US Brig Syren by Hipexec - FINISHED - Model Shipways - 1:64 - building as USS Argus
I've built the bowsprit bit ( inboard support for the base of the bowsprit.) Now I have to clean it up, stain it, then pin and glue it to the deck
Link to comment
Share on other sites
Link to comment
I glued the bowsprit cap on since I finally got the angle right. The bowsprit is just dry fitted untill I build the whole thing up.
Edited by HIPEXEC
Link to comment
22 hours ago, HIPEXEC said:
Tapering the bowsprit with my home made lathe
Ha that is amazing! I imagine for work of this scale, you wouldn't always need an actual lathe. Just something to spin it for a few quick cuts? I'll have to remember this one for later.
Cheers,
Andrew
Current: Amati Viking Drakkar
Link to comment
I've glued the jib boom to the bowsprit. The bowsprit still remains dry fitted
Link to comment
I'm continuing to detail the bowsprit. I'm making some modifications since I am building "The Argus" not "Syren"
Link to comment
Link to comment
Flying jib boom installed. I added a rear support since I didn't think the partially drilled hole at the base would be enough to handle all the stresses and strains of rigging
Link to comment
I'm fabricating the bow splash guard. Since I changed a lot on the hull, I had to make a splash guard from scratch since the pre-cut pieces didn't work anymore
Link to comment
I've pinned and glued the bowsprit to the hull. I'll add the Dolphin Striker later. The Splash guard isn't finished yet but I dry placed it in position for the photo
Link to comment
I've glued the Splash Guard in position. Once set, I shall stain it to match the ship
Link to comment
13 hours ago, Mahuna said:
Great progress, Rich.  I'm really happy that you're back in your shipyard.
Thanks Frank. It feels good to be back
Link to comment
I had to give up making the Dolphin Striker according to the plans. The wood provided and the desighn made it just too fragile. So, I made one out of some brass stock I had laying around. Now a bomb won't break it. It's pinned and glued in place. Now I just have to fancy it up.
Edited by HIPEXEC
Link to comment
I made and installed the Jack Staff. I'll pretty the whole Jack Staff and Dophin Striker area up when the glue dries
Link to comment
I made and installed the inboard boarding ladders. I used leftovers from other kits since this kit made you make them from scratch
Link to comment
I'm starting to build the ship's binnacle. Again, Model Shipaways provided very fragile parts. The back piece split when I tried to clean it up. I will build it with the provided parts and if I don't like it a'll scratch build one
Link to comment
5 hours ago, s4usea said:
Didn't they put out a second version with better parts? Or was that just the Essex?
I don't know, but this kit has sub standard wood. It makes you get very creative
Link to comment
I staged the binnacle parts, broken and all, and added a base to the cabinet since I have no idea how it would stay together without it. I'm adding a much more sturdy top piece. I still think I have to add more structure to it to make it work. We'll see
Link to comment
Binnacle glued together. I had to add many pieces from the plan to get it to hold together. Now I have to clean it up and stain it to make it passable.
Link to comment
Binnacle stained. My fingers can't build anything smaller than this!
Edited by HIPEXEC
Link to comment
Binnacle is now glued in place with a "compass" installed. I made the compass out of an old kit's cannon wheel painted black with a silver face
Link to comment
1 hour ago, src said:
That binnacle is quite the little project Rich. Looks good there.
Sam
Sam
It's more like a tiny tiny project. That was my limit for tiny woodworking
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
