Brodie stove completed,
except for the chain to drive the spits its more or less finished, a bit more cleaning up and paint touch up to do
and in situ on the boat, now onto the fire bricks/plate and then back to knees-lovely
ive ordered some scale bricks from an internet site to see how they will look for the plate under the stove, not sure how to make the lime mortar as robin points out or even how to fasten them in but will have to experiment when they arrive
Paul,
your build is beautiful, the hull with all the woodwork and joinings is a pleasure to see, and the stove tops it all. Fantastic modeling !!
Nils
Current builds
-Lightship Elbe 1
Completed
thanks everyone for the comments and likes, a lovely restful 2 weeks in tenerife over, now back to work and hopefully some ship building
The clerk of the cheque's yacht of sheerness
Current build HMS Sirius (1797) 1:48 scratch POF from NMM plans
HMS Winchelsea by chuck 1:48
Cutter cheerful by chuck 1:48
Previous builds-
Elidir - Thames steam barge
Cutty Sark-Billings boats
Wasa - billings boats
Among others 😁
  • 1 year later...
Wow, I can't believe how long it is since I last made a post here, I have been keeping up with peoples logs and incredible work going on and been doing some work on my own boat, recently I have finished the pumps and associated brass work and have bee making the 26 Ft cutter over the last few weeks
Merry Xmas and a happy new year to everyone and I hope it won't be as long until my next post
Regards
Paul
Ps excuse the dust and hopefully I took some better pictures of the pumps which I will upload next week
Previous builds-
Among others 😁
Thankyou Mike, definitely not abandoned and some more pictures to come
Regards
Paul
Previous builds-
Among others 😁
Small update, starting on the quarterdeck beams
And she has all her teeth with breeching ropes
Previous builds-
Among others 😁
I've had a couple of weeks off from Sirius and the cutter over Christmas under orders from her who must be obeyed, she suggested I made something for her mother as she is more into the boats that I'm making than the wife, in fact she has my old cutty Sark on her mantelpiece, I found on eBay a constructo kit for a Thames steam barge, the model had already been started and all the frames etc were missing but for £10 I thought what the hell
As we live in Cookham which some of you may know (Druxey does) we are on the side of the Thames so I thought this wold be perfect for her, it arrived the day before Xmas eve, I cut my own bulkheads from the sheets still in the box and laid the first plank at 12.15 on Xmas eve
This is the finished job today and I'm giving it to her tomorrow as a belated Xmas present.
Previous builds-
Among others 😁
Then the boss said cushions, so now we have cushions
Previous builds-
Among others 😁
The kit had a lovely cast wheel which I thought not good enough, so now it has one of chucks 24 mm boxwood wheels as the "piece de resistance"
Previous builds-
Among others 😁
The 24ft cutter is nearing completion so I have started cutting the bulkheads for the 26ft cutter and pinnace, I'm using chucks version from his longboat with bulkheads and a false keel that is sanded down afterwards
Edited by paulsutcliffe
Previous builds-
Among others 😁
Thanks Druxey and thankyou for visiting after such a long period of inactivity on the site
Previous builds-
Among others 😁
Bulkheads for the 26ft cutter cut out on the dremel scroll saw and then sanded, I've also added a tenon at the top for a strengthening and clamping aid down the centre, which can be seen on the right with a couple of frames already added
Previous builds-
Among others 😁
All bulkheads fitted and first planning going on, planks are 0.5x3mmWP_20180119_19_34_47_Pro.thumb.jpg.2146d3f7615c395eaaaacb3b072441b0.jpg
And after a light sanding with 600 grit
WP_20180119_19_40_48_Pro.thumb.jpg.aac664ad724e6af2ac867fe8803c4b5f.jpgWP_20180119_19_42_16_Pro.thumb.jpg.9feb8b4046b5d7005c2319cd1f9ccc5e.jpg
Previous builds-
Among others 😁
With much trepidation I got the washstrake on the 24ft cutter, actually went a lot easier than I thought, much cleaning up needed but it certainly makes the boat look more finished
Previous builds-
Among others 😁
WP_20180120_17_25_43_Pro.thumb.jpg.5aa372c80938bb5b298d5f16e23387aa.jpgAnd carrying on with the planking for the 26ft launch
Previous builds-
Among others 😁
Planking finished and frames thinned quite a bit
I could/should/can thin them down some more but its rather frightening the planks are so thin, if you hold it up to the light you can see right through, I probably should have done the frames before sending the outsideWP_20180124_18_46_00_Pro.thumb.jpg.516b78834222f853e5be34b34f685eb0.jpg
Previous builds-
Among others 😁
So I bit the bullet and thinned them down as far as I could go, added some flooring to strengthen a little bit
Previous builds-
Among others 😁
I have realised that I am following the boat plans from the aots Diana the wrong way round, the first one I did in the background above will now become a rigged display model, the 24ft launch should be a two masted affair and clinker built planking, so I will have to redo that one and make the 26ft cutter with anchor winch at the back
All from mahogany so they match the syrius which will look better in the long run anyway
I really envy how all you people show such beautiful clean pictures, that last picture of mine looks awful with all the cr** in the background
Regards
Paul
Previous builds-
Among others 😁
So another one for the mother in law to look afterWP_20180203_18_07_54_Pro.thumb.jpg.15befdd28d0a46759e48d2f652d4a6df.jpg
Previous builds-
Among others 😁
26ft launch version 2 coming along
Planking and frames mahogany, all interior from boxwood, frames were  3 mm 3 layer mahogany plywood and have taken a lot of cleaning up and still need some more from the photoWP_20180203_17_44_46_Pro.thumb.jpg.c548e358da14fa4041c118b3efa257a5.jpgWP_20180203_17_44_53_Pro.thumb.jpg.39ac01062c4d4f5430375a411bf218a4.jpg
Previous builds-
Among others 😁
Haha, about all that c**p in the background... you should see my photos. All kinds of weird stuff. I think it makes for interesting thoughts "wonder what he will use THAT for"
Oh, and also, very nice launches Paul. Keep it up.
Happy modelling!
Håkan
Previous builds
Kågen by Wintergreen
Regina by Wintergreen
Billing Boats Wasa
Gallery:
