Back again from a short break, thank you all for watching & your nice likes!
The next steps for the large skylights are done, all window frames are ready cut, and the first grill is soldered. The large grills are a lot harder to make, they have 9 fields instead of only 6 at the smaller ones.
The frames, all have carved cutouts for the grills and glasses
All frames fit to the body og skylight
The grill for the first frame
Grill set in for a test before painting
Regards
Gerhard
Problems just mean: solutions not yet found
Models in progress
SMS DANZIG
http://modelshipworld.com/index.php/topic/12842-sms-danzig-1851-by-gerhardvienna-radio-150-scale/
USS CAIRO
http://modelshipworld.com/index.php/topic/13282-uss-cairo-by-gerhardvienna-live-steam-radio/
Baby Bootlegger 1/10
http://modelshipworld.com/index.php/topic/13625-baby-bootlegger-110-radio-by-gerhardvienna/
Swiss paddlesteamer RIGI 1848 1:50, after plans from the Verkehrshaus Zürich, rescaled to original length
Anchor tugboat BISON, 1:50, plans from VTH, scratch
Finished models
See-Ewer ELBE, Constructo kit 1:48
German fastboat after plans from german Reichskriegsmarine measure unknown (too ugly to show up!)
German traffic boat for battleships WW2, 1:50, after plans from Jürgen Eichardt, scratch
German Schnellboot TIGER P6141 VTH plans, scratch
awesome looking frames.........very nice  ;)
I use a flameless soldering iron too.......looks like the combustion level got too high on the last frame though.   looks good none the  less  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi Gerhard
Your build is outstanding.
It looks like you are using some kind of paper templet for your soldering.
Is it paper???
If so how do you keep it from going up in flames when you solder?????
Joe
Hi Joe
I use an electric soldering tool, so there is nothing burning. My wife would kill me doing that in the livingroom :D .........
Hi popeye
I use a lot of soldering wire for that grills, and grind them after soldering. So I get a good surface for painting, without the danger of breaking the grills.
Today the rest fo the grills were made, the last one still needs to be grinded, all will be painted flat black tomorrow.
Finally for today, the ordered pinewood has come, so I can start with the hulls frames :)
Thank you all for watching and all that likes!
Regards
Gerhard.
Models in progress
SMS DANZIG
USS CAIRO
Finished models
that's one wood I haven't tried yet,  other than plywood.   do you use it for hull planking too?   be interesting to see how it looks sanded and smooth.
windows look great!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
windows look great!
Hi Popeye
I use plywood when I build "normal" frames in the upside down method, but the CAIRO needs another way of making the frames. So i have to cut the frames from 5 x 5 mm "sticks", glue them in a form, and then set them to the keels. The planks will be made from 6 x 2 mm pinewood, this is very good for such works. Even bending them is easy, when they are wet enough, and sanding is no problem. More about that will com later, next wek will be filled with more work for my home renovation, so there will be not much time for the models :(
Today I will continue with the windows, thanks for compliments!
Regards
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
Again we go on.........
Homeworks took a bit more time than I thought, but there is always a way to do something at the Cairo build.
I finished the paint job on the windows and grills, and could also build the keels. The pinewood is very good for working with, not too hard for cutting, but hard enough for the keels and frames.
Skylight parts ready painted
The center keel
All 3 keels on the plan, everything fits well
Regards
Gerhard,
and thank you all for your kind likes & watching!
Models in progress
SMS DANZIG
USS CAIRO
Finished models
A Restart?
NO, just a continuation.............
After a nice weekend I could go on again with the Cairo. I made the first set of frames, but had a smaller mistake with them. I tried to glue them free handed, but they had too large differencies i  their height so I had to dismantle them. For the next try I made a glueing form, now the frames are all at the same height.
Thank you all for your nice likes and for watching!!
Regards
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
interesting jig  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
That's a great idea on the frame jig.  With that many frames, that jig will get a lot of use.   The frames are looking great.
A nice start made on the hull, Gerhard.
John
Hi John
Thank you! Will be a long way to go............
interesting jig   :)
Hi Popeye
I saw a similar jig in the building steps report from Bob Hill, but he used a closed jig, I wanted to excluse any mismatch of both sides, so i decided to make an open jig, and turn the frames after glueing one side. That way all the angles are equal.
Hi Mark
YES! There are a lot of frames to make, freehand work would not be good enough for that :huh:
Hi everyone!
Thank you all for your nice likes and comments again!
Today I made the next frames, No. 110 to 101 are done now, framework still continues. This will be a never ending story :(
Best regards
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
Hi again, and many thanks for your likes again!
Even today I made some more frames, 15 pieces are done at the moment, and a first test how they sit at the keels is also done. The keels have cut out seats for the frames, see the pics..........
Regards
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
Hi again, and thank you all for your nice likes!
The last days wrer filled with more frame making, the front frames from No. 110 to 85 are done, and the keels are prepared to that point. I will need even more time for the next frames, a lot of them is still to build..........
Frames 110 to 85
The keels with cut out frameseats
Cut first the central keel
Then the side keels
Ready done. The cutouts are 1/10th of a mm wider than the frames are. This will allow me to mount the frames easy to the keels.
Regards, thank you for watching and your comments and mybe critics!
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
Do you dream frames?
During coopering, when I first draw, make "rivets", cut and glue over 4000 pieces, I meet a pain itself.
Again, when making planking strips for decks
Your work is more delicate, and at the same time, much harder, demanding much more patience
How more to go?
Edited by Nenad
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
How more to go?
Hi Nenad
I`m dreaming, breathing, eating, living frames, I AM FRAMES :o !
There are a lot more still to make, but the first 31 are done.
Hi again to all my visitors, and thank you for your nice likes!
Today I made the next frames, including the first frames for the boilers. They are a little different to the "normal" frames, and need more work and pieces per part.
Boiler frame in the jig
all 31 frames set to the keels for a test
Regards
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
I don't think I would have the patients to do that many frames! Great job!
-Elijah
Current build(s):
Completed build(s):
Model Shipways Phantom
Member of:
The Nautical Research Guild
Dam that is a lot of frames
Hey Joe............ :)
Indeed, and there will be a lot more of them in different looks. When it comes to the rear end there will be the waterway, the narrowing to the stern and the location for the wheel, all that things need different shapes of the frames inside and outside silhouette.
Hi Elijah
Thank you!
Patience is what is most needed for such a big project. Somtimes the frames makning can be really boring, but there is no way to avoid that.
Today I made some more of the frames, but no pics from them. It would only be just the same as the last photos. More interesting things will come, when I go to the building board, to set all that things to the keels, this will be a nerve wrecking stage for me...........
Thank you all for your visite and that many likes!
Regards
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
I see you've increased the spacing.......are you going to continue with wider spacing till you get to the stern?   repetitive work is a bear.......but when fared and ready for planking,  your going to be happy how it will come out ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi Popeye & all interested too
I will not need all the frames in the mid section, it`s just straight. At the stern will be more frames, every second from the plan will be placed there. The space between frames 2 to 5 is really close, so I will replace frames 3 to 1 with a full piece of wood and grind that to shape. The last frames are done, today I can start with re-examine them all, and then fit the whole things together. More will come later today................
Thank you all for your visite and likes!
Regards
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
It`s a bit late for "today" as I meant yesterday, but re-examining and overworking the frames took longer than I thought. Now they all fit well to the plans, and I can start with the building board, prepare the plans, and fix the keels to the board. Next photos will come when I`m doing this, then the real work starts!
Regards, and thank you all again for watching & likes!
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
Back again with more.............
The plan sheet is fixed to the board, the keels are clamped to the plans, and some frames are glued to them.
Plan on the board, fixed with flat nails
Center keel fixed with wooden clamps
Each of the keels is held with 2 of this wooden (homemade) clamps
All 3 keels on the board
A few frames are glued to the keels, more are to see in the background
Thank you for looking in, and yor likes and comments!
Regards
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
Nice! She's coming together!
-Elijah
Current build(s):
Completed build(s):
Member of:
Hi Elijah
Thank you!
She MUST come together :) , now the work starts. In times I dont glue frames to the keels, I`m studying plans and drawings from sternwheeler engines, so I will be able to draw and construct my own machine. All the plans I know at the time show too large engines, so I have to make a full new one.
Regards
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
Looking grand, Gerhard.  Will you be cutting notches in the rest of the keel for the frames?  If so, how?  I'd think it would be easier to cut them before mounting to the build board.
Hi Mark
I dont think I will need more notches. I have made the cutouts for over 40 frames, this will be enough for a good stability. Most frames are set at the bow and stern sections, less in the middle, but the whole hull will be stiffened with 2mm plywood inside, and 2mm planks outside. So this will be a really solid hull, strong enough for the steam equipment. No new pics today, just setting frame after frame after frame....................
Thank you all for your interest & likes!
Regards
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
Hi Gerhard,
well done!
Hello Johann
Thank you! Have set more frames today, still going on with it. This will take some more days...................
Regards
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
nice to see her in the assembly stage Gerhard.   that's a large hull your build'in  ;)   love it!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
