Everything posted by Senior ole salt
Looks like a noble build coming up. I loved those DD . They escorted my aircraft carrier during deployments. IMHO all US Navy ships should be named after Medal of honor or Navy cross recipients. S.os
- 144 replies
- basilone
- BlueJacket Shipcrafters
Thanks Bob for the heads up. Glad you're OK. S.os
Thimble help needed
Senior ole salt replied to Senior ole salt's topic in Metal Work, Soldering and Metal Fittings
grsjax, Sounds good. Wish I thought of it sooner. Thanks S.os -
Michael and others, I continue to be awed by the craftsmanship show on this forum. and the ability to post it so well. S.os
- 2,215 replies
Wow !!! Daniel. All I can say is Bravo !! That was for me was a tension filled video. So glad it had a successful outcome. I might even try it but with a canoe in a wide mouthed opening. S.os
Peter , what an exquisite little boat. Same for the paint job. It looks cozy enough to live aboard in comfort. S.os
- 109 replies
- zeeschouw
- billing boats
You ain't kidding me Gary. You got some miniature shipwrights working for you. Probably space aliens, and all master shipwrights from some distant planet. Outstanding and thanks for posting it all. S.os
That sure is an impressive build you got there Mike. Thanks for the post on the thimble making. How did you anneal just the center portion ? S.os
- 2,215 replies
You're going great and I admire your diligence in posting your progress. S.os
- 569 replies
- shenandoah
- corel
Dannyboys, You also might look into this book available though the internet, http://books.google.com/books/about/The_Junks_and_Sampans_of_the_Yangtze.html?id=VzpJAAAAYAAJ S.os
Thimble help needed
Thanks for all the good tips in solving my problem. I decided to go with the simplest, a kind of a combination of the suggestions above that is: Take a strip of copper (soft) cut about 3/32 wide and suitable length to make the desired eye. I filed one end to a sort of blade or better yet a "scarf". I then bent it around a twist drill with a 1/8" overlap. I then sodered the assembly together. To mount it in place on the model I first formed the rope grommet,and seized it in the "thimble with thread. Right now it resides P & S on the model . If you look real close you can see the thimble has no flange, but tell anybody. Thanks Pat,Jud,Ulises,Bart,Druxley,Antony S.os -
One particular detail that is giving me trouble on my New Bedford whale boat has me stumped. That's the thimble needed to furnish a tying point for the boat's erected mast shrouds. It needs to be about 1/8" inside dia. I tried the method outlined in Mr. Ronnberg excellent book but it doesn't work for me. Are there any other methods to achieve making this round thimble ? Thanks S.os
Received this video I'd like to share. https://www.dropbox.com/sh/4zkp7hvrgbcd7gd/D-qPNsG9ym#lh:null-Laffey%20Enhanced%20vo%203.wmv S.os
What is the staple bolt for ?
Senior ole salt replied to captainbob's topic in Masting, rigging and sails
Bob, maybe it had something to do with getting the dories over the side. Check out this video. S.os -
Joe , good idea about the name plate but I may go with a fancy shiny brass one .. a bit of contrast i think. Thanks Jay for the offer but this model has a promised destination. Overdale, I tried the tea solution on the sail and it worked OK . Now I'm going to figure a way to soot up the furled sail, like smoke from the try works got on it. Mark Here's one putty cat but he;s too big. It looks like I'll have to whittle one. Thanks all for your interest. S.os
I've making slow progress but the finish is near. I obtained the weathered mounting board ( cherry) a imitation sperm whales tooth. The images shown below are missing the various line tubs, buckets and piggins that go with this model. The tubs have their lines faked down but I still have to "weather" the hoops. Also to soot up the sail some to kind of get some of the grimy whale blubber being processed aboard the whale ship. S.os
- 39 replies
- new bedford whaleboat
- model shipways
Captain Bob I googled staple bolt for schooners. I got this: http://books.google.com/books?id=tmGcfkEBNLIC&pg=PA84&lpg=PA84&dq=staple+bolt+on+a+schooner&source=bl&ots=V-TH99pUxs&sig=aHjC2_J_xzfzkSOEg76U2OhO6Xw&hl=en&sa=X&ei=P3MJU5nUBJHlygGUr4Fo&ved=0CCkQ6AEwAA#v=onepage&q=staple%20bolt%20on%20a%20schooner&f=false A bit long but I think your answer might be in there some were. Good Luck S.os -
Stunning work. That cage type mast rivals the Eiffel tower in beauty.
- 116 replies
- kilkis
- mississippi
