USS Syren by Hipexec - Model Shipways - 1:64 - building as USS Argus
9 hours ago, HIPEXEC said:
The fighting top rims splintered while drilling the holes for the deadeyes. I will now rebuild the damaged rims.
Bummer, Rich.  Try starting the holes with a very small drill and work your way up to the final size.
Link to post
Share on other sites
Here we go again! The instructions say to drill the small rigging holes in the pre-cut top cross trees before removing them from the laser-cut sheet. Guess what? I gently took the smallest drill bit I had that would make a tiny hole for the rigging...and the cross tree split after two turns (gently)! I'll figure out how the rig them another way.
Link to post
For drilling a small hole in a small piece like that, you are probably much better off with a high speed drill than hand drilling it.
I'd use a very sharp bit in a dremel tool turning at high speed and it would probably drill through fairly clean as long as you used very light pressure.
Turning it very slowly lets the bit grab the wood and split it instead of just shaving off a tiny bit with each rotation.
I'm way too far away for a trip just for this, but if you do want to drive out here you are welcome to do it on my mill.
Link to post
Thanksgiving
ill try my dremel
rich
Link to post
I give up with this junk wood. I drilled four beautiful holes only to have them crumble after all the drilling was done. I made my own cross trees on my Connie by bending some good wood and drilling the pieces with no trouble at all. So much for the  laser cut junk wood. All they had to do was pop some holes with the laser and that probably would have worked.
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
    No registered users viewing this page.
