1 hour ago, druxey said:
Very neatly done, Rob.
Thanks.....I'm wrestling with the details...and trying to keep things shipshape.
I'm making stuff up as I go....construction details that is...
Rob
Current build:
Finished build:
Current build(On hold):
Worked a bit today on the topgallant stay sail.
Here are some pics.
Rob
Current build:
Finished build:
Now I'm going to focus on rigging (alternately) the fore stays and fore backstays along with the final foremast remaining yard halyards.
As I get higher up the masts the issue of bending and sagging of stays becomes the real problem.
So much pre-thought has to go into the next phase of rigging.  Stay sail and jibs sails will need their halyard and downhaul blocks rigged as well...and not too early or late..as to block myself in or out of a situation.
Belaying the topgallant downhaul line to its lin aft on the rail between the rail and house was the thing of total frustration.
Rob
Current build:
Finished build:
She's looking very grand Rob; hopefully you won't run into any problems with the jib and stay sails.
cheers
Pat
Once again, love those sails. That's how I like sails on a ship model, she looks like she's going to shoot off the end of the workbench at any second. Maybe you should drop a few taut anchors from her to the model base, to help explain to viewers what's stopping her from busting out of her display case.
cheers
Pat
Thanks Pat....I appreciate that. The stays need to be threaded through the cringles prior to install and that can be problematic...that is why I pre-make the stays with hooks and eyes so I can re-attach them after the stay sail/jib sail is installed.
I've got the process all figured out...it just takes a while to perform.
Rob
Current build:
Finished build:
Rob, do you make each crinkle on the jib with a wire loop?  Geeeze, I’d go blind!  Nice work. 👍
Able bodied seaman, subject to the requirements of the service.
"I may very well sink, but I'm damned if I'll Strike!" JPJ
My Pacific Northwest Discovery Series:
On the slipways in the lumberyard
Union, 1792 - 1:48 scale - POF Scratch build
18th Century Longboat - circa 1790 as used in the PNW fur trade - FINISHED
Future Builds (Wish List)
Columbia Redidiva, 1787
HM Armed Tender Chatham, 1788
HMS Discovery, 1789 Captain Vancouver
Santiago, 1775 - Spanish Frigate of Explorer Bruno de Hezeta
Lady Washington, 1787 - Original Sloop Rig
I appreciate that....I've worked hard to make them as convincing as possible...both in detail as well as billow effect.
Rob
Current build:
Finished build:
I make each one singularly.....paint them..then add them to the panel lines of the sails.
Rob
Current build:
Finished build:
Incredible work Rob and incredibly beautiful.
Rob that is a lot of work, is it possible to show a close up of the cringles?
The sails are looking great.
Michael
Michael
Sure..here are some pics of the closest I have of the sails mounted.  These little guys are about 1/16" diameter.
Edited by rwiederrich
Current build:
Finished build:
I also began the first of the backstays lanyards.......and off we go.....
Current build:
Finished build:
Thanks so much Kieth .  I’m doing everything I know to make them as accurate as possible within the limits of this scale.
Current build:
Finished build:
11 hours ago, Bob Cleek said:
Getting the sails done well on a square-rigged model at this scale is no mean feat. I've seen very few that didn't spoil the overall effect of an otherwise beautifully done model by adding sails set and full and falling short of the mark. This is one in a hundred that has done it. Wonderful work, Rob!
Bob...If I hadn't created these paper sails before on other models...and by that, gaining the necessary experience....I surely would have never put sails on this particular model using cloth.
Large weave, heavy, un-naturally wrinkly sails that just hang lifeless on your model can be an extreme disappointing distraction.
Much labor is even required to install such out of scale sails......labor that was needlessly expended IMHV.
I agree with your assessment....I'm very pleased with the results... Since these sails are made of paper and not cloth, makes no difference.  It is the final result not the material that draws the welcome compliments and admiration of the beholder, not to mention a far superior realistic sail that captures motion and action.
It's definitely labor intensive...but also very forgiving.  This is why I adopted *off ship* techniques.  Add the sail details while the mast is off the ship so as much detail can be added without the general incumbrancers found while working on the model proper.  I try to work smarter not harder, and as you well know clipper ships had an intensive rigging scheme.  Ed on his Young America would be the first to agree....I'm trying to attain the same attention to rigging detail as he.....just in a much smaller scale.
Thank you Bob for your extremely nice comments.  Your encouragement means the world to me.
Rob
Current build:
Finished build:
One thing I might point out....I purposefully set the sails at a 20degree cant so that sails never fully overlap.  I also placed name plates of the model on both sides of the display base so that I could turn the model for a starboard or port viewing.  If the model is at a port viewing stance, then you can see fully the running rigging and inner sail rigging detail very easily on all masts.  The back side of the sails has just as much detail as the front with all its buntlines and reef points.
The opacity of the sails adds to the realistic impression.  I tried to adequately overcome many of the supposed pitfalls accompanied with sail addition to models, like, *sails block rigging detail*, *sails diminish overall detail*, *Poor sails lessen the overall model*, and many similar distractive criticisms.
I only hope more builders become ambitious and try paper sails on their own models and that they can work past the dogma that over sized, out of  scale sails is all they have to work with...so they opt out.
A sailing ship is beautified by her sails....they are what make her what she is.  So model them too.
Rob
Current build:
Finished build:
Thank you for the close ups Rob. I also appreciate your thoughts on the sails on models in your last two posts.
Michael
I figured you'd make some provision for viewing port and starboard. I hope you have the space to put the model in the middle of a room so the viewer can walk around it!
Contrary to the "sails hide the rigging detail" conventional wisdom, if the sails are done well with full running rigging detail, as you note, the running rigging on the sails "working" demonstrates for the viewer what all those lines are designed to do far better than a lot of lines run through blocks and back down to the deck, or worse, no running rigging at all.
Michael
I hope the images were adequate.  My ramblings are not meant to be an indictment to those who use out of scale cloth sails...just my observations formed by 45 years of doing things against the current.
Again..thanks to all who commented and for all the likes......
Rob
Current build:
Finished build:
Rob, I am in awe of the job you have done, she certainly will be a stunning model when finished.
Zipper hydroplane(Miss Mabel ) finished
John Cudahy  Scratch build 1/4" scale Steam Tug
1914 Steam Tug Scratch build from HAMMS plans
1820 Pinky  "Eagle" Scratch build from; American Ships Their Plans and History
Steam....  I appreciate that very much...sometimes I feel as if I'm a shackey mess...on the verge of breaking everything....quite stressful actually.
Rob
Current build:
Finished build:
Today was a slow day for progress...lots of thought had to go into my next moves.  It first began with removal of the bowsprit from the hull.
Before I begin to add so much to the bowsprit and jib boom...I needed to add parts to it and many blocks and bull heads.   so off she came.  It would have make these additions go waaay easier.
I know she looks weird without it but it is the best move forward.
Current build:
Finished build:
While I manufacture additions to the bowsprit/jib boom....I continued along with the addition of the backstays that will support the masts as new stays are added.  (Like I said....it is a back and forth process between addition of stays and backstays.
Current build:
Finished build:
Prior to the addition of the backstays....I needed to finish adding the fore topsail halyard and the topgallant halyard and their purchases.
With the addition of padeyes and blocks to accompany them.
Current build:
Finished build:
Similarly....the main topsail yard needed to have its halyards and purchases added as well in similar fashion...with one difference.  I chose to represent the port main deck winch involved with the lift of the yard.
All of this detail had to be added before the backstays were installed.  It would have been a nightmare of the highest caliber, if these details had been overlooked and attempted to be added later.
Current build:
Finished build:
A few more pics...
Current build:
Finished build:
Looks good Rob and quite timely for me as I grapple with "Victoria's' purchase winch locations.  I will now have to revisit my decisions to ensure I have thought it through enough as your solution may change my plans also.
cheers
Pat
cheers
Pat
Thanks Pat  You have any images of your Victoria?  Love to see
Current build:
Finished build:
