they look terrific Rob!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks Popeye...I appreciate that very much.
And thank you everyone for your likes.
Rob
Current build:
Finished build:
Current build(On hold):
I spent a bit of time adding the futtock shrouds.....More work to tidy them up.and get them ready for the deadeyes.
Current build:
Finished build:
your masting details look very nice Rob,
Nils
Current builds
-Lightship Elbe 1
Completed
Thanks Patrick...I work relatively fast when I have the time to do so.  I plan out my work in stages and finish each stage before moving onto the next.  I feel I get more accomplished when I tackle small jobs....they eventually all add up.
Once I can measure the finished dimensions of the ship....I'll probably frame out(from knotty maple) a display case.  Unlike most of my models that are out of reach by most..this one will be at table top level and needs protection from marauding grandkids fingers and creeping feline-ical critters.
Rob
Current build:
Finished build:
Nils
Well, unlike your masterpiece, I'm barely touching on detail.  I really do appreciate your fine comments. :rolleyes:
Nothing could be less ornate then a greyhound of the see...stripped of all finary and things of comfort...speed is bread into them and any encumbrances to that goal are left at the dock side.
Again...your comments are very appreciated..especially coming from one so masterful and accomplished as yourself.
Rob
Current build:
Finished build:
I've decided to make my sails in like fashion..except using paper..
Rob
Current build:
Finished build:
Well Jeff something or the other is up my sleeve...that's for sure... :P
I've worked extensively with plain white paper.  I've used simple yellow food coloring mixed in isopropyl alcohol 90%...and I've used brown India ink also diluted in alcohol.  Once sprayed(Misted) on the sail it colors the sail as well as ages it.
I don't have very many images of the process..except one image I found of a sail I did representing an extremely weathered patched old sail..hanging to dry.
I was replicating the Portuguese Ferriera(aka..Cutty Sark) when she was laid up in some old backwater for years...rotting away.  Her sails were very bad off.
I tried to mimic the extremely wrinkled weathered drying sail...much like these sails drying on this clipper.  But much worse off.
Rob
Current build:
Finished build:
Yes..Jeff I lived in the Olympic natl. forest watershed  at Gold Mtn. ;)
I'm currently drawing up a seam template that I will duplicate that can be used for each sail.  It will represent in scale...3/32=1ft.  Or 3/16" =2ft canvas bands that represent each band on each sail.
I will make many copies of the template one for each sail and cut the sail to scale, band it and each sail will be in scale to the other(I hope).
I'm currently trying to figure out a good way to represent the upper spider bands and their pins for each mast. :huh:
I failed to mention earlier concerning the futtock shrouds that they were probably cable...since from all I gather from my extensive study.....McKay was a forward thinker and utilized many ideas on the Great Republic that found their way on ships many years later....like self ventilating cabins, use of cable in the rigging and the use of a 15 horse power steam engine or loading/unloading cargo, pumping out the ship  and operating the yards.
Here's kinda what I was simulating.
Rob
Current build:
Finished build:
Well I experimented after a great deal of study.......
After creating the strips of canvas and fixing the edge and top banding and the clew band.
I then lightly dusted with the appropriate light tan paint to soften the joint lines...I created the edge pleats by pressing heavy gauge wire alternately into the sail.....here is my experiment.
Rob(the band seams are present on both sides.)
Current build:
Finished build:
This is simply an experiment....and the actual sails will have lower edge banding as well as reef points.
Plus I will work more diligently in achieving the curved lower edge.
I think they will look clean and crisp...the look I'm looking for.
Rob
Current build:
Finished build:
Working on the sail curve.......the edge is important to roll right.
This is a lower topsail...Not a main course.
Edited by rwiederrich
Current build:
Finished build:
I'm looking for a soft full sail...full, but not over powered..or limp.
Kinda like this image(I won't be using stuns.)
Rob
Current build:
Finished build:
Rob,
Your sails look very convincing... and these are just tests?  I can't wait to see what the real deal looks like.
Now I need to get started on the top masts.....My hope was to finish each mast independently now.
Rob
Current build:
Finished build:
very interesting idea for the sails.....as long as you can maintain and keep the wrinkles for the sheet corners,   they will look super!   those wrinkles add a little extra detail ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Popeye...the sheet corner wrinkles are embossed into the paper sail..so they will not *undue*.  At this scale I opted to eliminate the  sewn edging leech ropes...this would be covered up by the leech and foot lining (bands) anyway.  Clarity and undue clutter makes for a better displayed sail in this scale I think.  Bunt and leach lines along with reef points will be ample rigging detail.
Making the untold numbers of Hank loops for the jib sails in scale will be a real skill stretcher.....
Currently, I'm still working on the top masts...been postponed due to several friends health issues that need tending to.
Rob
Current build:
Finished build:
I had a couple hours today to work on the Great Republic and so I finished the masts...Here are some pics.
Current build:
Finished build:
Before I fix the masts in place....I still have to devise and finish up the rest of the spider rings around the mast feet and the mast boots.  It feels good to get some work done.
Rob
Current build:
Finished build:
masting looks great Rob!  gett'in pretty close to rigging time ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
I'll be riggin away..rig rig riggin away.......Yeah.
Once I fix the last items I mentioned I'll glue the masts in place then begin the shrouds and fore and back stays.   OH boy..oh boy.
Somewhere in there I'll also place the top deadeyes as well.
When the mast get on the bench for final work...I'll cut in the lift sheaves for all the yards.....an fix all the blocks to the masts at that time.  That's best done with the masts off the model.
Rob
Current build:
Finished build:
She's looking like a great piece of work there. I didn't realize quite what her hull shape was. I thought she was more angular. Her cutwater is more curved and angled than I thought it was. That 4th mast looks almost like an afterthought. I'm curious to see what it will look like once she's rigged.
I still have an old revel CS hull that's destined for your shop........
Yes..the spanker mast does seam an after thought...and eventually the Germans who owned her last did indeed remove it.
This lithograph of her entering New York on her maiden voyage is the most accurate of her original masting design...envisioned by McKay.  From this and many other sources I fashioned my version.
Thanks for the fine comments.
Rob
Current build:
Finished build:
Final note:  So many examples of this vessel show the hapless error of many builders who mixed elements of the rebuilt Great Republic with the *Original* built version.  Namely the number of sails per yard.  She had larger and fewer sails as originally designed...but mistakenly she is modeled with 6 per mast as her original make up...plus the height of her masts are sometimes erroneously fashioned.
Is my version perfect...by no means...
I just try to do my homework.
Again...thanks.
Rob
Current build:
Finished build:
