Hi Piet,
There is nothing wrong with Belgium beer….
But you are Dutch, and that's why you have to serve Dutch !!!!!!  :D
Then about the vase….. it's better to put the spare wood somewhere where we can found it if needed.
And because there are big planks, a high vase is a good solution.
Also the fact, I don't have to buy flowers because the vases are in use……. :P  :P  :P  :P
You are right about the pictures…. :(
Still have to go to Vlaardingen…...
I'll be waiting for snow for a romantic picture  :D  :D
The last thing….I think that we are all having the same problem…money…..
If I had enough, I come to the States to meet all off you !!!!!!!!
But the virus of meeting builders has already started…….
Who knows where it ends…….
@ Adam,
Thank you very much !
What about the ratlines….it's all experience...
After a few 1000 , you know how it works.
It's not that difficult.
Let me see if I can explain it for you .
You are using the clove hitch.
Also use a pair of tweezers.
Don't pull to hard so the shrouds are still in one line and not getting curved.
You have to practice to see how it goes.
Print the picture out and keep it next to the build.
Then it should work.
Not to steal your thread Sjors but I feel Adam's angst.
As is shown on my san fran build, I am far, way far, from an expert on ratlines... more like a duffer but I felt the same way when I looked down the long road of a few thousand knots and had no idea how to do it.
Sjors is right on the money... the physical part is not hard, it's repetitive and has a right and a wrong way but it gets easier after a few and brainless after a few hundred.
That said tho... tying the knot is easy once you figure it out... the hard part is trying to make it match the one below it without too much tension and match the height gap so your sailors don't hurt themselves.  And that too takes a while to wrap the head around but gets more understandable as you proceed.
Another cool thought is from Popeye the Sailor... he said imagine you're the guy on the boat needing these lines to climb on... how would they need to be? For whatever weird reason, imaging that helped me understand it just a bit better. :P Thanks Popeye!
It's oke Randy.
I forget to tell that I keep a distance between the ratlines of 5 mm.
And use a template behind the ratlines so they are straight and all the same distance.
Grant give me the idea to use different colours and do first each 5 th ratlines and then each 3 and then fill it up.
To be honest , It don't work for me.
I prefer to do each ratline after each other.
But maybe it works for you.
You have to try out what works the best for you.
As they say Adam
Ratlines are a personal thing as there is several ways of completing them
You will find your own way after a while
It is a very touchy freely thing
I would definitely countenance the template to give you something to work to but then it is all down to look and feel
They are easy to remove if you make a mistake as long as you don't make use of glue that some people do
This is one thing I would steer clear of glue on
Good luck when you come to do it
<p><strong><span style="font-family:'times new roman', times, serif;"><span style="font-size:18px;">Keep it up :10_1_10:</span></span><span style="font-size:18px;font-family:'times new roman', times, serif;"> </span></strong></p>
<p><strong><span style="font-size:18px;font-family:'times new roman', times, serif;">Mick</span></strong></p>
<p> </p>
<p><span style="font-size:12px;"><span style="font-family:'times new roman', times, serif;">Current Build --- Will Everard --- </span><a data-ipb='nomediaparse' href='http://modelshipworld.com/index.php?/topic/3636-will-everard-by-micklen32-billing-boats-167/'>http://modelshipworld.com/index.php?/topic/3636-will-everard-by-micklen32-billing-boats-167/</a></span></p>
<p><span style="font-size:12px;">Current Build --- Endeavour --- <a data-ipb='nomediaparse' href='http://modelshipworld.com/index.php?/topic/2804-hmb-endeavour-by-micklen32-occre-154/'>http://modelshipworld.com/index.php?/topic/2804-hmb-endeavour-by-micklen32-occre-154/</a></span></p>
<p> </p>
<p><span style="font-size:12px;">Completed --- Guitar --- <a data-ipb='nomediaparse' href='http://micksjem.blogspot.co.uk/'>http://micksjem.blogspot.co.uk/</a></span></p>
<p><span style="font-size:12px;">Completed --- Barcelona Taxi --- <a data-ipb='nomediaparse' href='http://micklen-taxi.blogspot.co.uk/'>http://micklen-taxi.blogspot.co.uk/</a></span></p>
<p><span style="font-size:12px;">Completed --- London Tram --- <a data-ipb='nomediaparse' href='http://micklen-tram.blogspot.co.uk/'>http://micklen-tram.blogspot.co.uk/</a></span></p>
<p><span style="font-size:12px;">Completed --- OcCre Mississippi --- <a data-ipb='nomediaparse' href='http://modelshipworld.com/index.php?/topic/1803-spirit-of-mississippi-by-micklen32-occre-180-a-hopefully-accurate-rendition/'>http://modelshipworld.com/index.php?/topic/1803-spirit-of-mississippi-by-micklen32-occre-180-a-hopefully-accurate-rendition/</a></span>
it's good of you to say Randy....but I'm sure this has crossed someone's mind at one time or another.  how would this work?  it's the functionality of the aspect your working on.   some folks even find a figure of the same scale to use as a gauge.  I think this is one of the main reasons why I enjoy Dr. Dafi's work so much.   his aim at creating the functionality and realism,  is very interesting.....really puts himself into his hobby.   very comendable :)
if anyone's looking for a good tutorial for creating ratlines..........one only needs to look no further that sjor's build ;)   well done Sjors!
Edited by popeye the sailor
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Ah, the old ratlines.  Days of mindless repetition.  That's why I like it ...... lost my mind years ago.
Sjors is certainly 'King Rat'.  Glad he mentioned the template.  Get some nice heavy card stock and get it behind the shrouds to give you a good background.  I don't actually use it as a spacing template.  For that I just use a stick cut to the proper width to serve as the spacer.  And although Mick cautions against using glue on the knots, I do use a pinprick of flat clear acrylic lacquer on the knots on the end shrouds.  It doesn't make the lines stiff but it does hold the knots fast.
You'll develop your own comfort zone.  Just don't make them too tight so that the shrouds pull together halfway up the mast.
We'll be here to supply encouragement :D  :D
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
And encouragement is supplied in spades :) It helps a lot especially when floundering :mellow:
I used a template and then changed to a spacer of sorts... even still it was tough. I'm proud of my ratlines but not delusional enough to think they are stellar... they are ratlines that represent a first try and from that a learning... the next ship(s), and there are plans for many, will benefit from this ship in many ways including rigging.... :D
Thanks Popeye,
You make me  :blush:
Then for the glue…..
When I finish the whole part of the ratlines, I used diluted glue on the knots.
So I know for sure that they are stay in place.
Thanks for the pictues of the Ratline construction. I will be doing this in the near future and was wondering the same thing.....and yes it was FINE Belgian Ale.....quite outstanding.....I don't remember drinking Ale in Then Netherlands when I was there.....what would you reccomend??? Can it be bought here in the States? I figured a good Dutchman (perhaps it could be Piet) would know Ale's...and he like's Belgian......lol
John
Current Current Builds:
US Brig Niagara on my website
FINISHED BUILD LOGS:
New Bedford Whaleboat - page on my Morgan Website:  http://www.charleswmorganmodel.com/whaleboat-build-log-by-john-fleming.html
C.W. Morgan - Model Shipways 1:64 http://modelshipworld.com/index.php?/topic/1785-cw-morgan-by-texxn5-johnf-ms-164-kit/
USS Constitution - Revell 1:96 http://modelshipworld.com/index.php?/topic/1796-uss-constitution-by-texxn5-johnf-revell-196-kit/
website US Brig Niagara Model http://www.niagaramodel.com
website Charles W Morgan Model http://www.charleswmorganmodel.com
website PROXXON DISCOUNT TOOL STORE http://proxxontoolsdiscount.com
Thank you for the clove hitch picture Sjors!   Scanned that over a few times and okay - the knot itself isn't so scary (did  a couple on a stick here).... so when the time comes..... :huh:  .. I will be using you and others as inspiration.  Fear knot  :P  questions will be coming... (get it,  knot instead of not...  I crack myself up).
-Adam
-Adam
Current Builds
Santa Maria - Artesania Latina (1:65) POB
MayFlower - Model Shipways (5/32"=1') POB
Blue Shadow - Mamoli Revolutionary War Brigantine. (Fict) (1:64) POB (Recommissioned as the Kara June)
On The Shelf Waiting so Patiently
USRC Ranger - Corel (1:50) POB
18th Century Longboat - Model Shipways (1:4) POF
La Nina - Artesania Latina (1:65) POB
U.S Brig Syren - Model Shipways (1:64) POB
Completed Builds
Phantom NY Pilot Boat - Model Shipways (1:96) Solid Hull
Decommissioned Builds
(Time and conditions were not good to these. They have been cancelled =( )
Willie L Bennett - Model Shipways (1:32) POF
USRC Harriet Lane - Model Shipways (1:128) Solid Hull
@ Randy,
I'm sorry, I missed your post :(
You can be proud of your ratlines !
You did it !!!!!
And for the future….every time when you do some, it goes better !
I'm happy that I can help some of you with that wonderful tying ratlines job :D:D
And you are doing it the right way Adam.
Try it first on a stick.
When you figure out how it goes, it goes well.
@ Sam,
You're welcome.
Sjors!!! She looks great!! Sorry, I have been here, just quiet for the most part this week. Not much time for anything but to look in and peek at what's been going on.
Robbyn
If you risk nothing, you risk everything!
Current builds
Syren (Model Shipways) version 2.0
AL San Francisco II
Mordaunt (Euro Model)
Completed Builds
18th Century Longboat designed by Chuck Passaro
In the closet
Battle Station
Al Charles Morgan (1980s version)
Sjors,
Congratulations on the finishing the ratlines!!!! Take a moment and smile and feel good about them. Times up...go get some more done. :D
Hi Shaz,
No problem to come later.
The only thing is that you have to " search " for an update…….
Maybe when I place a update, on every page I can put the link where the update is ????? :D
But thanks for the nice comment…. :):):):)
@ Mark,
This weekend was not building time at the Mirage but on the San Ildefonso.
I have to do something else for a while.
So maybe later today a little update on the SI.
And thanks for the Congrats :D:D
Sjors, i believe you....but I thing the aggie has a syren call of its own, and I can hear echoes of it all the way over here hehehe
Robbyn
Current builds
AL San Francisco II
Completed Builds
In the closet
Battle Station
He Nick,
I'm glad that I see you again.
How is life with the two young ones ????
They are eating all your time I think……
I'll be waiting for your update !
Only I can not learn from you anymore  :(  :(  :(
@ Shaz,
Thank you that you believe me !
You can hear the echo of the Aggy….that's correct !
When I open the box for the unbelievers, she was thinking that I gonna start at her……
Sorry for her, but she stay still in the box !
But I'm happy that a few builders believe me.
Hey Sjors
Dont know yet. Number 2 is not due until January :D  (sorry couldn't resist!)
I know but heh look on the bright side: I can learn from you :)
Nick
Hey Nick,
Oke, january then……
I shall ask it again in February  :D  :D  :D
And when you at the part of the masts, there are a few things that you have to know.
When you've got there I will tell you that.
But with your speed it can take a while  :P  :P  :P  :P
Say Hi to your Admiral !
Hi Lawrence,
I have two builds going on at the moment.
The Agamemnon is still in the box under the workbench.
And she stay there till I finished one of the other two.
Thanks Lawrence,
When I start building at the Aggy now, I think it's gonna to much !
I have to finish one of the others or I have 2 unfinished ships and Anja don't like that.
And you know, she is the boss in the house....( at least, that is what she is thinking  :P  :P )
Hello Sjors, I just saw the weather and it showed a hurricane going into the UK, you'll probably get part of it too.....hope all is well for you and Anja, and be safe.  You will get to experience what we deal with in Texas and Piet experiences in Florida.  They aren't fun.  However we used to stock up on beer and go to the strongest house in the neighborhood and have a "Hurricane Party" until they would pass through.....helps one to weather the storm....Be safe....
John
Hi John,
We have this morning our part of the storm.
Windforce 10 till 12......
We are safe !
Anja was at work and I stay at home.
No damage in the neighbourhood
There was a hurricane but that as on one of the Islands ( Vlieland )
But thanks for thinking at us  :D  :D
Hi guys,
Sorry for the late replay but I had a long day of work today....
A broken shift of 12 hours totally !
I'm happy that I was yesterday free of work.
I talk to my collega's and it was not fun to drive with a bus yesterday.
But everybody survive and all the busses are in one piece.
The San Ildefonso is back on the shelf because I need a serving machine.
Mobbsie has make one for me and I'll have to wait till he brings it to me ( in about 3 weeks )
So back to the Mirage .
I have done nothing so no update.
But when I can go on with her, it should be making the yards and place them.
This weekend no duty so maybe a little progress.....
But that's not a promise !!!!!!!!
Hi Lawrence,
The Mirage is again on the shelf.......
I have to figure some things out with the rigging and in the mean time I'm working on the San Ildefonso.
Everyday i take a look what I have to do but I don't do it  :D  :D  :D
And of course my work is in the way.
When the time is there, you will see a update !
It was fun Popeye.
We enjoy it also !
And what about Wayne....he come s and go as it him pleased :P
But you will talk to him , I know that for sure !
Edited by Anja
