HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 69 donations so far out of 49,000 members - Can we at least get 100? C'mon guys!) ×
Thanks to all who have visited, commented, and liked. Both sides of the hull are now planked below the deck. Not as good as I would like, but it came out okay.
Russ
Russ
Nope.. not "okay"... it came out great.
Kenneth:
Exactly. The model will always keep me humble. That and the camera that sees everything I do not.
Russ
I'd be extremely happy for an outcome like that........really nice looking hull! :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Elia:
Good to hear from you. Thanks for the kind words. I also like the stem and how it affects the planking. That is one of my favorite aspects of this hull form.
Russ
A little more progress the past few days. I began work on the bulwarks for this lugger. These vessels have a lightly planked bulwark and there is a slot left open at deck level to clear water from the deck. These vessels often come back to the dock with the decks awash because of their heavy load of shrimp or oysters.
My challenge is to make sure that this long open slot is of a uniform width for its complete length. I needed a jig to ensure that uniform spacing. I used scrap material of the same thickness as the opening and then glued several pieces of it inboard to a piece of decking material. The jig can be slid in place when and where necessary. It is temporarily nailed to the subdeck to ensure that it follows the sheer of the deck. It does not look pretty, but it got the job done. Once the glue holding the bulwarks planking to the stanchions has dried, the jig can be removed.
Maybe this will help someone with a similar issue.
Russ
Pat:
Thanks. This will be very useful for me since many of these local vessels have that same scupper slot along the deck.
Russ
There is a little progress to report. The starboard bulwark is complete. This was tedious. The result are not all that I hoped, but this model will be painted so it will probably not be that noticeable. I learned a few good lessons that can be applied to the next model. That is never a bad thing. :)
Russ
I do not see anything a miss on that starboard side ... maybe clean your visor
Carl
A tad of filler and a lick of paint will fix it but I don't see too much amiss there Russ.  Did you have the lens cranked to max zoom when looking?
cheers
Pat
