Well, perhaps I'm mistaken, so I've sorted out a selection of files and will post them in the following few posts.
Again, if anyone has any questions on what the heck I was doing up to now, please don't hesitate to ask.
John
For someone whom lost his images ... you are doing rather well. It seems you had to rebuild her from the start to get these on screen ;)
It would really have been a loss if this build log would not have reappeared
Carl
Now that's better John!  it seems that Stag is properly home now.  Thanks for taking the trouble to re-post your wonderful work - there are many of us who admire and learn from it.
Cheers,
it is good John,  that you put the pictures back up.......no matter the order.   It was the content of this build,  that made her so special.  now there will be no more questions,  as to how she became so beautiful.......superb work,  my friend!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi John,
Great build. I have been one of those who watch from outside of the ring.
I have question as to the Stag. She was  a Cutter by build and appears to have a clinkered hull. In my observations Sloops are similar in nature and build to a cutter. a difference I am seeing is the difference between the two the texture of the hull Cutter being a clinker planked and sloop being smooth planked. Is this a fair observation and does it hold true?
Dale
Dale,
The Stag is actually carvel built.  Although a lot of early cutters were clinker hulled, the plans for the Stag show her very clearly as being carvel.
In theory, the difference between a cutter and a sloop (bearing in mind that in the 18th century a sloop could also be a small three masted ship) was that the cutter had a running bowsprit while the sloop had a fixed bowsprit, however in practice the terms seem to have been used rather loosely.
Falconer (Marine Dictionary 1780) lists a cutter as a sloop rigged vessel used in the south of England by smugglers and by the customs service.
John
Thanks John
That does make a little more sense. I think I now have it. It was not the cut of her build the determinded her Identity but the way she was rigged.
Again Thanks, Stag really does look the part.
Dale
Thanks for the pictures,John.  Now we are back up to speed and waiting for the new work.
Bob
Current build:  SS_ Mariefred
Just adding to the chorus. I'm delighted you could re-post as yours is a build I was following avidly.
Tony
Thanks folks.  If we don't all get washed away in this latest East Coast rain depression, I'll try and get back to work! :)
John
wonderful work John......I look forward in seeing more progress.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
John - I must confess, I had not seen this log prior to the MSW upgrade. and now I wish that wasn't so. I noticed that you and I are both building ship that are in approx. the same decade. Can you share with me the plans for your Windlass?
Current Builds - 18th Century Longboat, MS Syren
Completed Builds - MS Bluenose, Panart BatteStation Cross section, Endevour J Boat Half Hull, Windego Half Hull, R/C T37 Breezing Along, R/C Victoria 32, SolCat 18
On the shelf - Panart San Felipe, Euromodel Ajax, C.Mamoli America,
Its a sailor's Life for me! :10_1_10:
Great I think I can use these. Can I ask how did you make the drum and the gears?
That's an interesting degree of detail shown on your draught, Jim. Anchor chain, rather than cable?
You have a good point - Would chain be proper for a for a ship of this period?
Elia - thanks for your support, mate!
Druxey - the plans were taken off by the Royal Navy in 1839 and I think are the most detailed I have ever seen.  As far as I'm aware, chain cables were first used in 1808 and Augustus Earle's painting 'View of the Midshipmen's quarters on biard a ship of war 1820' shows a chain cable.
Floyd - See comment above re chain cables.  I'm modelling Stag in mid career (hence 6 guns - she started life with either 2 or 4) so chain is, I think appropriate.  The windlass barrels and drum ends were rounded by hand (square; taper; eight sided; round) and the 'waisting' put in with a half round file.  The gears are discs of wood with the gears filed in.
John
