4 hours ago, yvesvidal said:
Anchovies, tomatoes and capers.....the fruits of the Mediterranean basin.
Well done Jack.
Yves
But they are quite salted . . and you surely may need also to drink enough: wine or water ?
Beautiful work, Jack.   Very nicely done.
Jean-Pierre, Mark and Yves.
Many thanks again for your more than positive comments.
I'm now in the process to leave Tuscany and come back in Cinisello (Milan) to my "official house". Having not decided what to do after my return in Cinisello, I'll bring with me this model and its materials, plans etc in order to be able to continue, if I'll decide so, and finish it.
I want to remember you I'm also working on
in Cinisello, and its shipyard is idle since many many months. Your sincerely, Jack.Aubrey
Hi Mr. Jack ...this Falkusa is done really good!! Beautiful work ...
Best Regards, Zoran
Saturday, June 24, 2017
It's since April 20th that this log isn't updated anymore. The reason is relatively easy to explain: in this period of time I went back to Milan from Tuscany and, as often happens after long absences from home, I found myself to be involved in everything and more. So nothing or very little modelling, save a timid resumption of activity over the past ten days.
Now my ultimate goal is to build the second part of the boat sides, the famous elements that could be removed after sailing and reassembled after fishing. The so-called "Falke". I do not think it will be an easy task, so I'm moving very carefully.
I started preparing the removable extensions on the bow and stern. I think the next four images can explain by themselves: these extensions are fixed to the protruding part of the keel and clutched on two metal pins holding this accessory firmly fixed. .
y4m-F-nk_palbpCnIzR4Bmsmc0TCwrPWjzRWYK_a
y4mrfDMr3zTFQ5P3qN-OBbBW0JcitwyPOrNCefB-
y4mUGmae9AYA9WCVgxcmxcX0YCiL4lYigabjTs_C
y4mpwz8-MFRqhJZq4FPIhSZ-JMu7FsE36388lYbO
By the way I built the rudder, though it will be needed a lot further. Below is a photo of this item.
y4moIOq10am86ErSekzIx4qNNSOZOwmncJCtRiW3
And here's the most demanding part: the picture below shows all the bulwark stanchions on which the "Falke" planking will be applied. Here are presented after the long treatment received. The pieces were laser precut and obviously, on the cutted side, they were all black and burnt. The first activity was to remove the burns to get the original color of the wood.
Afterwards I had to work to fit the openings of the gunwale, where to plugin every single stanchion, a rather delicate and boring task: 24 square holes to fit.
Finally, when everything was fine, I could stain all the stanchions with a medium wood color. Now they are drying and finally the next job can start, provided the necessary checks to assure everything is properly set up.
y4mBFTXoxakOfyn5OnDtEc-HML7XAlCJlR3LFvhe
Hopefully, I hope not have to wait two other months to post the next  message. Cheers, Jack.
Wednesday 28 June 2017
I put the items shown in my last message of June 24 (and displayed into its last image) in their proper locations so that, once the glue will be well dryed, I'll can start to install planks over these new hull elements.
I thought for a long time to find a method of building these "falke" in order to allow them to be removable, instead of leaving them permanently held but, although I had some idea, I didn't feel confident to try it. There were too many unknown things, one for all: did these so assembled falke maintain their correct shape once extracted from their beds ?
So, though with a little reluctance and remorse for my defeat, I decided to fix them. In the photos here below I show all the bulwark stanchions in their room, obviously well glued, indeed rather than well.
y4mOFjOQTmuAcoS4lyxUdrCKQgC89R5NkDf3lbhQ
y4mDQ6Pf4hKzoKHnR0O2v0H02VQvvCbM0zXYTldx
y4mMmMRCjzQFLOcyXUvJ1GT0szPY0OYQk10WNsFt
y4mFBnxuu9MQg32WoNGwqoL-t-B4iP91dtNQc6ua
y4mfx3G20A8beMpj3LNbHdtMeMp83R9wsliRAhuk
Cheers, Jack.
Sunday 2 July 2017 ------ ATTENTION ------
The following three images will probably be the only images of this model visible forever in this building log.
Unless I can implement a solution that will allow to review the images contained in all the posts I published from 2009 onwards, a solution at the moment I don't have, you will no longer be able to view the images in this thread.
But not only: even all my other "topics" I created and managed since 2009 are concerned (!)
What's happened ?
Since 2009 I took the habit to publish my posts in several forums. More precisely two italian forums, using my mother tongue, and two in english language.
To avoid uploading images onto four different sites, with often different loading rules and methods, I had found the solution of uploading them onto a single site, since then free of any charge, acting as a "database" of my photos.
By sharing its link, inserted into the body of the forum message, the image was thus displayed. Basically: a single source code for the forum that can be used anywhere.
This has worked since 2009. . . Until a few days ago.
On June 28, 2017, the owners of the site where I uploaded the images decided to provide this service only for a fee, at the modest annual charge of $ 400.00 !!! All this was communicated with a banner linking the following page: http://photobucket.com/terms
Now I don't want to comment the behavior of site owners http://www.photobucket.com ; it's not worth waste time. I'm sorry because a treasure (probably only for me but I'm illuded could be regarded as such by others) of events, problems, solutions and work, time and efforts spent in promoting and making known ship modeling is simply disappeared.
This fact will most probably lead me to leave my habit (and my pleasure) of publishing and share my experiences in the near future . . Even though I cannot 100% foresee what will happen. So it's with great sorrow that I am going to say goodbye to you: now I do not feel calm and peaceful to continue presuming that nothing happened.
A embrace, Jack.
01 - 20170628_110435.jpgy4m2GPfCzTlKKiVIZhf9KQbfW0inkNRkzsRENtub
02 - 20170701_172050.jpg y4m6uTA71QwnJhUO02Me21MnGhKDC4uIYRy21OMP
03 - 20170702_122726.jpgy4mSigxnRkCmMH8g3Ag7XvPsutbePUZTyKiOQWo2
That is bad news Jack, I would love to see the completion of this beautiful gem
Very bad news not just for you, but around the world.  From what I saw in the IT press, everyone was surprised and hit hard and outraged.  There are other hosting sites such as Imgur and others that are either still free or very low costs.  The big problem would be moving the images.
Thanks Don and Mark for your comments.
I don't know the reasons Photobucket made this behaviour change regarding their free customer, but, over all, they could imagine the impact of this change. If the fee was $50 instead of $400 may be I accepted their request, considering the potential loss but in this way is not acceptable.
Any possible migration from Photobucket to other sites (for example I have 1TB disk space of OneDrive coming fron an Office 365 purchase where to load the images) is possible but difficult and requires a lot of work to implement. Automating this process is, for the moment, out of my capabilities.
Hi Mr. Jack ... this would be so pity to lose all the photos of the beautiful models You posted... Do not give up on making some kind of the models build log reviews... They are valuable ..
Zoran
Tuesday, July 4, 2017
Despite the unlucky "PHOTOBUCKET" event, and therefore accepted, though with great sorrow, the loss of a wealth of personal memories, I decided that I'll continue with this journal until completion.
Obviously all the previous images are lost, or as we say in italy, are gone to infantry.
So let's imagine to start from now.
I am now building, even if not removable, the so-called "falke". We are still far from completing them, but we already have an idea of how the hull completely changes . . From a boat low on the water we are now facing a high-sided boat, much more suitable for sailing.
Enjoy these images. These should be forever . .
01 - 20170704_144401.jpgy4mz_ialvnOQXRjv6rp0ykCCn7jedhA8nc7K7F-v
02 - 20170704_144407.jpgy4mIPzKQJfeRuDYUkOrgeP4c2PkxHfXW8YsdVnOC
03 - 20170704_144416.jpgy4mvwN0S-JqK5HHppXcWPyyG3IhHWTQyLSdvpzg2
04 - 20170704_144423.jpg y4mcObP8E_ZD56l7ZGpUtTtnz97unulKU7ZCoxhc
05 - 20170704_144431.jpg y4mP6AsRA4sdxfDserH5fulN98LvUO-WxznQHheR
Regards, Jack.
Looks real nice Jack, that is a damn shame losing the rest of your build pictures
I'm very glad you decided to continue posting your build log. What beautiful craftsmanship!
Steve
completed models:
Shenandoah (Corel)
waiting on the shelf:
La Sirene (Corel)
Half Moon (Corel)
Puritan (Mamoli)
Patsy (derisively): "It's only a model."
Arthur: "Sshhh."
Saturday, July 8, 2017
Completed the planking of the top sides on the hull, in particular I raised, as planned, the height of the sides in the stern and, above all, in the bow area.
Now I've to start the cleaning and refining tasks before proceeding with new details of these "falke".
01 - 20170708_084910.jpgy4mpL1lHKAulzkzNGFfCLddKYzxlz73n-pJLgYpA
02 - 20170708_084920.jpg y4muzbZku8gBPM-WpquBKq8xIoJ6_72lff_F43_m
03 - 20170708_085047.jpg y4meDWIxAgwfXQv17KFZ5Pogjm9fV3xnGamF_j2K
04 - 20170708_085103.jpg y4mVhakwekYDhEpwmCHHLkE91oT0jyHZZVsTRysA
05 - 20170708_085141.jpg y4mRHwC6GHkp6rxSJd48lZhrxPgoysfsHttblRo-
See you soon, Jack.
Saturday, July 15th, 2017
The hull practically finished.  Now, only minor details are missing, and a final black paint coat on the outside.
Next planned activity: building the oars. My starting point is a nice walnut stick 7 x 7 mm. I'm thinking about the right procedure to make them.
Regards, Jack.
01 - 20170715_162949.jpgy4mgFI7cc8R1hA9pyf_l_otZjc9XhM80owwrP0PX
02 - 20170715_162644.jpg y4mV4wFxbkAlL737OTpIx9_DAgap-8-5B0EKaT_B
03 - 20170715_162634.jpg y4mEDoqyxXTzHysvy8TrVH59b-zgloEJP2osn4UJ
04 - 20170715_162606.jpg y4mA73ZKd9wvUcwuxg7hSyTEpYJJNNpv5ohNsRNi
05 - 20170715_162626.jpg y4m7y5JtP2tQKk3Ys0Uos-ivKE0zh6dOM9TQP1uD
06 - 20170715_162617.jpg y4mJrcASqIbuI5tXBWZeLoIgOx6VnWY88-qgh8vg
What a beautiful boat Jack,
fantastic handcraft work, clean and acurate joinings   :)
NIls
Current builds
-Lightship Elbe 1
Completed
Important notice:
I'm trying to recover the images lost thanks to fu.... Photobucket (:angry::angry::angry::angry:). I've a lot of work to get the final goal, anyway be patient that I'm sure to be totally successful. It's only a matter of time.
Cheers, Jack.
Wednesday 19 July 2017
Completed, with the latest details, the hull, inside.
y4mP1nkrDoFjQAiZK9mSmOdW1raCHL8ZoICldulM
y4mUvygH5DHILQhGwZU3HqhmV9mwqzMhMjoHqWNZ
y4mUgqQy2M0fthf9os_v3E0FVFYSnRfde2Mgb1O5
Friday, July 21, 2017
Built the oars on Thursday, today I did some color 'cause all clear walnut was a bit too serious !!
y4mfbDLRqw5fyUAbiJ-9rP6_iSHfh2HaYQDmQT2v
y4mWEMEadpRZU521zYO9lBYfyF_pgcbBKZfU07_8
y4mv77fHjC3uEBjzEvbFm02j-HJo4h-8mkvCPoH0
Regards, Jack.
Important notice:
I'm working to recover the images ransomed by Photobucket .
Today I've recovered the complete page #1 of this log.
With the exception of post #5 and #22 that I cannot edit 'cause I'm not the owner, all the images in this first page should be visible.
In order to be sure everything is OK may I ask you to inform me if there are still some problems with the images in that page ? I had to set some permissions in the system where I store the images (Microsoft OneDrive) and I prefer to be sure all problems are solved before continuing. If you get some problems please send me a private message so we don't fill with stuff this log. Thanks in advance, Jack.Aubrey.
Friday, July 28, 2017
These days I've done a lot of work on this model, but unfortunately I don't have adequate pictures to show. So I just show these three images where you can see the original support provided with the kit.
Anyway I have a somewhat different kind of presentation in my mind . . I will explain it as soon as possible. So I'll meet you soon. Regards, Jack.
y4mRBw8M1dK75EtE-OUYeIz9bk4Qwne71ISBHolU
y4m-nQuDSajn4Lgff6TFkg7o0FS-nEV_pVQ33aSF
y4m0-MdH2X9oZIpErjRvcOyk5GzA5iv43P9wkKyU
Saturday 29 July 2017
I started some tasks for sailing equipment.
Let's begin with the mast, wedged in the keelson and embedded in a half-rounded niche of a seat. Here, of course, it's just positioned. Then we have the boom that will house the jib.
y4m2awSfB__Y_3rZ-bOxUcGAzwJXgP1LYcOtnavP
y4mMHART8FpjXGV6FbB8tgjzXFyXZLqaPIasR0Gr
y4m-6v9oKzBMtpIV_58OfShFmr5GrBvBqboBeNCo
Here, instead, the antenna for the triangular sail. This boat features two types of triangular sail, one high and one lower. Because of the height of the display case, I chose the sailing with the lowest antenna. It was a tough choice but I think it's necessary.
y4m9lwsnoz_O3zQSXn_myXpjWZFxhVRgiFNj9QU3
And now let's come to the showcase basement of our model. Although the support provided with the kit is nice and original, I had in mind a kind of presentation like the image 08 20160924_110111.jpg, in my opinion very realistic. Then the base of the case is ready to contain this kind of bed made of stones/sand.
With this in mind, I asked my daughter, Silvia, who went on holiday to Elba Island to "steal" (I remember that it is not allowed by law) sand and gravel from a couple of Elba beaches . . Now the stolen material  has to come in my hands.
For now I release some images of the showcase base . .
y4mtc1L38OBqKgIDYNZRrb0aTNtSvqMEWhXLjipY
y4mVmK5VR__yiMafjVDEc3tQw0mLJDEcmU1x1vzs
y4mNRRLWgWd4WFONJ-TnMNntnkVHMohHN--mw3If
y4m5Uz_sHmoupzSWeCYTBVETZEdWfk6-LBVy_gTD
Regards, Jack.
Jack,
your boat is lovely. What a little marvel of precision, elegance and beauty.
I love the idea of the showcase with sand and gravels. It is absolutely stunning and takes you back to these small Mediterranean harbors where life is slow and full, with laughter, love and friendship. I miss that .....
Please, keep enchanting us.
Yves
Thursday, August 3rd, 2017
I'm working on many small details with little to show individually: rudder hinges, mast support, crates for fishes, painting of the "falke" sides, etc.
The only things worthy to be seen at the moment are the outside paintwork, now black and the crates for the fish, to which I am still working.
This is the prototype: measurements mm 30 x 20 x 15.
y4m8L82avdXAaa-HHq5pIAqfh-9zeoP9_L418UZV
Below the hull with the "falke" painted in black . .
y4m4tB2oaVeu60S6QcglFtsWsZGbDQYnxZZjFxkN
y4mMwaAzTpbohrW7YiRb1FRUJbUimjZfnSgEJYrU
y4mJ122rGAWZLuMvwh8Tfts12Aaf21rNYJis_fDj
Edited by jack.aubrey
Jack,
Don't how I missed this one -I have been following your builds for a while. This one is especially awesome indeed, as has been stated by many members.
Beautiful work. So perfect!
Photobucket !! what the He*ll.
Cheers,
Edited by md1400cs
Under the table:
Woody Joe Higakikaisen
Completed:
Santa Maria-Mantua --
Vasa-Corel -
