I started the day ( very early ) by cutting the Frames for the Cockpit Floor. ( there is a gradual slope from the Bow to the Transom ) I then cut the Frames, and installed the Cockpit Floor. I then turned my attention to getting the camber set for the Deck. Next I installed the Deck starting at the Bow and working my way back toward the Transom. I then added the scarf to the sides of the Deck ( both Starboard and Port ) Next I made sure that the Bowsprit slot would work accordingly and then installed the bow section of the Deck. I then installed the Cockpit sides up to where the Cabin Bulkhead starts . I then faired the Deck in with the Hull. Then did the same with the Cockpit. Next will be to lay out the Cabin . Here are the results
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Herreshoff Buzzards Bay 14
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
I am glad to come across your new build Pete.  It is refreshing to see a modern racing ship every now and then.  Your hull looks like a sleek thoroughbred ready to run a couple of laps.  Okay if I joint the rest in looking in on your build I should learn plenty from it.
David B
That profile shot looks like a speedboat from the '30s.  No wonder they're fast.
Bob
Current build:  SS_ Mariefred
Thanks David B. , I think it would be great to see more people building Modern Sail Boats. She is definitely sleek and built for speed , and you are more than welcome to join in on the fun.
Thanks Cap'n'Bob, I noticed that as well ( 30's speedboat) and they are fast boats
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
I will start by saying this is the most difficult Boat I have ever built. It took 3 days to get the Cabin figured out ( lots of angles and curves all converging on one spot ) it worked out and will be a lot easier on the next one. ( there will be a next one probably a free sail version maybe Team Brunel graphics I am not sure yet ) the deck and cabin have been painted a Flat White ,and more sanding will be required . I made the cradle, she almost ready for the Keel and Rudders. Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Pete that is a slick looking hull, I am always amazed at how fast you get these models built.
Michael
Thanks Patrick, I can see what you are talking about , it looks like it could be in a Marvel Comics movie . esp with wheels
Thanks Michael, I am pleased with how she is turning out , I think she is very sleek
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Today, I decided to get back to work on the Volvo 65, I started by sanding the Deck up to 600 grit ( starting with 220 ) then prepped her for another coat of paint. I then turned my attention to making the bowsprit . I then sprayed a coat of flat white . once dried I checked the bowsprit for a good fit . Next will be to get started on the Hull graphics. Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Looking very sweet.
Michael
Thanks Michael, Shes coming together
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Thanks Patrick, We are almost there , I bet she sails great. I am thinking I have to do a free sail version just to see what she can do
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Really nice model. I took the time to have a look in your other logs. Really intersting,I didn't know Herreshoff before.
Regards Christian
Thank you Christian, If I am not mistaken Herreshoff designed more America's cup winners than any other designer, and some of the most beautiful pleasure Boats that I have ever seen
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
 I had not worked on this one for a while, so I thought I would set up to do the Hull graphics, and realized that I had some small gaps primarily where the Hull and Deck come together and mostly where the planks converge at the Transom. So I made up some filler, using sawdust and titebond 3, I then applied it on the gaps, Sandedup to 600 grit (once dried) and applied another coat of Flat white , Now I can set up for the Hull graphics . Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Thanks David B., I have been taking my time with this one, and I have been happy with how she is turning out
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Every edge is clean and sharp.  She's really looking good.
Bob
Thank you Gibbs, This has been a challenging build ( I always like a good challenge ) pull up a chair there is always room
Thank you Cap'n'Bob, Sharp edges and clean lines are key to this build , I am happy with how she is turning out .
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Thank you Marc, I think these Volvo 65's are amazing. an incredible design ( very sleek and fast) and with the completion of the Alerion, I can now focus on getting this Volvo Finished
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Today, I started by getting the Hull prepped for the graphics, The first step was to lay out the angles ,to establish a starting point. I then took masking tape cut the appropriate angles and widths ( to match what is shown on the plans ) I then applied the strips to the Hull , I then masked off the deck and shot 2 coats of flat black . And after waiting 2 hours I unmasked the Hull to reveal the desired graphics. The next step will be to apply the logo's to the hull, and to make the Keel and rudder blades . Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Sweet paint work.  The graphic look great, Pete.
The angled white really says speed.  Well done.
Bob
Thank you Mark, I am pleased with how the graphics turned out , there was a lot of masking ( very time consuming )
Thank you Patrick , Crisp clean lines are key to this build , so far so good
Thank you Cap'n'Bob, She looks fast just sitting in her cradle , I was surprised at what a difference the graphics made
Thank you Jay, I appreciate it . She's coming along rather nicely
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
