With all the manipulating the hull while planking, the center section of the transom came un-glued. It'll be good the get the transom planked to protect it.
Here I'm bending and twisting a plank in several directions so it will easily fit on the hull. Most of the planks from now on will need the same treatment.
1/8" a day. That's slow planking. So, I'm still bending, shaping and gluing planks. Pre-shaping the plank on the hull really makes the gluing part easy. No forcing at all.
I'm showing pictures of plank progression since the plans do not have detailed pictures as the planking progresses. The center part of the hull is always the trickiest part, so I will take photos along the way so maybe it can help others building this kit.
Moving right along! Well done.
Are you planking from both the keel up and the bulwarks down at the same time?
Doug
Current BuildsBluenose II - AKrabbenkutter / Prince de Neufchatel / Essex Cross-section / Syren / Barque Stefano / Winchelsea / Half Hull / Maria HF31 - Dusek / Bandirma - Turkmodel
On the Shelf: Santisima Trinidad and Cross Section / HMS Cutter Alert / Tender AVOS / Confederacy
Suspended Build: Bluenose II - Billing Boats Nr 600
Another plank. I'm showing all progress in case someone really wants to see how long this planking process takes me and why. On many logs they show the beginning of the planking process...then wham....they show the whole hull planked. If it only was that easy.
I love the way my planks fit into place after all the pre-bending, twisting, beveling and wet pre-fitting I do. The fully prepared plank virtually snaps into place even without glue. I've come a long way from the first models where I wrestled with planks forcing them into place.
While the glue dries on my last plank, I'm wet pre-forming two planks putting the last bends, twists and curves before beveling and later tapering.
The first picture is of a pre-bent, pre-twisted, pre-beveled plank. The next photo shows this plank freshly glued in place. Notice...it doesn't need clamps!
I just discovered your build Rich. I'm joining in and following along.
Jesse
 Current build: Syren : Kit- Model Shipways
Side project: HMS Bounty - Revel -(plastic)
On hold: Pre-owned, unfinished Mayflower (wood)
Past builds: Scottish Maid - AL- 1:50, USS North Carolina Battleship -1/350  (plastic),   Andromede - Dikar (wood),   Yatch Atlantic - 14" (wood),   Pirate Ship - 1:72 (plastic),   Custom built wood Brig from scratch - ?(3/4" =1'),   4 small scratch builds (wood),   Vietnamese fishing boat (wood)   & a Ship in a bottle
I agree with Greg.  The good thing is that all of the planking below the water line will be covered with coppering.  And the coppering is easier to do than you might imagine.
<<Gary>>
current build: SYREN
nearly done:  Fair American, Benjamin W. Latham
future builds:  Emma C. Berry
completed builds:  Rattlesnake, Newsboy, Sultana
More pre-bending. I'm using various methods to hold each plank since the places to hold them keep changing and shrinking. I use rubber bands, clips, nails or anything else that will hold the drying planks. After they dry I will bevel them to fit.
