Hi Marc -
The Helping Hands and the fly tying thread will make a significant improvement.  Go with that if it works for you.
Here is another solution that works in small scales like yours.
It relies on stropping with wire and making the hook an integral part of the strop.
The photo is pretty self-explanatory.  The block is 2mm from Warner Woods West.
You can add to the realism with a quick layer of paint on the hook to minimize the look of the twisted wire.
A line can be tied to the other side of the block to start the lacing from block to block.
Best of success
Dan
Hello Marc,
here the way I do it. This is a 3 mm block and a 0,3 mm rope
Then with a cannula I go through the rope once,
and a second time from below. Then I glue it with clear nail polish.
I wisk you good luck and nerves like wire ropes with your rigging.
Regards,
Siggi
Recent build: HMS Tiger (1747)
Gokstad ship (ca900) scratch build
Captains Barge ca. 1760, scratch build
HMS Dragon 74 gunner 1760, scratch build
GOOD DAY Siggi!
Thanks a lot!
This is real good way! It is almost real splicing!!! Looks very natural!!!
All teh Best !!!
Kirill
i intervene, by asking anyone here if they have seen any metal sanding sheets, i think with carbide abrasive coatings , fine and coarse.....it's like they don'l exist anymore ......they put sandpaper to shame....i still have some after 40 years.....sandvik came out with them first....you can cut them to any shape....the most wonderful tool ever.....maybe it's some kind of suppression?.......thanks....
If you mean those ubiquitous dark grey ‘wet & dry’ sanding sheets, which I believe are coated with silicone carbide, you can still get these just about everywhere relevant in the uk. But as we’re on the subject, can I make an additional recommendation, that being sanding mesh. If you are familiar with it, it’s really good on wood as it doesn’t clog and stays ‘sharp’ for much longer than normal sanding paper.
Kevin
Current projects:
strange...''they'' had course, medium, and fine.....purchased at home depot in vancouver many years ago.....i can't even see them mentioned  anywhere online.......i guess the the sandpaper manufacturers, forced termination somehow.....first sandvik, then another company took over....then.....ziltch.......they were-are just wonderful.....
In response to reading through my travails of researching and learning basic rigging techniques, Dan Pariser offered to give me a first-hand tech session of the various tools, materials and techniques that he employs in his own professional work.  As is always the case, this was time well-spent.
Immediate takeaways:
- The helping hands vise with a retro-fitted hardware store spring for tension is an absolute game changer.  Intuitively, this is common-sense, but actually using the device makes it crystal-clear how medieval my previous efforts really were.  Welcome to the enlightenment!
- Speaking of which, a simple magnifying visor really helps to ease eye-strain - particularly for fools like me who are still stubbornly resisting the very real need for transition lenses.
- Buying a box of small CA gel tubes is a wise investment.
- Along those lines - small disposable paper cups, like the ones you would use to stock a water cooler, are the perfect elevated platform for you to place a dollop of your gel CA.  I had been using small squares of tin foil, but it’s easy to lose sight of the glue spot and/or stick the foil to your hand when you aren’t paying strict attention.
- One really should accustom themselves to using bent-nose tweezers for their rigging processes.  Self-evident, I know, but I have a tendency to make due with whatever I have laying about.  I am usually working way too hard.
- Common, round tooth picks are the perfect CA applicators.
So, Dan showed me a variety of approaches to stropping a block, either with or without hooks.  What was especially fascinating was the interplay between polished line (free of whiskers) and either embroidery thread or fly-tying line for seizings.
Embroidery thread, because it has a lay, will grab onto the polished line, while fly-tying line is more prone to slipping.  This can make it difficult to advance the seizing.  To counteract this, when using fly-tying line, one might begin the seizing with a Lark’s Head knot, and then reversing both leads in the counter-direction, in order to cinch the knot tight:
https://howdidyoumakethis.com/larks-head-knot/
Another important take-away was to begin the seizing at the distance away from the block that you wish the seizing’s length to be.  With each successive wrap, the seizing grows tighter as it nears the block.
Lastly, a perfectly serviceable and long-lived serving machine can be made for a mere hardware store pittance:
As soon as I got home, I now found it incredibly easy to make hook strops for my 2mm double blocks:
Right now, I’m in the process of painting all of the main deck guns. Their bores have been blacked-out.  I have learned from my earlier experience with the lower main deck guns to always keep the gun barrels separate from each other during the painting process.  This is especially true for the next step, which is the Citadel ver-de-gris wash.  I’ll have a bit of a tedious touch-up process for those lower deck guns, much later in the build.
The cascabels are still white, here, because I am using that end to hold the barrel while I brush on the Citadel dark bronze.  I haven’t tried to airbrush this paint, but I suspect that the metallic flake would make it a poor candidate for air-brushing.  Once painted, I’ll join the barrels to their carriages.  I’ll add cap-squares with CA and strips of black construction paper.  Then, I’ll glue the guns down and attach the breaching ropes and tackles.
Dan showed me quite a bit more about knotting techniques and other rigging tips, but I will discuss those things as the build necessitates them.  Thank you so much, Dan!
And thank you all for looking-in!
Edited by Hubac's Historian
Off topic, but.
As a former 3M employee (retired).
Up until 25 years ago, the resin that "glues" the "sanding grains" to the paper was made from phenol and formaldehyde.
Not environmentally and health friendly, but of great quality.
Now a different, healthier resin is used. Less unhealthy, certainly. Better...?
Search the 3M website. You might find the sandpaper you are looking for there.
Yep, phenolic resins are so much better, because harder, for many applications ...
If you consider building a serving machine, you may also consider building yourself a rope-walk. Basically, you need the same kind of parts and materials, as for the serving machine. Ropes made from fly-tying threads or certain high-quality threads (e.g. Alterfil L 400, a German brand used now by various museums in Europe) will have a 'lay' and no fuzz.
Hi Marc -
Thanks for the compliments.  It's always gratifying to pass along the tips and tricks that I have worked out over the last 35 years.
I used to teach rigging seminars for the Guild, but they have been phased out.
I keep thinking that I will write a book one day, but it has never really gotten off the ground.
Happy to have helped.
Dan
Huge help, Dan!  The problem with rigging is precisely that there aren’t any substantive modeling technique books out there, so one finds themselves in a vast grey area of looking through better build logs along with their own experimentation.  In his books, Philip Reed details some of his rigging technique, but owing to small scales, that is often accomplished with wire.
As you said the other night - most of what a really good model requires isn’t complicated, but it is helpful to understand the best simplifications for the sake of whatever scale you are working in.
You have my vote, Dan; by all means, please write that book!
Thanks Marc, and by way of Marc thanks Dan, this is some good information and techniques. It was interesting for me recently when I toured the Cutty Sark in Greenwich, England. They have a small scale rope walk set up and visitors could help in making a small section of rope as a souvenir. I have seen numerous posts here on MSW showing a builder using a rope walk to make their own rope but never gave it much attention. I just use the variety of if rope sizes available online. However I did find it interesting watching how they work. I also was amazed when the guide explained they needed football field long buildings to make the ship ropes, which actually makes since. I may have mentioned before that as my different builds come and go I have more and more looked forward to the rigging the model. This is where the model actually comes to life I think. What I also find fascinating is that if a builder builds their model straight from a high quality kit with the supplied thread, blocks, and other rigging essentials, following the instructions they can achieve a very nice model. However for the more experienced and adventurous builder taking the rigging outside the box opens up vast avenues for the hobbiest. Marc your steps outside the box encourage me to maybe put a toe out there. And of course Dan, as Marc said, write that book. Teach classes. Do what you can to spread your infinite knowledge.
Bill
There is a bit of a scale gap in books and other instructions on the practicalities of realistic ship models. For instance, Lloyd McCaffery provides ideas for very small scales, based on wire, in his book. There are the old-time classics, such as Underhill, but they typically are aimed at a scale of 1/48 or perhaps down to 1/64 or so. In the range of 1/72 down to 1/200 there isn't anything specifically in bookform, as far as I am aware.
If you are interested in a tour-de-force of absolutely detailed, down to all the splicing and serving, rigging example in 1/48 including all the historical research that goes with it, have a look at @archjofo's log on LA CREOLE (we have been pushing him to write up his work in a more permanent form, but this is a lot of work).
Another example, but in 1/96 scale is @dafi's HMS VICTORY. At this scale, he has to make already simplifications and describes them very well, including rope-making.
At smaller scales the materials are a limiting factor. About the thinnest material for rope you can get is 16/0 fly-tying thread and Alterfil L400 sewing thread. Below that you will have to resort to wire.
Today, my son is home, sick, and so I stayed home with him.  This will afford me a few hours to assemble guns, while otherwise enjoying a lazy afternoon.
Painting of the barrels came out well.  The Citadel ver-de-gris wash is a little tricky to use.  Unless you are depicting the centuries-old guns currently on display at the Palais des Invalides, then you are going to want to dilute the wash-coat.  I like to use a medicine dropper to do this because it is easier to keep track of ratios that are repeatable.  I think I ended up at a 50/50 mix, cut with common tap water.
Despite thinning, the wash coat does dry almost immediately, and it is almost impossible to avoid lap lines with a brush.  I do think a bristle brush is the best applicator - as opposed to an airbrush - because you can draw color into and out of crevasses, thus modulating the effect.
After everything has dried, I use a Q-tip, covered with a t-shirt scrap to burnish each barrel, and minimize the lap-lines.  Particularly stubborn laps can be further softened with a well-worn SOFT toothbrush.
In the light of day, this degree of oxidation looks about right to my eye:
As for assembling, I have a small, round needle file that I use to clear paint from the trunnion blocks.  I scrape paint away from the undersurface of the trunnions, as well as the quoin and the cascabel rim, where these two surfaces meet.
I will add cap-squares, at least to the fully visible carriages.  If the process is not too tedious, I will do so for the rest of the main deck guns; it’s just a little extra bond-insurance to safeguard against guns breaking free of their carriages.
So, little by little.  Catch as catch can.  We are getting there!  Thank you for stopping by.
First of all, I wish your son a good recovery.
I guess fall was invented specifically for illness. My childhood memories of my ailments are primarily associated with this time of year. Of course it's not pleasant to be sick. But still, being sick as a child had its advantages, you could play games, even in bed. Building caves or castles out of blankets. I was also very fond of my childhood constructor, made of metal parts, slats and wheels. You had to connect them with bolts and nuts. For some reason they don't make those anymore. It's a shame. You could build mechanisms or transportation with it. Then I found nuts or other parts in my bed for a long time. So when I was a kid, there were advantages to being sick. And now when I get sick and ask to bring something like that to my bed, my wife looks at me strangely and scolds me. It's frustrating. Being sick as an adult is boring.
I won't say much about your work. I just don't understand much about working with plastic, and any words I say on the subject will show my low understanding in this technique. But I always watch all your releases and admire. You can be sure of that.
Sincerely, Aleksandr
7.30 - Wake up
9.00 - Dispersal of clouds
10.00 -19.00 - Feat
Looks about right to me too. When I was working up the resin printed Victory cannons a while back, I did a weathering trial on a few, using Vallejo Model Air cockpit green (71.331) diluted even further with a bit of water. It came out okay, but no better than that. With the paint being so watery, it was very difficult to get it 'just so'; it would run and sit in the corners but run off the surfaces, and when I look at those test pieces now, I can see that the results varied from cannon to cannon. Yours looks much better and, when I come to it, I'll try that citadel paint.
Kevin
Current projects:
11 hours ago, Hubac's Historian said:
would not most of Victory’s guns have been iron?
Yes, all iron as far as I know. I meant when I get to the SR!
Kevin
Current projects:
Ultimately, I decided to make cap-squares for all of the main deck guns.  With black construction paper and CA applied with a sharpened tooth pick, the process was relatively straight-forward, if a little time-consuming.
I used my new bent-nose tweezers to massage the paper into the glue, and to snug into the trunnions.  The glue wicks into the paper and polymerizes it.  Truly, paper is an underrated modeling material.  The added benefit is that the black construction paper has some tooth to it that approximates the scale appearance of wrought iron.  In other words - it’s not a very fine surfaced paper.
I’d be lying if I said that it didn’t bother me at all that I did not really address the raised trunnion mounting blocks on the carriage cheeks.  Naturally, with this much scraping of glue and general handling, there is going to be a round or two of paint touch-ups.
At first, I was going to re-touch the red around these silly trunnion blocks.  I had a eureka moment, though, and realized that I could paint those blocks black and they would blend into the cap-squares.
I experimented on the less visible guns, and liked what I saw (guns, right):
This may be a slight exaggeration of the scale of the cap-square irons, but at best - the carriages are mostly viewed from above.  What you will see is a straight red line delineating the top of the carriage cheeks.
I decided not to paint the paper cap-squares, themselves, because I did not want to lose that wonderful texture:
All-in-all, I think this turned out to be a fairly elegant work-around to a lot of extra work that I wasn’t interested in doing.
Next step:  mount and rig the guns.  As ever - thank you for your continued interest.
That’s a clever way of dealing with the cap squares. It must have taken huge patience to get them all so regular and the results look very convincing. I also prefer it to the ‘all red’ effect. When I come to do my SR cannons, even though it is probably not historically correct I will most likely leave the trucks with a weathered wood colour. The rims at least must surely have become a dirty grey in no time, just through use.
Kevin
Current projects:
Marc beautiful work as always. And the additional advice from you and Kevin is always so valuable. Kevin I am eagerly awaiting your start of your SR 😊.
If you guys, at your convenience, would check the question I have over on my Endeavour build and give me your opinion I would greatly appreciate it. Can’t decide for sure my sequence to proceed.
Hello to all,
This is just an alive and kicking post.
The past several weeks have been pretty frenetic and filled with ups and downs.  Thanksgiving was very nice, however the day after, my sister and I flew to Florida to see our Father’s brother (85), who landed in hospital with serious cardiac issues that necessitated an aortic valve replacement.  I am grateful that we were able to see him, because he passed the day after we left on Sunday.  Very tragic, as his wife passed in August of this year.  My cousins are distraught, naturally.
We then spent Sunday into Monday moving my Father to a new assisted living facility.  While this process was fraught with all kinds of logistical problems and oversights, my Dad at least went willingly.  He was, in fact, quite delighted with his new accommodations.  Unfortunately, owing to his advancing dementia, we can’t even tell him about his brother.  I don’t think he can even process that news, at this point.
Overnight, my father took a hard fall, and now I am with him, in hospital, awaiting results of all the scans they did.  I think he will be okay.  He’s in better condition than I was expecting.
Sooooo, needless to say - there hasn’t been a whole lot of time for modeling.  Over a period of weeks, when I had the energy and attention span, I very carefully closed all of my breaching rope rings around their bulwark eye bolts.  Druxey’s idea to file a groove into a pair of tweezers gave me just enough purchase to close the rings without completely collapsing their shape.  Thanks again, David!
Last night, before this latest misfortune, I was able to glue those guns in place:
While I am not a saber-rattler, by any means, it is nice to see the ship begin to be armed as befitting her raison d’etre.  The next step will be to arrange the breaching ropes in a more realistic fashion that conveys a sense of heft and a natural lay.  I will achieve this with dilute white glue.  After that, I can attach and arrange the haul-out tackles.
One project that I would like to soon undertake is the design and fabrication of the new f’ocsle break rail, belfry and the quarter deck break rail.  All of that gingerbread stuff makes me happy.
Now, I would like to take this opportunity to introduce you all to my friend Eric Wiberg.  He has undertaken his own Heller SR modification project, and it is quite a bit more ambitious than my own.  He is modeling Soleil Royal, 1671.
Here, a brief re-cap of his alterations, to date:  He has completely re-mapped the wales so that the forward sheer is less pronounced, and the aft sheer rises appropriately for a vessel of this early time period.  He has added to and arranged the artillery so that it is correct in number and placement.  He has sanded away the kit grain, filled the kit plank lines, and scribed new plank lines that follow the new wale sheer.  The wales are correctly graduated in scale, and the upper wales will eventually be ornamented with the famed l’istons d’or.
Eric has created new, correctly scaled timberhead railings that will eventually be bracketed by dolphin hancing pieces.  He has re-shaped the main deck ports so that they are correctly square.  He has added a waist ladder, skids and scuppers, and he has planked his inner bulwarks.
At the moment he is experimenting with the steave of the bowsprit, as he plans to completely re-construct the head, so that it has the more “Dutchy” early appearance of her near contemporary, La Reyne.  Here, a few pics to whet your appetite:
A number of people have undertaken these very complex modification builds.  Eric possesses the talent and determination to bring this all to fruition.  Please come take a look for yourselves:
Until next time, let your friends and family know just how much you love them.
All the best,
Marc
Marc I am so sorry to hear about your uncle and dad. These times can be so sad for you, especially around Christmas. As I mentioned before I went through this with my mom. It is great when you can get away from it for a few minutes and let your brain sink into your ship. She is looking great.
Be at peace my brother!
Bill
Edited by Bill97
