G'day Nils
Again bravo on another outstanding piece!
Is the small bridge on the side of the captain's cabin a bridge to the lifeboats?
Current builds
-Lightship Elbe 1
Completed
Beautiful work.
Bob
Current build:  SS_ Mariefred
I`m very pleased that you like the progress Bob,
Thanks for your compliment...
Nils
Current builds
-Lightship Elbe 1
Completed
Thanks Greg,
I know a picture is saying more than many words, and here is still a lot to do to get the model look this way....
Nils
Current builds
-Lightship Elbe 1
Completed
very nice progress Nils  ;)   very nice indeed!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you very much Denis,
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you very much Ed,
for your nice compliment.....
Also thanks to all the "likes"
here is an Update :
I was busy and I`m beginning with the 4 stacks, they will be made from 26 x 1,5 mm alumimium tube. But first the rings for taking up the upper funnel stay fastening points have to be made. They will slip on, 3 per stack, and secured with low viscosity CA (aluminium / Brass connection), hopefuly not generated electro chemical corrusion afterwards...
The rings are made from 2 x 1 mm half-round brass profile, guess the included pics are self explaining......
Nils
the profile is heated and quick-quenched under cold water, to get that anealed condition frozen in
to compensate that remaining spring-back effect, the coiling is rolled with a thinner dummy tube
the loop is cut to overlap for about 4 mm (canfer and bevel ends of soldering area)
the ring is soldered together and slipped on to the original funnel tube for drilling the "stay pass through" holes. The holes arrangement is per pattern (8 holes per ring)
the final ring drilling is done on a dummy wooden dowel
just ran out of half-round brass profile....
a bit tricky to drill that half-round profile from the convex side, lucky, no scap so far...
status overview...., upper bridge wheelhouse with nav- and charts room is on...
Current builds
-Lightship Elbe 1
Completed
Fantastic work....
Current build:
Finished build:
Current build(On hold):
The rings look good, fine drilling job.  I love the picture of the ship.
Bob
Quite the jeweller you are Nils. Some exceptional fine work on those rings. If you have a film of CA in between the brass and aluminum, the chance of the elctro chemical corosion is nill. As water is a requirement as a transport medium, and I presume you are going to paint the funnel, I wouldn't use acrylic paints on them.
Carl
many thanks Bob and Bob,
for both your nice compliments....
I`ll put in an overview pic appr.
once a month, if its worth showing the progress....
Nils
Current builds
-Lightship Elbe 1
Completed
Thanks Carl,
that sinks my doubts to zero for possible electro chemical corosion. You`re so right, one of the three "knockout criteria" is the missing electrolyt in this case.
The final paint coat will be resin based paint (Kunststoffbasis Farbe)
Nils
Current builds
-Lightship Elbe 1
Completed
Man..... :o  B)  :rolleyes:
Current build:
Finished build:
Fantastic work....
Thank you very much Rob,
much appreciated...
Nils
Current builds
-Lightship Elbe 1
Completed
again, many thanks Rob,
Nils
Current builds
-Lightship Elbe 1
Completed
Hello Nils,
Caught up again and congrats with the closing of the hull, a major milestone indeed.  And then some fantastic additional builds to feast our eyes on.  She's looking really splendid my friend.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
thank you very much Piet and Greg,
for your nice compliments...
Also thanks to all the "likes", much appreciated...
Piet,
thanks for looking in and catching up, I`m pleased that you like the model...
Greg,
nice comment and compliment, thanks very much..
Nils
Current builds
-Lightship Elbe 1
Completed
Update :
funnel sockets and some vent enbeddings on the upper deck, also doing a bending template for one of the upper platforms (with waste 8 mm copper stripe), before bending the rather fragile and  expensive etched railing material...
The vent tubes still have to be cut to length at a later time
Nils
here the first raw funnel socket comprising the short center dowel, with 10 ° backward rake, (the hole made with the hole-saw tool as introduced before)
The structures are made from 7-layer water tight ply.
The socket design worked out exactly  as it was intended to be
the bottom funnel-end will be shifted appr. 12mm into the foreseen close-fit socket
the centering dowel sits rock tight (glued) in the structure plate
these are two of the four largest vents on the ship, bringing required amount of air down to the boiler furnaces.
Member, Bill of Idaho, will probably have noticed that here the "Brad-Point drills" have come in the game  for making the clean cut vent-tube holes.
here the wooden layers can be seen quite well in unpainted condition....
this is a bending template for the railing of one of the upper platforms, before bending and glueing on the etched railing
Current builds
-Lightship Elbe 1
Completed
Hello Niels!
Your doing an absolute amazing  job especially in metalwork.
I think that I will have to ask you for help in this, for I am going to prepare my next project. That will be the Gorch Fock. And in building her there will be a lot of metalworks ( reling,vents and so on)
Best regards
Angarfather / Hartmut
on the : Staatenjacht Utrech
At last finished:
Gianna a Pinco Genovese
HMS Agamemnon
Hello Niels!
Best regards
Hi Hartmut,
thanks for your nice comment, and I`m pleased to note that the Gorch Fock 3-mast barque will be your next project. You do her justice as she was nearly sentenced for break down these days ( now repair has been luckily approved once more)
I will be pleased to give any assistance I can, feel free to contact me whenever you wish....
Nils
Current builds
-Lightship Elbe 1
Completed
Wonderful stuff Nils, just love that shot showing her in all her magnificence :)
B.E.
Thank you very much B.E.
for your kind compliment, I`m pleased you like the build. It is in the moment hauled alongside the fitting out quay of my yard..., workers processing at all corners
Nils
Current builds
-Lightship Elbe 1
Completed
G'day Nils
Brilliant work on the bending template! One question though, are there any 'bounce back' of the decking after you remove the template or have you taken that into account?
Havagoodone mate
Greg
"Nothing is impossible, it's only what limitations that you put on yourself make it seems impossible! "
Current log : The Royal Yacht Royal Caroline 1749 1:32 by Greg Ashwood:...
Hi Greg,
thanks for your nice comment. The copper stripe is in an anealed rather "soft" condition and stays just as bent (no bounce back). I am using two sorts of etched railing, one with 3 wires and one of 4 wires each plus handrail. The later is very fragile and  a few  mis-bends, staightening again and corrective rebending can cause the very thin wires to break. So its worth it investing in a bend template.
Nils
Current builds
-Lightship Elbe 1
Completed
You like complex things it seems. I see you've mixed brass and aluminum on your vents too. Looking forward to the installed funnels
Carl
