Thank you, Dan!  What makes it all the more gratifying is how easy it is to do.
Well, this has been a banner week in my mobile shipyard.  I’ve made up the false amortisement windows, and I have finished modifying and prepping to paint the beakhead bulkhead.
What’s missing is the lyre carving between the windows.  I’ll re-draw that this weekend, and get busy making those next week.
Now, these windows would be fine, as is, but they’re a little two-dimensional, IMO.  Adding just a little bit of moulding gives the windows a better sense of dimension:
I will likely just paint them flat black with either white or yellow ocher mullions.  I haven’t yet decided.
The Beakhead Bulkhead:
After grafting-on side extension pieces to make up the extra width of the hull, I decided to close what I find to be the exaggerated open timberhead space on the bulkhead.  I will cut-in the cathead timbers, at deck level, when it comes time to install them.
Once painted, this paneled effect will disappear.  I added another band of moulding to delineate the space:
I decided to close the lower chase ports, as they won’t be armed, anyway.  I also filled the concavities that would ordinarily accept the lower footing of the roundhouses; these were no longer necessary, as the bulkhead has been set back, by its thickness, so that the ship sides overlap it, as would be the case in actual practice.
As a side note - I have found that I really like the Tamiya white putty; it’s much finer than the squadron white, easier to apply and more durable.
I, then, scraped away the raised grain; re-engraved the plank seams so that they extended all the way to the ship sides; sanded for texture with 50 grit paper, and drilled for the nailing.  To finish up my modifications, I decided to add a field of fleurs, as was often done at this time.  I also decided to make use of my foliate diamond ornaments for the band I created when filling-in the timberheads.
Next, I’ll prime, paint and install the bulkhead.
As always - thank you for the likes and looking in!
Beautiful progress, Marc.   Your scratch built works just boggle my mind at this scale.
I appreciate the compliment, Mark!
Well, with the harps made, the windows are now complete, and I’m about 60% of the way, done, with the amortisement.
Final assembly will take some finessing, but here is what we have so far:
Next up, I will tackle the semi-structural elements above the windows.
Thanks for the likes and for looking in!
Thank you, Victor - Little by little, we are getting there!
I made this - I’m not sure what to call it - Xs ornament for the starboard side.  Even more so than the trailboard, this thing is terribly small and impossibly fragile.
This turned out okay.  The first effort was a disaster and had to be scrapped; a lighter touch and a pointier blade produced much better results.  Still, though, the extensions of the Xs don’t have the neatly uniform rounding I was hoping for.
I decided to add tiny domed slices of styrene rod to dress it up a bit, and give the whole thing some dimension:
I think this helps.  Once it is straightened out and secured to its backing it will look plenty good enough.  The port side should turn out better, now that I know what I am doing.
The beakhead bulkhead is painting up really nicely, and it will provide an exciting (for those who get excited about these things) glimpse into the eventual coloration of the stern.  More on that to follow.
Enjoy your weekend, everyone!
The beakhead bulkhead is painted, now, and ready for installation.  Before I do so, though, I will do a little addition to increase the glue surface area, backing the bulkhead.
I decided at the last minute to add panel framing around the foliate diamond ornaments.  It echos, if not exactly, panel framing around the lowest tier of fleurs on the upper bulwarks.
I didn’t really have the necessary space to copy this, so I simplified the paneling.  In fact, I originally wanted to use fleurs, but I couldn’t reduce them enough to make it work.  Even the smaller fleurs that I made for the stern counter were too big.
So, here’s the paint work bright and clean, as on the first day of her re-launching in 1689/90:
And here is two years of sea grime and paint oxidation, as just before the battle of Barfleur:
The blue, here, is really a cobalt blue, but it deepens to the ultra-marine with a very light wash of walnut ink.
The first red acrylic I applied was a proprietary mix for BLICK art supply.  The color was lovely, but I soon discovered that the paint would wash away when wetted.  I’m not sure why that is; perhaps, in thinning the paint with regular tap water, I altered its curing properties.
Anyway, I washed away the paint with soap and water and then applied ModelMaster’s Insignia Red acrylic, which is the red I’ve been using everywhere else.  I can successfully thin this formulation with tap water.  It turns into a pleasing red ocher, once the walnut ink is applied.
The other decision I had to make was whether to paint the top sheer of drift rails gold or yellow ocher.  I decided, ultimately, to go with the yellow ocher, and to save gold for the ornaments, themselves.
Thanks for the likes, comments and looking in!
Beautiful! The weathering is well done. Naval ships were usually well kept by their crews as a point of pride, but natural wear would still be present. I think you are doing an excellent job in showing this.
"It was a stormy sea that made a Captain out of me."
- Derina Harvey, "Captain" Derina Harvey Band
-E.J.
Current Builds - Vasa - Scratch
                               Royal Louis - Mamoli
                    Royal Caroline - Panart
Thank you very much, Victor and EJ!
This next level of the amortisement is fun to make because, while it seems simple, it is actually a pretty complex form.  Without having drawn a top plan view, I have to wing-it, a little, when it comes to establishing depth and taper.
The first step was to make up a styrene billet.  The canopy is 1/4” in height, between the top and bottom mouldings.  I made my billet stock a little wider, in order to file in the top and bottom taper necessitated by the tumblehome of the ship’s sides (see pic below).
Once I had billet stock, I could lay out all of the paneling and the outer parameters of the canopy:
The tricky thing about this aspect of the project is that there does need to be some depth to the canopy - which will be further overhung by the top and bottom mouldings - because the upper-most section of the amortisement has at least some depth, at its center, which tapers out to the sides (where they abut the pixies).  Considering that, the canopy must also diminish, slightly, in depth, from top to bottom.  And, on top of all of that - there are a series of reverse curves that define the bombastic form of the canopy.
In layout, and looking at it from the top view, that all looks like this (excepting for the reverse curves, at the ends, which I did not draw-in):
With the layout pencilled-in, top and bottom, and on the outer face,  I could then make a series of shoulder cuts, with a fine back saw.  After hogging out the bulk of waste, at the ends, this is what that looks like:
Once all of the shoulders were neatly defined, I could set-to shaping the subtly curves ends and middle:
The end scallops are set-down about 1/32” lower than their adjacent short flats, so that when I apply the panel framing details, in the next step, there will remain a stepped demarcation between the ends and middle section.
As I had hoped, the second Xs moulding came out much more cleanly than the first.  These decorations are springy enough to accommodate the tapering surface, without appearing to become distorted.  Once, I have the port-side canopy made and both canopies paneled, I can use them to pattern the exact top and bottom overhang of the mouldings.
More to follow...
Alright, so I’m pretty psyched with how this all came together:
Before glueing on the top and bottom moulding plates, I faired the canopy to the curvature of the upper bulwarks.  Now I can simply sand the plates down to match.
For this profile scraper, I decided that attempting to scrape the full reverse curve was likely to chatter and dig into the plastic - particularly, along the bottom return.  So, I simply ground the top portion of the reverse curve, and then rounded the underside by hand.
Now, I can move-on to the upper finishing of the amortisement.  That should be a fun little bit of trompe-l’oeil, as I attempt to create a sense of depth in what is now a very shallow platform.
So, the upper finishing of the amortisement has been straight-forward but surprisingly labor intensive.
This particular photo of Tanneron’s damaged model of L’Agreable is so instructive because it provides so much information about the fabric of his construction, as well as the shaping cues for the upper finishing of the amortisement:
My ambition, always, is to attempt to capture some sense of the magic that makes Tanneron’s models so impressive.  Toward that end, it’s a process of layering details with all of the care of execution that one can muster.
As has been my method, the upper finishing is made up of a series of laminations: a base layer of 1/32”, a middle 1/16” layer, and a top layer of 1/32”.
I toyed with the idea of using Bondo fills to fair panel recesses at a continuous depth.   I did not think the Bondo would adhere well enough to the plastic to withstand the slight flex of fixing the part in place.  Conventional model putty would be too brittle.  In the end, I decided that the 1/16” layer was deep enough to create a sense of shape without having to go through undue effort for minimal gain.  I think it worked out pretty well.
A montage:
Given my struggles to carve good faces, I decided to extract Louis’s radiant head from the same place on the kit’s stock quarter galleries.
I wasn’t sure, early on, just how much space I would have left-over, after the bellflower garlands were in place, so I left the heads oversized for the time-being.
You can see the subtle shaping of the 1/16” layer, above, as well as the slight rounding of the final window framing.
The garland and cornice were a separate 1/16” layer.  Just as they are, above, they would be fine, if I decided to stop there.  Attention to detail is everything, though, so I took the shaping a little further:
The garland diminishes, in depth, as it rises to the cornice, and the cornice, itself, is now tapered in a gentle arc from its center to its ends; this small detail helps to accentuate the convex shape of the windowed center, below.
I coved the inner surface of the cornice, modeled the bellflower garlands, and then I gave Louis a haircut.  I was able to incorporate just enough of the fanning rays of light, beneath his head, to satisfy the original design:
The first layer creates the recess I need to capture the acetate window:
I made up the acetate panes, yesterday, but botched the engraving on one, and will have to remake that.
So, now that I have all of the elements of the amortisement, it was time to see how this was all going to map out on the upper bulwarks.
The whole layout hinges on exact placement of the canopy section.  Although the uneven underlying ornament makes it difficult to place these pieces, and the parts have yet to be faired to each other - this placement should enable me to salvage my aft octagonal port:
I will have to drop a wing from the forward pixie, but I am now confident that I will be able to make this work.
With my kids back in school, and the uptick in their activities, I have found that I am not sufficiently alert, in the evenings, to do good paint work.  All of the putty fills at the bow are nicely faired and I brush-primed all of the raw plastic, but I just haven’t felt like I could give it the focus it requires.  Opportunity will present itself in the coming days, though.
As ever, thank you for the likes and for looking in!
Your work on the carvings is mind-boggling beautiful, Marc.
It has been a slow week of mixed results and some small progress.
Painting-in of the head timbers was going well enough.  Unfortunately, I over-estimated the blending capability of Van Dyke Brown oil paint to conceal the color-fills I made to the ventre-de-biche of the deadworks.
I thought I was being careful to feather-in the new color, yet because of the contrast of the original weathering, I still ended up with a clear line of demarcation:
This was after two applications of oil and wiping off the excess.
Part of the problem is that the original weathering is sealed under a clear top-coat, so I can no longer lighten or manipulate it.  I can only go selectively darker.  Toward that end, last night I began applying heavily thinned wash-coats of the oil paint, and have succeeded in eliminating the strong contrast. I didn’t take additional pictures, but the appearance is much improved.
At the moment, though, the color appears a bit mottled, as I was applying the color with light dappling touches, over and over again; a brushing motion only “washes” away the color you put down on the previous layer.
I then charged the chip-brush I’ve been using with un-diluted oil paint, and left that to semi-cure overnight.  My hope is that, this evening, the wash-coats I applied will be sufficiently durable that I can take light sweeping passes with the charged chip-brush to smooth the tone and blend back smoothly into the ship sides.  We shall see.
In preparation for building up the amortisement on the upper bulwarks, I coped together all of the individual parts, and this helped me feel better about the paint problem.
Thank you for looking in, and enjoy your weekend!
Concerning the paint issues, could the artist oils over the much larger area of the hull have had longer to stain and even dry a little more than on that small patch? I use oils on miniature figures and have to adjust my timing moving from larger to smaller figures. It's just a thought, and worth what you paid for it.
I appreciate the thought, T_C.  When I first painted the ship sides, I worked in manageable sections (3-4 port openings), and I only left the oil on the surface for five minutes, before wiping off the excess.
This go ‘round, I left the oil on for significantly longer - about 15 minutes - but the contrast was still high after cleaning away the oil, in the darker areas, with spirits.
Fortunately, what I proposed seems to have worked pretty well.  It will certainly be good enough in this area which is overshadowed by the headrails, anyway.
A shot of the stippled effect before blending:
Then after blending:
Tonight, I’ll resume the yellow ocher.
I’ve also been affixing the port side amortisement.  I cut through for the octagonal ports and the one real window - the oval of the Admiral’s quarters.  This would be moving faster, but I am too nervous about traveling with the upper bulwarks.  There is too much time invested to risk damaging them in-transit.
In the daytime, I’ve been doing more tedious tasks like cleaning up the kevels.  I spent a good bit of time re-reading Henry’s log, today, as I consider how I will run all of my tacks and sheets.
The past few weeks have been mostly about tying up loose ends.  The bow area is nearly done with the paint re-touches. I also realized, recently, that the beakhead bulkhead should be equipped with doors, in order to prevent heavy seaways from swamping the middle gun deck.  I got myself busy making a pair of those:
I also spent quite a lot of time building up the port side amortisement:
I took extra care to beef-up the portion of the crown that rises above the sheer rail:
One can get a very good sense, here, of just how shallow the amortisement really is.
The next detail I wanted to affix before priming the upper bulwarks are the quarter pieces that support the side lanterns.
One peculiarity of the Heller kit, vis-a-vis the Tanneron model, is that the side-lantern support boxing rises above the sheer rail.  This contributes, greatly, to the exaggerated height of the tafferal.
For reference, here is that detail on my first SR:
Note, the extreme difference in style between the kit QG and the 1689 version.  This transformation has been the primary motivator of the entire project.
I suspect that Tanneron took his cue for the lantern boxing from this later QG drawing for SR2, in 1693:
The earlier drawing, though, shows the boxing below the rail:
As a constructor of things, and considering just how massive the side lanterns actually were, it makes much more practical sense for the lantern boxings to mount solidly to the ship’s sides.  There also exists a solid foundation of Van de Velde drawings to support this detail.
Using Dan Pariser’s Photoshop collage as a reference, it seems more likely that this, in fact, is the arrangement that was intended to correspond with the stern drawing:
Thinking back to the start of this project, this lowering of the side lanterns was how I decided to shorten the tafferal tableau for Apollo’s horse-driven chariot.
As I do when the opportunity presents itself, I more deeply defined the acanthus detail of the quarter pieces, while cutting away the unnecessary lower portion:
My hope had been that I would be able to re-cycle the kit figure of the Americas, for the port side, but she is scaled for the much taller tafferal, and she now looks too far out of scale.  As I was going to have to carve Africa, anyway, it is best that the Americas be proportional.
I have also begun making the lower section of the QG.  Henry’s hull continues to be invaluable.  Without being too delicate about it, I could grind away the wales in the QG area, so that I could closely fay each section to its location:
There will be 1/16” styrene spacers between these sections that define their shape, while providing the moulded transitions.
More to come!  As always, thank you for the likes and for looking in.
Truly incredible as always.
-E.J.
Thanks, EJ!
So, here are a few pics of the bow area with everything re-touched and distressed, the beakhead doors in-place, etc:
I realized that I shouldn’t glue-in the beakhead bulkhead until I have painted the lower transom because I will need to remove the model from its working base and flip it over, in order to access the underside of the stern counter.
Just for fun, here’s what the built-up amortisement looks like in place:
I also realized that I can’t paint the lower transom until I’ve made the lower section of the quarter galleries.
I’ve held off on doing this for a long time, while I tried to figure out what exactly my approach would be.
The greatest difficulty is in trying to ascertain what the volume and shape of the sub-structures should be.
Ultimately, I decided that I would carve these sub-structures from apple solids, and use the pieces above to inform the shape of those below.
For additional reference, I looked back on Drazen Caric’s excellent tutorial for the making of his QGs on the Provincien:
The logical starting point of this process seemed to me to be the widest section of the QG - the middle-deck section, which is the functional level of the officer’s toilet.
I know that the projection from the ship sides should be about four scale feet, or a 1/2”.  As the above amortisement hints at, I wanted there to be a slight rounding of this level, at the middle, before tapering in towards the hull, at the foremost end.
The pictures below are a pretty clear evolution of this shaping process:
One thing worth mentioning, here, is that the projection of the false stern balcony is a bit exaggerated.  This owes to the fact that I did not, initially, realize that there needs to be a shelf of sufficient depth to support the four seasons figures.  Consequently, I had to graft-on an extension piece:
Ideally, the end-shape of the counter should match the moulded shape of the sides.  That won’t be the case with this build, but it does not appear too distracting on the model.  Lesson learned!
Now that I had established this shape, I could trace its bottom onto the top of the piece below it:
Please bear in mind that positioning on this scrap hull is only approximate, as the hull was cut down, in order to make my hull longer.
At this stage, I can begin applying all of the styrene pilasters, mouldings and ornaments that decorate these sub-structures.
Once, they are fully sheathed in their paneling, I can use them to determine the outside dimension and overhang of the transitional mouldings between sections.
I am wondering whether I should sand and seal the wood with something before using CA glue to attach the surface ornament.  Or, would I be better off sanding, applying surface ornament and then sealing with poly, or something else?  I’m just concerned about CA adhesion, here.  Also, considering that these wooden surfaces will be painted, how fine a grit do I need to sand to.  Is 220 sufficient?  The wood grain is very fine.  As always, any advice is welcome.
Thanks for taking the time to visit!  More to come...
Edited by Hubac's Historian
Your beakhead bulkhead is stunning.  Just fits right in with everything else.  I'm sure the king will be pleased.
Amazing it's from a plastic kit, fine detailing with your craftsmanship is really bringing out a beauty of a ship. Catching up on some blogs and been missing a bunch.
:cheers:
Current build project:
CSS Alabama 1/96
https://modelshipworld.com/topic/20148-css-alabama-by-jonathan11-revell-196-scale-kit-bash-90-historical-accuracy/
Finished build projects 2018:
H.L Hunley 1/24
CSS Arkansas 1/96
