Very nice work Steven, amazing what you are producing with simple tools (and patience).
cheers
Pat
Beautiful work on the  xylokastra.
Adding decking and ladders to the xylokastra. The uprights of the ladders double as supports for the beam carrying the rear of the deck. (The rungs are made from toothpicks).
Steven
Edited by Louie da fly
Nice work Steven,
An idea from me
Use wooden clothespins for plastic models and plastic clothespins for wooden models.
if you use clothespins of the same material as your model, then they can sometimes gleu together.
learns my experience ;)
I've been working on the xylokastra. The first photo shows them with the decking added.
Here is the framing for the parapets/battlements to protect the marines in battle. First the framing members were cut to shape and all the identical ones glued together - the long ones are the horizontals, the short ones are the verticals. Then grooves cut into them where the mortises were to go for halving joints.
Using isopropyl alcohol the glue was dissolved and the members separated.
More framing members, including the ones for the sides and top of the parapets.
The frames assembled
and ready to put in place.
Steven
I've now added the framing for the xylokastra parapets and started on the planking.
Laid the assemblies on the tabletop to glue the front parapet frames on.
Here they are in place
The glued the sides of the parapet frames on and held them in place with pegs.
Here they are - frames complete
Steven
It's like you are building a palazzio ... must have been hard to fit it all together without breaking anything ... very impressive Steven
Carl
A problem from an earlier step got in the way - the tops of the columns were only butt-jointed to the rest of the assembly. Look at what happens when you use flexible PVA (white) glue.
I had to use some kind of pin or peg to join the columns to the rest of the assembly. The smallest drill I could get was 1mm, so I needed a 1mm peg. Couldn't find any, so I made my own from bamboo toothpicks.
Size checked against a 1mm hole.
20181220_084003.thumb.jpg.d33a99cb593d199048c6c4b43b1695c8.jpg 20181220_084534.thumb.jpg.4225ca064b380f1c4706bddabb7ba0dd.jpg
Peg inserted in a hole drilled in the top of the column and glued in place.
 Hole drilled into the capital and the xylokastron framing above it.
Peg inserted and glued into the hole in the capital.
A bit labour intensive, but it seems to have worked. Pushing the outside of the envelope, though, with the (pretty basic) equipment I've got. Getting the holes centred and in line was very difficult.
Unfortunately I can only do this at the corners of the xylokastra, where there's enough "meat" above th columns to take a 1mm hole. With the other columns I'll just have to be very careful to make sure they're vertical before I glue their bases in place on the deck of the ship.
Steven
You have done remarkable work with a limited toolset Steven; congratulations are well deserved.
Merry Christmas
Pat
Thanks for all the likes, and thanks Druxey and Pat for the encouraging comments. Very much appreciated, particularly with what turned out to be a very frustrating stage of the build.
Well, I've finished the xylokastra at last.
Parapet planking nearly complete on the first one - with a crewman for comparison.
Planking complete.
I sanded it all smooth, but it looked a little bare, so I added some horizontals nominally to strengthen the structure but really to make it look better.
Another column came loose, so I "pinned" it.
I ended up doing this to all the corner columns, and even then I had to repeat the procedure with at least one of them because the pin broke. Next time I do this (for the forecastle or pseudopation) I'll do the columns last, because a lot of repair had to be done to damage which occurred while I was working on the superstructure. And I'll carve an integral pin into the end of each column to hold everything together, rather than (a) butt-jointing the tops of the columns and/or (b) drilling holes in the tops of the columns to add the pins.
The same problem came up with the corner pieces of the substructure, and in future I'll pin these as well.  As you can see below the corner piece came away along with everything attached to it as I was working on the superstructure, and the whole thing had to be repaired.
The first xylokastron complete.
20181228_154323.thumb.jpg.b37505f2cfc49b5af7a87a6c1fe25de7.jpg 20181228_154311.thumb.jpg.2d53cfe263c2de805899cf18ed0a5958.jpg
The second one under way.
And a comparison with the finished one.
Both xylokastra complete and inhabited, with a crewman, a Varangian guardsman and a flute-player (for giving the rowing pace to the oarsmen). These aren't the guys who will be there - they're to go elsewhere on the ship. In fact I might leave the xylokastra completely uninhabited, as the vessel's not in combat.
20181229_175725.thumb.jpg.0b0ab07ef65affcb27700fc194356eb8.jpg 20181229_175738.thumb.jpg.360ac3cb72e1d0dc647d7a5f01394cb4.jpg
It's been a long and difficult process, but I've learnt a lot while doing it, which will stand me in good stead later in this and future builds.
Steven
Steven,
although it is a wooden built you could use part of a sewing pin to pin or strengthen such pieces. if the wood is soft enough, you wouldn't even need to predrill
Carl
They have come out very nicely Steven; your persistence has paid dividends.  Every sub/mini-project is a learning process; the next batch should be faultless masterpieces then ;) :)
cheers
Pat
Thanks everybody for all the likes.
Cog, unfortunately the wood is as tough as old boots, so I can't just shove a pin into it, much as I'd like to. And the smallest drill bit I can get is considerably larger diameter than a pin, so it would slop around in the hole.
Druxey, Pat and Patrick, thanks for the comments. And Christos, Ευχαριστώ πολύ φίλε μου.
Best wishes to all for the New Year,
Steven
Started work on the pseudopation (forecastle), making use of the lessons I learnt making the xylokastra - such as making the deck and parapet before I make the supports.
Here's the cardboard mock-up (version 2) along with the lion's head which forms the outlet for the nozzle of the siphon for Greek Fire (which will be added after the structure is complete and in place).
20190103_122142.thumb.jpg.30c995645a0ca0b008ba0e624c04d8a1.jpg 20190103_122155.thumb.jpg.481ae177cf8c083ea8781b9306045563.jpg 20190105_104455.thumb.jpg.6d5868baf5ad4e52dd2f0d10e617e488.jpg 20190103_122303.thumb.jpg.04d880655bbe2ccb1f5753be89869b0e.jpg20190105_104645.thumb.jpg.82ac02b17dfb7b6ac0883447e2aec7ad.jpg
Deck structure,
20190105_212021.thumb.jpg.fadafc065d8e8b7a537cc539f582edd2.jpg 20190105_225137.thumb.jpg.362de3d66445ac3ccfec804569bb0ccf.jpg 20190109_192545.thumb.jpg.41452e84d67388ada7e01c1305e77fa6.jpg
Decking added
20190112_192940.thumb.jpg.c44f2cb9e46bedd62977bdad87d26489.jpg 20190113_201452.thumb.jpg.65c1eb55c514f923ef55241eb0e463b4.jpg 20190114_083751.thumb.jpg.38156a96e528edea0723a3cb22eb4e04.jpg
And in the meantime for a break, a bit of carving - the Emperor's second Viking bodyguard.
20190105_212320.thumb.jpg.4e043dba19bded7460635ed8664d78c8.jpg 20190105_212603.thumb.jpg.46b1b303e9d2eca4b8da91c8f5635ac7.jpg 20190112_193145.thumb.jpg.94cada87c11ab09247bd4bfe80e75ce0.jpg
20190115_113309.thumb.jpg.b12d860cbb7c226a5ae6890a34509189.jpg  20190115_113528.thumb.jpg.f2bfcfc71bcbcdc5a43f35c395d5195b.jpg 20190115_113542.thumb.jpg.b21ac6f225c42f1ca6188e7b87a80ba5.jpg
More to do, but coming along nicely. I believe the faces are getting better as I gain more experience, but the magnifying headpiece has made a big difference as well.
Steven
Thanks for all the likes and encouraging comments.
I think I've come a long way since the first figure I did for the ship (which I now consider not good enough to be included).
Christos, I've got quite a few figures made now - they're scattered through the build log. The helmsman is incomplete till I get the steering oars in position (I have to work out exactly where his arms go), and the seated Captain probably won't be included now because he has to give up his seat when the Emperor is aboard.
20190116_083618.thumb.jpg.6d8037657e0d20be289a56c380c1f424.jpg 20190116_083626.thumb.jpg.f71ff628e808c7aea06237157516b792.jpg 20190116_083636.thumb.jpg.633f6c9c4101443c96278b40a18a7294.jpg 20190116_083654.thumb.jpg.5a408284605cb3a68376a335746f918c.jpg
There was a quantum leap in the quality when I got the magnifying headset, though. Though I'd carved wooden figures before, I'd never tried to carve anything that small with that amount of detail, and the headset made it so much easier to see detail. Compare the face of this guy with the Emperor and his courtiers and bodyguards, which I made after I got the headset.
Steven
Quite the crew and dignitary ensemble you have there Steven; they look good and far superior to anything I could carve.  As you say, the more practice and times repeated certainly improve skills.
The pseudopation  is coming along very nicely also.
cheers
Pat
Steven awesome! The figures are just awesome. Be prepared am going to place you an order of my next kit's figures. What it will cost?  Dont care... any price shall be lower than what your work worth 😁.
About that magnifying head set.... dont tell me about it! I bought it last year and since then, every time I use it, I keep say to my self : "I was blind and I saw light" 😎🙄
Latest progress on my Varangian guardsman. I've done my best to simulate mail (NOT chain mail, please - that's a term invented in the 19th century and unknown in the Middle Ages), but it's rather difficult.
To show what real mail looks like and at the risk of blowing my own trumpet, here's a photo of me and my Hearth troop when I portrayed Leofwine, the brother of King Harold, at the re-enactment of the Battle of Hastings on the actual battlefield on the 940th anniversary in October 2006 (I'm in the back row, fifth from the left, with my hand resting on the axe-head.)
To duplicate that isn't easy in a carving at 1:50 scale. Here's a few contemporary carvings at a considerably larger scale (probably 1:1)
image.jpeg.f152f66ec99113f22fc7def05f6f719d.jpeg   Related imageImage result for chain mail in stone carving
I first did a test piece on the figure I'd already decided wasn't good enough to go on the ship. Here's one method, which didn't satisfy me:
and another, which seemed to work better:
and here's the guardsman with the mail in progress:
It's a bit coarse and I'm not sure if I'm totally happy with it, but at this scale anything with a finer "weave" is likely to be invisible. I'd hate to discard this guy after all the hard work I put in - we'll see how it goes when he's finished.
Steven
