Very nice Kevin! Your planking skills are improving with each video.
When you measure the distance between planks to establish plank thicknesses it might be better to use tick strips. The digital caliper does not take into account the curve of the hull and will read shorter than the actual distance.
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
Take a small strip of paper and abut it to the bottom plank or planking line. Then make sure the paper is lying on the frame and mark where the top plank crosses. This is the true distance between the frames. This tick strip can now be divided into the number of desired planks in tick marks. To prove this to yourself measure the distance as you are currently doing on a curved section of the hull then compare with the tick strip method as described. You'll see that your measurement is shorter than the tick strip and thus your planks may be  narrower than they should be.
Greg
website
Admiralty Models
Finished build
Current build
Speedwell, 1752
Nice job!  Now for me to remember it all.
I was concerned about the metal end of your clamp maring the plank when turned to tighten and was imagining various ways to avoid it ... and then you showed the simple soft wooden nose piece add on solution.
Simple and effective... like everything you show us.
Thank you.
Alan O'Neill
The hull is shaping up nicely Kevin. On your next model (should you ever wish to plank again!) you'll learn how to install stealers and drop strakes to control the width of those planks at the bow and the stern.
Greg
website
Admiralty Models
Finished build
Current build
Speedwell, 1752
You forget that we did this on the internal planks. This would have been so much easier to do on the external planks but the book did not want us to use stealers, so we followed the book. I have to say this is the first time i shaped both ends of all the strakes  for the entire hull rather than force bending them into shape and what a difference it made. I was always worried that having to finish the open side of the plank would result in  irregular surface causing a difficult joint when the next row of planks was applied, but this turned out not to be so. I found  that the hand plane made it very easy to prepare a nice smooth line on the exposed side of the plank.
Looks very clean, a place for everything and everything in its place.  👍
I've learnt that whatever you do when cleaning up, ignore all urges to reorganize because you'll never find that special tool once moved.
Alan O'Neill
When you dont know what you are doing you can purchase all sorts of useless crap on line. I purchased the gauges along with the portable valves (just to cover my donkey) to set up the Chinese knockoff of the Smith Little torch. The oxygen worked fine but when i tried to connect the gas gauge (LPG) there was no local supplier that could accommodate me with the CGA 200 connection on the gauge.  Then i went to at least 10 different wielding suppliers and non could help me find an adaptor. Thank goodness i purchased the small bottle valves.
eventually i was able to hook up a medical oxygen bottle ( of which i have 2) to the Bernzomatic gas and got it to work. A real pain in the donkey
Looks like something I could do alot of damage with😏
Alan O'Neill
I was thinking the same thing here.
Ye gads, Kevin! Some really heavy duty silver soldering to come?
Seem a pity to hide all that framing, but the planking job looks very good.
