All,
I have a couple questions.
I have been granted permission to purchase a mill.  I have decided on a Sherline 5400.
Where has everyone purchased their equipment?  Directly from Sherline?  An authorized dealer?  Obviously I'm looking to get the best deal I can.
Also which does everyone prefer, imperial or metric?  I don't want to start a debate, but just looking as to which direction everyone goes and why.
What about DRO (Digital Read Out) seems like it would be a nice feature to have.
What about CNC, I've never used CNC before and for what I will be using the mill for it doesn't really seem to be an option I would really need right now.
Any guidance would be appreciated.
Thanks
Shawn
I bought mine after the NRG conference direct from Sherline and got a 10% Conference discount.  THey had a "Senior Citizen" 10% discount as well but not both.
Maury
I ordered my Sherline mill from an authorized retailer for significantly less money.  The name escapes me but it was somewhere on the East coast.  The advantage of buying direct from Sherline is the advise you will receive to guide your purchase.  Don't forget, the accessories will cost you at least as much as the mill itself, so plan your purchase accordingly.
Toni
Member IPMS
                           Utrecht-1742
I bought my Sherline gear from Discount Campus http://www.discountcampus.com/store/sherlineonline.htm and got a better price than Sherline was offering. No complaints at all on the service I received.
I heartily recommend getting the DRO on the mill. It really can be helpful. I didn't get CNC because I wouldn't know how to use it and don't really have a lot of interest in investing the time to learn it. Aside from that, it adds significantly to the cost since you also have to factor in a computer and software.
Although I live in the US, I bought my mill in metric. I just find it much easier to use than Imperial. I can divide by 10 in my head much more easily than I can divide by 16. I work in metric for all my measuring, not just the mill. That said, you'll likely be working with cutters measured in Imperial, such as 1/8" or 3/16". Sometimes you need to be able to move half the width of your cutter, so you have to convert to metric. I just made up a simple conversion chart that I tacked to the wall behind the mill. No big deal.
Cheers -
John
Sa far as the metric question.  Buy what you are used to using.  My machine is in metric but I don't think in metric, so it's always b problem to change my thinking for the job and a lot of the time I make mistakes in the conversions.
Bob
Current build:  SS_ Mariefred
Discount Campus is who I purchased my mill from.
Toni
Member IPMS
                           Utrecht-1742
I have not used a Sherline but this chap is doing some amazing work in metal on one, and has some interesting comments about the handles.
http://www.modelenginemaker.com/index.php/topic,6515.60.html the page is talking about machining stainless plates for a steam hauler, if you scroll down there are some pictures of his model ship building, which is very nice too.
Overall it looks like a very nice machine. if I were looking for a lathe and mill combination I would seriously consider this machine, Bob's comment about the cutters is useful, remember that you can purchase metric cutters as well.
Michael
The ship is very nice.  The background story is amazing.
Toni
Member IPMS
                           Utrecht-1742
Not sure why you'd want a Sherline, seems to me there are far better options for roughly the same price. Little Machine Shop is where I have always bought my machine tools. The micro mill is better than the Sherline, but it's the mini-mill for about $100 more than yours that's an order of magnitude more capable with a far greater and varied ecosystem of accessories and modifications and DROs that can be added.
Edit, the HiTorque versions are preferable as those can handle machining steel no problem, but if you're willing to machine steel a bit more slowly, see the Sieg X2 Mini Mill that's on sale for $599. Out of the box I think it's a considerably better choice than Sherline. The HiTorque mini mill is just a Sieg X2 modified per LMS' specs to have an upgraded motor.
If you happen to own a Sherline lathe already, then check the website.  Last night I saw that the vertical milling columns were on sale from $160-300.  They fit the lathe - remove the headstock and mount it on the vertical column, and then mount the vertical column at the headstock position.  About inch vs. metric, it really doesn't matter - the inch screws are 20TPI, so one revolution of the wheel is 0.050", and the wheels are graduated in 0.001 increments.
I have both the mill and the milling column for the lathe.  The milling column works really well, but the x-axis is limited to the travel of the lathe's cross-slide.  It would be a good way to start milling, and I've found having both to be a great advantage when I have repetitive milling activities that would require frequent changing of tooling.
