water it looks amazing. Question: Why this running of planking?
  8. Julie, kitchen is important for the happiness of the family. Maybe you can sneak in a minute or two with the Endeavor.
  9. Blown away! On the other hand it is a rather windy day day too.........
  10. Now, that makes the mill even more impressive!
  11. Weflack, Are you creating this little mill from plans or is this just all from plans in your head? I am so impressed!
  12. Hi Sarah and welcome back along with your Longboat build. That frame support you added will keep the longboat strong while fairing the frames. It is well needed. I beveled the planks lengthwise for a tighter fit to avoid light coming through. I went along with Chuck's additional separate instruction using a hair-dryer or light heat-gun for bending and CA when it came to planking. Worked out really nice. However, your longboat is coming together very nicely and quick as well. We missed you at the annual PSSM BBQ in August. And that applies to you Harvey as well. ​
  13. Herr Pucko, I am very pleased that the instructions are in Swedish as well. ​ The detailing is amazing! Thank you for sharing.
  14. Gråsäl (grey seal), I just found your restoration of Bluenose (jag såg din restauration av Bluenose) And as to me it seems to be an old AL version (för mig ser det ut som en gammal version of AL) However, the ship doesn't seem to be to damaged so it should be a fairly simply fix (däremot verkar det som att modellen är i ganska gott skick, så det borde inte vara så svårt att ordna henne) There are so many build logs of Bluenose, so you shouldn't have to many problems (Det finns så många olika byggnationer av Bluenose (både orginal och version II) så det borde inte vara några problem för dig. If you have any sort of question in with Bluenose, this is the site! (Om du skulle hava någon fråga beträffande Bluenose, så har du hittat rätt!) Good luck to you work - looking forward seeing more!
  15. Mr. Pucko, I hope you didn't choke on the chocolate drink when you realized it. I wonder if there is an error in the laser cutting?
  16. Beautiful pictures, thank you for sharing. I miss visiting the area. It was easy when living in Europe, but now traveling from the West Coast of America there is so much more planning.
  17. Bill, There are ship parts in the pictures. Guess you got caught by the "surprise" ​
  18. Very nice! Looking forward to seeing what is next in the building line.
  19. Adam, This looks both interesting and very good. Guess I will be one of the first to pull up a chair, to watch this build.
  20. Thank you Chuck, I appreciate your fast answer. I was suspected the 24 but wanted to be sure.
  21. Can anyone shed some light regarding the oar locks as these are supposed to be made out of 26 gauge black wire. The material list only shows 24 and 28 gauge. Which size has been used on others longboat?
