Everything posted by Nirvana
Okay, I must have lost my mind, either the modell is extremely large or the the tools are very small. But the outcome - well I wish I had some top words for this. Just fantastic!
Julie, Don't use steam, use a hair dryer and the heat from it, Chuck is using that method so it should work for you too. However, with a steady pace you will be done sooner than you realise. Looking good.
Julie, Decide where she is to stand, then open up the ceiling for the part of the master, or make her an Admiralty version, like up the first spreader.
Julie, That's a very nice "wrap" Beautiful done! I know it's way down the list but how are you planning of attacking the mast, this considering the two parts that has to be joined and tapered?
Julie, that looks so good. A friend of mine didn't put in material between the bulkheads and got problem with the planking.
Amazing and extremely superb craftsmanship!
I wouldn't worry to much about rugginess and roughness, use a light touch with steelwool on top .... not to much and you will have a surface that will with time look amazing. This looks real good!
- 143 replies
Arbortech Power chisel
Nirvana replied to John Allen's topic in Modeling tools and Workshop Equipment
This tool is still sold by WoodCraft, in store running at 260 dollars. At one time my local store had a demo of the machine with a "person representing ArborTech", unfortunate he broke three machines within half an hour. He couldn't believe it and claimed it had must happened during the shipping. The local store owner was extremely unhappy and canceled the remaining one and half hour of demo giving out vouchers for 50 dollar in store for tools for 8 people that had shown up. What happened afterwards I have no idea. Personally I bought hand chisels and got additional rebate. -
Hobbyzone building slip for wooden ship models
Nirvana replied to aydingocer's topic in Modeling tools and Workshop Equipment
Here is the link for our fellow members located in the USA Minislip -
Papegojan 1627 by mati - FINISHED - 1/48
Nirvana replied to mati's topic in - Build logs for subjects built 1501 - 1750
Mati, I don't have any words to express your delicate finish. Outstanding! -
Aydin, You mentioned to put fiberglass/epoxy on top of it all. I think that will cover the beauty of the mahogany. I would recommend to abort the planking, take of the current strips off and start over again, working with epyxy instead. I am afraid you are to experience problems with the exposure against the water. Specially after all the nice work you have put in. Another area to work is the one around the prop and rudder shafts, this before any second planking. When I build my T37, the instructions read - epoxy cover all the inside. Even though I have only used epoxy I have a problem area on the deck where water finds its way in. Oh, as for clear finish, I used marine varnish on all, none painted area. It is just my two cents for what ever they are worth.
- 414 replies
- riva aquarama
- amati
A Lorch Micro-Mill that never was ...
Nirvana replied to wefalck's topic in Modeling tools and Workshop Equipment
Pure artistic, I have no words on how to compliment you for this amazing tool build. Beautiful! -
Aydin, Don't make it to thick!...... carefully with mixture as this is almost like science
- 414 replies
- riva aquarama
- amati
Joe, Most woods yes, some are more prone to spring back than others. I used water and heat in combo for my Longboat, next build I will try the heat option only. Wood will expand in water; once drying, strips can get a little shorter and also the width. It may not be much, but can have hull twisting issues where you have "spot glued" to frames. Only my two cents
Aydin, Keith has a point here, which I think many of us never thought about when you started your build and specially going for RC version. Some of us in here has built RC boats; including me, see my T37 sailing yacht. I never used anything but Epoxy! It is messy, but it is a guaranty from water damages. I just recalled the instructions from my RC build. Even the inside of the hull must be treated otherwise you will have problems in the future. Water will always finds it way in! Otherwise beautiful build!
- 414 replies
- riva aquarama
- amati
Aydin, That looks so great, looking forward to next part of the build.
- 414 replies
- riva aquarama
- amati
Tony, Very nice approach for the "waterline display" Looking forward of more.
- 269 replies
- Caldercraft
- First build
(and 3 more)
Disappearing lines in drawing
Nirvana replied to Mark P's topic in CAD and 3D Modelling/Drafting Plans with Software
Mark, Any cad program can have this issue, and it's the connecting nods no matter layer. One of the nods got connected with another in a hidden layer. To solve it is to go through each layer making sure all nods are closed and connected. Otherwise as you write, start again. Good luck -
Mike, Even though the laser burns will be covered, many of us has experienced less contact with glue when charded. Using a combo of CA (spot (like spot welding)) along with wood glue and your structure will be solid. Clean up any wet spots from glue before setting!
- 143 replies
Okay, not that we are supposed to used cursing words in this forum. but what the $#@$#&*%$ have I missed! These machines are absolutely crazy! What is the pricetag of the Micro Mill? Not that I can afford a regular one as of today, but I am curious. Must be in the price of an Aston Martin Db5 Vintage -
Just make sure you are sanding all the laser chard off!
- 143 replies
